3 messages2015-10-19 21:17 UTCthrough 2015-10-20 20:11 UTC
Dock Lines
david dobbs2015-10-19 21:17 UTC
Went to the yard today to start getting the CAL ready for winter, pumped the bilge, topped off the gas tank, did some other odds and ends, brought the dock lines home because I wanted to see how they were. The answer is damaged, and they were new this year. That 5 day NE gale really took it's toll. They are all seriously abraded, and unfit for service next year, but they held. Three strand from West, but I think I will replace them with Sampson from Defender Marine.David Dobbs CAL29 411
Re: [Cal_Boats] Dock Lines
ccampbell2015-10-20 14:20 UTC
The failure mode on nylon lines tends to be via internal friction and
heating when they are repeatedly stressed. The stretching that we
prize in nylon creates internal movement of the fibers and internal
wear. They'll be stressed more at points where they turn, as in a
chock. Years ago there was a huge gale when our local schooner was
moored in a less-protected location than she enjoys now. We eventually
organized hourly boat watches and started cutting up the big anchor rode
to make replacement dock lines. They kept wearing out.
Nylon's big advantage--stretching to minimize abrupt forces on the
boat--is also a disadvantage because it leads to the internal friction.
There's always a balance to be struck between oversized lines, which
don't stretch much and put more force on the boat's cleats and bitts,
and smaller ones, which do stretch more but pay the price in wear.
I had a small-boat mooring buoy out in the Saginaw Bay over on the Lake
Huron side. I had secured it with some small nylon line around a
thimble, then via shackle to a chain. It gave out in that big NE
storm. Happily, a shoreline neighbor saw it floating down the shore
shortly after it let loose and snagged it for me with a boat hook. That
saved me a trip out in the aluminum boat to remove the ball for the
winter. I had checked the line a couple weeks earlier and it looked
fine. In Bay City, there were NE winds for about 8 days. That's
unusual. The standard NE blow is three days.
The same storm also flipped the aluminum pram, a 13' boat, up and over a
concrete sea wall section about 2-1/2' higher than the concrete pad the
boat sits on, inverted. That was a first.
RE: [Cal_Boats] Dock Lines
Michael Robinson2015-10-20 20:11 UTC
I just switched from 3 strand (I think WM is a cheap 3 strand) to Mega Braid by New England rope. Pam Wall http://www.pamwall.com/ spoke very highly about it in her seminar at last year's Stickily Sail Boat Show in Oakland. She says long lasting, stays supple/flexible and easy to coil, does not kink, and very good abrasion resistance. So far it is living up to her description!
Mike RobinsonS/V Eleanor May(916) 705-3200 our blog:http://www.sailblogs.com/member/eleanormay/
Date: Mon, 19 Oct 2015 21:17:29 +0000
Subject: [Cal_Boats] Dock Lines
