Re: dreaded beam, let me count...
I expect that the Cal 2-30 has the beam, but I do not have first-hand
knowledge of this.
The 2-30 was built in the same period as the 29 and 2-29 (the wheel version)
and I believe that both share the same underbody. The big differences are
that the 2-30 has a reverse transom (probably for a favorable racing rating)
and a considerably smaller cockpit.
I believe that the drawing on this page shows the beam:
http://sailboatdata.com/viewrecord.asp?class_id=1066
Let me start by saying that I am not an engineer (though I have played one
in the magazines.) The function of the beam, as I understand it, is to
distribute the forces involved in keeping the mast upright. The deckmounted
mast creates a downward force, which is transferred through a post in the
cabin (at the main bulkhead) down to the center of the beam below the floor
pan. The upper shrouds are attached to chainplates on the main bulkhead, and
these exert an upward force. The beam is attached by bolts through metal
tabs to the main bulkhead. Thus the upward force from the shrouds is
transferred to the ends of the beam. The beam thus balances the downward
force of the mast with the upward force on the shrouds, and distributes the
forces to the hull below. It is an integral part of keeping the pointy parts
aimed at the sky.
It is important to make sure that the drainage from forward of the main
bulkhead is not impeded on its way to the bilge sump. If water backs up, the
plain steel of the beam will rust and rot away. (I have pictures; they are
not for the faint of heart.) When Roger Jones redesigned the replacement
beam, he flattened the curved bottom plate so that water would not get
blocked by dirt and debris. I believe that this was a smart move.
I'm happy to field questions if that would be helpful.
Alfred Poor
Former owner of 1969 Cal 29 #132
