Re: Cal 39 Opening Ports
3 messages2015-07-14 03:02 UTCthrough 2015-07-14 07:22 UTC
Robert Andrew2015-07-14 03:02 UTC
I did this during the winter of 2013-2014. Very satisfied with them. The plastic originals were leaking and had to be removed - many broke in the process - and I couldn't see doing all that removal work and simply putting back new plastic. The installation is straightforward, assuming you are reasonably handy, have the right tools and some familiarity with fiberglass work and sealants. But, it is time consuming and the install (not the prep) is definitely a two person job. I worked together with someone at the yard where my boat spent the winter. We used 3M 4000, not the butyl so I can't comment on that. Very important to get all of the old silicone sealant off and you will have to cut new openings, as the Newfound product is close, but it is a different opening. You will also need the trim pieces for the interior because the cabin thickness is not sufficient. It's not an inexpensive project, but it is a big improvement in both form and function. I almost never opened the old ports - these are a snap to open and close and they give the boat a totally different and much improved look. Bob Andrew CAL 39 Nereid Norwalk CT
Ports for Cal 35 Cruise?
Peter Ford2015-07-14 05:22 UTC
Hi, Has anyone replaced their ports (3 front, 3 each side, one sliding rear) on their Cal 35 Cruise? Is there a recommended supplier for these? My captain wants me to look for opening Portlights to replace at least a couple of the fixed Ports? Any advice on this front? I am familiar with New Found Metals that has been noted in the Cal 39 Portlight discussions. regards, peter
Re: [Cal_Boats] Ports for Cal 35 Cruise?
Kris Jensen2015-07-14 07:22 UTC
Mine are custom fixed offshore ports. Powder coated aluminum frames and 1/2 inch polycarbonate. For seaworthy opening frames, you'd probably want to check out Diamond Sea-Glaze or maybe Manship. Wont be cheap but they will be really nice compared to the stock windows which were not really suitable to leave protected waters with. Kris From: "Peter Ford pe… [at] hotmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> To: "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com> Sent: Monday, July 13, 2015 10:22 PM Subject: [Cal_Boats] Ports for Cal 35 Cruise? Hi, Has anyone replaced their ports (3 front, 3 each side, one sliding rear) on their Cal 35 Cruise? Is there a recommended supplier for these? My captain wants me to look for opening Portlights to replace at least a couple of the fixed Ports? Any advice on this front? I am familiar with New Found Metals that has been noted in the Cal 39 Portlight discussions. regards, peter -- {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} hr {border:1px solid #d8d8d8;} {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} {margin-bottom:10px;} .yiv2296219890ad {padding:0 0;} .yiv2296219890ad p {margin:0;} .yiv2296219890ad a {color:#0000ff;text-decoration:none;} {font-family:Arial;} {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} .yiv2296219890ad {margin-bottom:10px;padding:0 0;} {font-family:Verdana;font-size:11px;padding:10px 0;} {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} span {font-weight:700;} span:first-child {text-transform:uppercase;} span a {color:#5085b6;text-decoration:none;} span span {color:#ff7900;} span .yiv2296219890underline {text-decoration:underline;} .yiv2296219890attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} .yiv2296219890attach div a {text-decoration:none;} .yiv2296219890attach img {border:none;padding-right:5px;} .yiv2296219890attach label {display:block;margin-bottom:5px;} .yiv2296219890attach label a {text-decoration:none;} blockquote {margin:0 0 0 4px;} .yiv2296219890bold {font-family:Arial;font-size:13px;font-weight:700;} .yiv2296219890bold a {text-decoration:none;} dd.yiv2296219890last p a {font-family:Verdana;font-weight:700;} dd.yiv2296219890last p span {margin-right:10px;font-family:Verdana;font-weight:700;} dd.yiv2296219890last p span.yiv2296219890yshortcuts {margin-right:0;} div.yiv2296219890attach-table div div a {text-decoration:none;} div.yiv2296219890attach-table {width:400px;} div.yiv2296219890file-title a, div.yiv2296219890file-title a:active, div.yiv2296219890file-title a:hover, div.yiv2296219890file-title a:visited {text-decoration:none;} div.yiv2296219890photo-title a, div.yiv2296219890photo-title a:active, div.yiv2296219890photo-title a:hover, div.yiv2296219890photo-title a:visited {text-decoration:none;} div p a span.yiv2296219890yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;} .yiv2296219890green {color:#628c2a;} .yiv2296219890MsoNormal {margin:0 0 0 0;} o {font-size:0;} div {float:left;width:72px;} div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;} div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} {font-size:77%;} {font-size:77%;} .yiv2296219890replbq {margin:4px;} div a:first-child {margin-right:2px;padding-right:5px;} {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} table {font-size:inherit;font:100%;} select, input, textarea {font:99% Arial, Helvetica, clean, sans-serif;} pre, code {font:115% monospace;} * {line-height:1.22em;} {padding-bottom:10px;} p a {font-family:Verdana;} p span {color:#1E66AE;font-weight:700;} {color:#ff7900;font-weight:700;} {margin-bottom:20px;padding:0px;} li a {font-size:130%;text-decoration:none;} li {font-size:77%;list-style-type:square;padding:6px 0;} ul {margin:0;padding:0 0 0 8px;} {font-family:Georgia;} p {margin:0 0 1em 0;} tt {font-size:120%;} ul li:last-child {border-right:none !important;}
