Season's close
Last night I put the winter cover on Cal 20 #1220, /Martha C/. It was
also the first night I've worn long pants to work. There was a stiff
wind from the north and it was chilly. I had worn shorts the night
before when doing my last epoxy work and when putting my winter cover
supports in place.
The epoxy work involved replacing the fiberglass on a portion of the
overhead. A couple years ago there was a sudden water intrusion via a
tiny crack at the corner of the forward hatch. It caused a strip of the
interior overhead fiberglass to delaminate from the forward hatch to the
main hatch. It happened right at the end of the season, so I cut out
the delaminated glass to let the plywood core dry over the winter. The
boat sailed perfectly well without the strip of fiberglass on the
overhead, so I made myself promises about attending to it one of these
days quite soon. Well, fall came again, and still no repair. Then I got
a tour of a local Tripp 26 when the owner helped me get my winter
mooring marker in place. His son was very proud of a core replacement
job he had done on the overhead of that boat. That made me a bit
embarrassed about not attending to mine, so I formed a plan and turned
it into a multi-evening project in steps.
As we all know, gravity is not your friend when working with epoxy goo
and fiberglass overhead. I used large boards with compressible foam on
the and with plastic sheets over that, propped up from below. It worked
pretty well. The surface will need some fairing, then I'll varnish over
it with some dull or low-gloss varnish so it matches the rest of the
overhead. Maybe I'll do all the clear-finished overhead with the
varnish. But that's a chore for next spring, likely, unless our weather
takes a sudden turn for the better or my other fall chores disappear.
The last fall chore was securing my new Brummel hook to the spinnaker
head. You may recall that I had asked if anybody had the second half
of a small Brummel hook. Our listmate Drew mailed me one, but the USPS
sorting machine apparently squeezed it out of the envelope. Well, last
weekend I stopped at a "garage sale" sign that said "boat stuff." There
wasn't much boat stuff but there was a small Brummel hook half @ $0.75.
I splurged. Wow, it fits! I seized it onto the spinnaker using some
polyester "waxed lacing thread" on a big spool. Now I'm ready for
downwind work next season.
