9 messages2015-08-03 13:58 UTCthrough 2015-08-06 05:38 UTC
Re: [Cal_Boats] Repacking Cutless Bearing on '73 Cal29
Marty Martin2015-08-03 13:58 UTC
Yes, stuffing box. Thanks to everyone for pointing this out. Cutlass bearing needs replaced as well as stuffing box repacked.
Joe DeMers2015-08-03 14:09 UTC
Hi Marty - call me at the number below, and I will answer your questions. *
*Joe DeMers - owner*
Sound Marine Diesel LLC
(860) 666-2184
(860) 666-2184*
Helen Horn2015-08-04 06:54 UTC
We replaced the cutlass bearing (through the strut)by pulling the shaft and making a very careful cut (parallel to shaft) with narrow sawzall blade, it then peels up to shrink the circumference and pull it out. But maybe you can realign your shaft, repair the stuffing box as well at the same time. It could be misaligned and could chew it all up. Check for bent, scored shaft, or bent strut. We needed to redo strut in our case.(Noah's Kid 74 cal 29) Helen and Edward
From:"Marty Martin wm… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
Date:Mon, Aug 3, 2015 at 7:01 AM
Subject:Re: [Cal_Boats] Repacking Cutless Bearing on '73 Cal29
Terry Spencer2015-08-04 15:01 UTC
Helen,
Where did you get your new strut? They’d told me mine is going bad.
Thanks in advance.
Terry
Cal 2-29
Capriccio
Tacoma
> On Aug 3, 2015, at 11:54 PM, Helen Horn he… [at] sbcglobal.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Sent from Yahoo Mail on Android <https://overview.mail.yahoo.com/mobile/?.src=Android>
> From:"Marty Martin wm… [at] yahoo.com <mailto:wm… [at] yahoo.com> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>>
Re: [Cal_Boats] Repacking Cutless Bearing on '73 Cal29 (Terry)
Michael D2015-08-04 15:07 UTC
Terry,
I recall that the 2-27 and 29 have the same strut. We replaced our strut three years ago. We had it fabricated in SS by Frank & Jimmie's in Fort Lauderdale. Give them a call. They may have saved drawings. In my case, I think the strut was around $700, but I forget.
Michaels/v Magic, Cal 2-27, #627Pompano Beach, FL
From: "Terry Spencer ts… [at] harbornet.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
Sent: Tuesday, August 4, 2015 11:01 AM
Subject: Re: [Cal_Boats] Repacking Cutless Bearing on '73 Cal29
Helen,
Thanks in advance.
TerryCal 2-29CapriccioTacoma
Timm Danish2015-08-04 15:32 UTC
You need the measurements ans angle and then talk to fisheries in Seattle who sells buck Algonquin bronze stuff.
dEmO
> On Aug 4, 2015, at 8:01 AM, Terry Spencer ts… [at] harbornet.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Helen,
> Thanks in advance.
> Terry
> Cal 2-29
> Capriccio
> Tacoma
Fred Haas2015-08-04 18:53 UTC
Terry,
When i hauled Nemesis at Citadel a couple of years ago they were able to weld up the electrolysis damage on my strut. Since then I have had a rudder zinc bolted directly to it, nd there have been no more issues.
Fred Haas
3-30 Nemesis
Tacoma
On Aug 4, 2015, at 8:07 AM, Michael D md… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Terry,
> Michael
> Pompano Beach, FL
> Helen,
> Thanks in advance.
> Terry
> Cal 2-29
> Capriccio
> Tacoma
RE: [Cal_Boats] Repacking Cutless Bearing on '73 Cal29 (Terry)
Timm Lessley2015-08-04 21:21 UTC
Aluminum is the preferred "anode" in most circumstances.
We almost never install or recommend zinc as an anode.
If your strut is almost bad, then put a rudder anode on it made of aluminum
( THEY LOOK LOKE SAND DOLLARS) and monitor it.
You might also consider making sure that the bolts on it are bonded to the
rest of your system, which they most likely are not, which is why it is
possibly part of its turning pink and failing.
dEmO
Sent: Tuesday, August 04, 2015 11:53 AM
Subject: Re: [Cal_Boats] Repacking Cutless Bearing on '73 Cal29 (Terry)
Terry,
Fred Haas
3-30 Nemesis
Tacoma
<mailto:md… [at] yahoo.com> [Cal_Boats] <Ca… [at] yahoogroups.com
<mailto:Ca… [at] yahoogroups.com> > wrote:
Terry,
Michael
Pompano Beach, FL
From: "Terry Spencer ts… [at] harbornet.com <mailto:ts… [at] harbornet.com>
[Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> >
Helen,
Where did you get your new strut? They'd told me mine is going bad.
Thanks in advance.
Terry
Cal 2-29
Capriccio
Tacoma
<mailto:he… [at] sbcglobal.net> [Cal_Boats] <Ca… [at] yahoogroups.com
Helen and Edward
<https://overview.mail.yahoo.com/mobile/?.src=Android> Sent from Yahoo Mail
on Android
Helen Horn2015-08-06 05:38 UTC
Echoing Fred. We also used sand dollar shape zinc on strut of 29, a bolt-together torpedo zinc on the one inch shaft. and our maxprop had its own zinc tailpiece. Sorry was away a few days. Looking for info and contact for strut. Helen Sent from Yahoo Mail on Android
From:"Fred Haas ca… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
Date:Tue, Aug 4, 2015 at 11:53 AM
Subject:Re: [Cal_Boats] Repacking Cutless Bearing on '73 Cal29 (Terry)
Terry,
Fred Haas
3-30 Nemesis
Tacoma
Terry,
Michael
Pompano Beach, FL
Helen,
Thanks in advance.
Terry
Cal 2-29
Capriccio
Tacoma
