5 messages2015-06-15 19:14 UTCthrough 2015-06-15 23:11 UTC
OLD ENGINE
Gary Mcgregor2015-06-15 19:14 UTC
Hello,
I was wondering if anyone has a suggestion for removing this old engine?Is there anything I shouldn't do?
Thanks,Gary.
Re: [Cal_Boats] OLD ENGINE [3 Attachments]
Joe DeMers2015-06-15 19:26 UTC
Hi Gary -
DO_ - get a 1/2" nylon line around it, and hoist away. A comealong helps
a lot. Weight is about 300 pounds.
DON'T - drop it on your foot! Joe DeMers
On 6/15/2015 3:14 PM, Gary Mcgregor ga… [at] yahoo.com [Cal_Boats] wrote:
> [Attachment(s) <#TopText> from Gary Mcgregor included below]
> Hello,
> Thanks,
> Gary.
*Joe DeMers - owner*
Sound Marine Diesel LLC
(860) 666-2184*
Gary Mcgregor2015-06-15 19:28 UTC
Hi Joe,
Funny!Thanks,
Gary.
On Monday, June 15, 2015 12:26 PM, "Joe DeMers je… [at] mindspring.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
Hi Gary -
DO_ - get a 1/2" nylon line around it, and hoist away. A comealong helps a lot. Weight is about 300 pounds.
Hello,
I was wondering if anyone has a suggestion for removing this old engine? Is there anything I shouldn't do?
Thanks, Gary.
Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.comphone & fax (860) 666-2184 -- {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} hr {border:1px solid #d8d8d8;} {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} {margin-bottom:10px;} .yiv6184436183ad {padding:0 0;} .yiv6184436183ad p {margin:0;} .yiv6184436183ad a {color:#0000ff;text-decoration:none;} {font-family:Arial;} {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} .yiv6184436183ad {margin-bottom:10px;padding:0 0;} {font-family:Verdana;font-size:11px;padding:10px 0;} {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} span {font-weight:700;} span:first-child {text-transform:uppercase;} span a {color:#5085b6;text-decoration:none;} span span {color:#ff7900;} span .yiv6184436183underline {text-decoration:underline;} .yiv6184436183attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} .yiv6184436183attach div a {text-decoration:none;} .yiv6184436183attach img {border:none;padding-right:5px;} .yiv6184436183attach label {display:block;margin-bottom:5px;} .yiv6184436183attach label a {text-decoration:none;} blockquote {margin:0 0 0 4px;} .yiv6184436183bold {font-family:Arial;font-size:13px;font-weight:700;} .yiv6184436183bold a {text-decoration:none;} dd.yiv6184436183last p a {font-family:Verdana;font-weight:700;} dd.yiv6184436183last p span {margin-right:10px;font-family:Verdana;font-weight:700;} dd.yiv6184436183last p span.yiv6184436183yshortcuts {margin-right:0;} div.yiv6184436183attach-table div div a {text-decoration:none;} div.yiv6184436183attach-table {width:400px;} div.yiv6184436183file-title a, div.yiv6184436183file-title a:active, div.yiv6184436183file-title a:hover, div.yiv6184436183file-title a:visited {text-decoration:none;} div.yiv6184436183photo-title a, div.yiv6184436183photo-title a:active, div.yiv6184436183photo-title a:hover, div.yiv6184436183photo-title a:visited {text-decoration:none;} div p a span.yiv6184436183yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;} .yiv6184436183green {color:#628c2a;} .yiv6184436183MsoNormal {margin:0 0 0 0;} o {font-size:0;} div {float:left;width:72px;} div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;} div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} {font-size:77%;} {font-size:77%;} .yiv6184436183replbq {margin:4px;} div a:first-child {margin-right:2px;padding-right:5px;} {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} table {font-size:inherit;font:100%;} select, input, textarea {font:99% Arial, Helvetica, clean, sans-serif;} pre, code {font:115% monospace;} * {line-height:1.22em;} {padding-bottom:10px;} p a {font-family:Verdana;} p span {color:#1E66AE;font-weight:700;} {color:#ff7900;font-weight:700;} {margin-bottom:20px;padding:0px;} li a {font-size:130%;text-decoration:none;} li {font-size:77%;list-style-type:square;padding:6px 0;} ul {margin:0;padding:0 0 0 8px;} {font-family:Georgia;} p {margin:0 0 1em 0;} tt {font-size:120%;} ul li:last-child {border-right:none !important;}
sailor7312 .2015-06-15 20:19 UTC
When I pulled my old feryman diesel out of my 29, I used my main and jib
halyards
with a loop that went around my boom. basically the halyards were attached
to the loop that went around the boom.
I used a 6:1 mainsheet on the bottom of the loop to lift the engine. I used
a 4:1 that went from the loop to the end of the boom to move
in and out.
Moving in and out required pushing to get the loop around the various
fittings on the boom, but we lifted it out, up and then passed it down on
the ground in pretty short order.
It was a decent system and by having a loop around the boom, w the halyard
holding at the top and the load attached at the bottom of the loop, the
boom is there only to steady the load and provide outward pull.
Always a good idea to discuss w everyone an exit strategy if things go
wrong.
use new line.
Good luck
Jim
East Coast cal 29 sailor.
On Mon, Jun 15, 2015 at 3:14 PM, Gary Mcgregor ga… [at] yahoo.com
[Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> [Attachment(s) <#14df8a59a7b2ad0b_TopText> from Gary Mcgregor included
> below]
> Hello,
> Thanks,
> Gary.
Terry Spencer2015-06-15 23:11 UTC
I built a bracket that sits on my companionway hatch track out of 2 X 10 material. One piece sits on top of the track and other bolted to it, fits just inside the edge of the companionway.
In the center of this contraption, I put a hefty eye bolt.
To that, was attached a chain hoist (not terribly expensive at Harbor Freight).
I tied line around the engine and hoisted away. The chain hoist gives very good control. The bracket allows one to slide the engine forward a bit to get it out over the companionway floor.
To get my old Farryman completely out of the boat when I repowered, I put the boat under a boat launch and had them lift it out of the boat and place it on the bed of a pickup.
Good luck,
Terry
Cal 2-29
> On Jun 15, 2015, at 1:19 PM, 'sailor7312 .' sa… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> When I pulled my old feryman diesel out of my 29, I used my main and jib halyards
> with a loop that went around my boom. basically the halyards were attached to the loop that went around the boom.
> I used a 6:1 mainsheet on the bottom of the loop to lift the engine. I used a 4:1 that went from the loop to the end of the boom to move
> in and out.
> Moving in and out required pushing to get the loop around the various fittings on the boom, but we lifted it out, up and then passed it down on the ground in pretty short order.
> It was a decent system and by having a loop around the boom, w the halyard holding at the top and the load attached at the bottom of the loop, the boom is there only to steady the load and provide outward pull.
> Always a good idea to discuss w everyone an exit strategy if things go wrong.
> use new line.
> Good luck
> Jim
> On Mon, Jun 15, 2015 at 3:14 PM, Gary Mcgregor ga… [at] yahoo.com <mailto:ga… [at] yahoo.com> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>> wrote:
> [Attachment(s) <x-msg://1/#14df8a59a7b2ad0b_TopText> from Gary Mcgregor included below]
> Hello,
> Thanks,
> Gary.
