3 messages2015-11-20 17:38 UTCthrough 2015-11-21 21:51 UTC
Re: RE: [Cal_Boats] Spreader tip boots - I like Taylor.
TomD2015-11-20 17:38 UTC
I'm inclined to think that moisture gets anywhere..EVERYWHERE on a sailboat.
Even the snap-wrapped, cloth boots will get wet, I would think.
Do they really drain/dry completely?
I'm asking questions because on my newly acquired 2-25 (25-2?) , the spreader has some tape and I want to rectify that.
I'm re-sealing all deck hardware, chainplates, sheet tracks...might as well climb and do spreader tips also!
thanks.
..tom
On 11/20/15, r good my… [at] hotmail.com [Cal_Boats]<Ca… [at] yahoogroups.com> wrote:
I would be reluctant to use this taping method. Moisture that gets in would be semi-trapped in there.
reggie
Date: Thu, 19 Nov 2015 17:32:07 -0800
Subject: Re: [Cal_Boats] Spreader tip boots - I like Taylor.
I used to use vinyl tape but it gets torn up as you can see in this picture. Last season I used million dollar tape and it does pretty well. It is very slippery being teflon and all. Here is a picture of my spreader. I don't know how this spreader compares to others so don't know if it would be harder or easier on a sail and if the Taylor Made cover would fit.
On Thu, Nov 19, 2015 at 5:07 PM, 'Timm Lessley' ti… [at] gmail.com [Cal_Boats] < Ca… [at] yahoogroups.com > wrote:
Hi Allen,
The Taylor Made covers are available for viewing at WM.
The cover is like a heavy “cotton / polyester” ribbed canvas, that looks a bit like fire hose cover material. The end is padded with a foam like material.
This review was on Amazon
These are the industry standard. They last 8 to 10 years, you can clean them with a spray cleaner with a little bleach in it, but bleach will eat them. These provide a lot of protection for your head sails that overlap the mast/spreaders. The other option is white rubber covers made of the same material as fenders. The plastic ones don't last as long as the Taylor made products, and the plastic ones do not provide as much protection for your sails. Finally, the web strap that holds these on is better than zip ties used on the rubber ends. The rubber ends look sleek and shiny. The other option is to tape under the covers. Just make sure water can drain from under the tape to minimize galvanic action. The tape will protect your sails in the unlikely event a spreader end get ripped off.
From: Ca… [at] yahoogroups.com [mailto: Ca… [at] yahoogroups.com ]
Sent: Thursday, November 19, 2015 9:57 AM
@Timm, What are those maxi pads made of? My spreader is wood and I doubt the oval one will fit so was wondering about making one. But what is the raw material?
On Tue, Nov 17, 2015 at 10:57 AM, 'Timm Lessley' ti… [at] danishmarineco.com [Cal_Boats] < Ca… [at] yahoogroups.com > wrote:
Yep’m – for me the cloth tips perform as I want for the reasons stated.
Sent: Tuesday, November 17, 2015 10:55 AM
Subject: RE: [Cal_Boats] Spreader tip boots - I like Taylor.
Timm,
I got lost in your recommendation, are you recommeding the maxi pads?
I read somewhere back not to use rollers on the spreader tips for some reason or another. They said to use leather tips.
I am replacing rubber boots.
Thanks again for your valuable input.
Randy
Cal 2 29
Out Patient
Channel Islands Ca
Sent on a Sprint Samsung Galaxy Note® 3
From: "'Timm Lessley' ti… [at] danishmarineco.com [Cal_Boats]" < Ca… [at] yahoogroups.com >
Date: 11/05/2015 5:55 PM (GMT-08:00)
We only use the Harken rollers on lifeline stanchions, never thought about on a spreader.
They help the sail during a tack to get inside the rail for a hard upwind grind.
If you were to fall on a stanchion, maybe they would also prevent a puncture to your rib cage.
If installing before you step the mast You will need to understand well the spreader angle under tension so the install will not prevent proper spreader function.
I don’t think I would use these on spreader tips on our discontinuous rig, as I do not think they would protect our film sails very well from the spreader tips.
I prefer the cloth padded “maxi pad style” as
· the film sails do not stick to it like rubber or other materials,
· they breath well, and let rain water wash the salt from the tips.
· I don’t trust the buckle and add a bit of red or green electrical tape, depending on the proper side.
· They only last @ 3years, which reminds me to clean the salt from the tip before the monel, stainless and aluminum fist fight concludes poorly.
· and apply a fresh coating of TefGel as a referee for the next three years.
· The big surface keeps the spreader tip from punching a $9,000 genoa in the belly button.
· 2008, our brand new Quantum Carbon Fiber 155% had the leech ripped off by a rubber tip during the test sail first tack…
· (see $9k sail aforementioned.)
Kind regards,
(¸.·´ (¸.·' ( ......….- _ /)
dEmO
From: Ca… [at] yahoogroups.com [ mailto:Ca… [at] yahoogroups.com ]
Sent: Thursday, November 05, 2015 11:28 AM
David,
We use the Harken Sail Chafe Protectors on Magic. They work well and have help up pretty good for the past three years.
Michael
From: "david howe tr… [at] yahoo.com [Cal_Boats]" < Ca… [at] yahoogroups.com >
To: yahoogroups < ca… [at] yahoogroups.com >
Sent: Thursday, November 5, 2015 2:09 PM
Subject: [Cal_Boats] Spreader tip boots
So I'm just about decided to use leather boots on the spreader tips and then I read about using the Harken Sail Chafe Protectors. Anyone have any experience with these?
I'm making new spreaders so it might be easier to install these while the mast is down and also cheaper.
Sent from Yahoo Mail for iPhone
RE: RE: [Cal_Boats] Spreader tip boots - I like Taylor.
Timm Lessley2015-11-21 00:20 UTC
You are right, water will go anywhere and trapping it will ruin any metal. The cloth imho lets the water migrate – which I think is a good thing.
Sent: Friday, November 20, 2015 9:39 AM
Subject: Re: RE: [Cal_Boats] Spreader tip boots - I like Taylor.
thanks.
..tom
On 11/20/15, r good my… [at] hotmail.com <mailto:my… [at] hotmail.com> [Cal_Boats]<Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
reggie
From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
On Thu, Nov 19, 2015 at 5:07 PM, 'Timm Lessley' ti… [at] gmail.com <mailto:ti… [at] gmail.com> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
Hi Allen,
From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> ]
On Tue, Nov 17, 2015 at 10:57 AM, 'Timm Lessley' ti… [at] danishmarineco.com <mailto:ti… [at] danishmarineco.com> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
Timm,
Randy
Cal 2 29
Out Patient
Channel Islands Ca
From: "'Timm Lessley' ti… [at] danishmarineco.com <mailto:ti… [at] danishmarineco.com> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> >
* the film sails do not stick to it like rubber or other materials,
* they breath well, and let rain water wash the salt from the tips.
* I don’t trust the buckle and add a bit of red or green electrical tape, depending on the proper side.
* They only last @ 3years, which reminds me to clean the salt from the tip before the monel, stainless and aluminum fist fight concludes poorly.
* and apply a fresh coating of TefGel as a referee for the next three years.
* The big surface keeps the spreader tip from punching a $9,000 genoa in the belly button.
* 2008, our brand new Quantum Carbon Fiber 155% had the leech ripped off by a rubber tip during the test sail first tack…
* (see $9k sail aforementioned.)
Kind regards,
(¸.·´ (¸.·' ( ......….-_/)
dEmO
From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com]
David,
Michael
From: "david howe tr… [at] yahoo.com <mailto:tr… [at] yahoo.com> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> >
To: yahoogroups <ca… [at] yahoogroups.com <mailto:ca… [at] yahoogroups.com> >
Sent from Yahoo Mail for iPhone <https://yho.com/footer0>
Allen Edwards2015-11-21 21:51 UTC
It didn't seem to hurt anything. The metal strap is either stainless steel
or bronze but more importantly it didn't hurt the wood. I would be more
worried about the cloth holding in water so it needs to be something that
won't hold water.
On Fri, Nov 20, 2015 at 4:20 PM, 'Timm Lessley' ti… [at] danishmarineco.com
> *Sent:* Friday, November 20, 2015 9:39 AM
> *Subject:* Re: RE: [Cal_Boats] Spreader tip boots - I like Taylor.
> sailboat.
> thanks.
> ..tom
> reggie
> would fit.
> [image: Inline image 1]
> Hi Allen,
> material.
> *Sent:* Thursday, November 19, 2015 9:57 AM
> *Subject:* Re: [Cal_Boats] Spreader tip boots - I like Taylor.
> raw material?
> Allen
> *Sent:* Tuesday, November 17, 2015 10:55 AM
> *Subject:* RE: [Cal_Boats] Spreader tip boots - I like Taylor.
> Timm,
> Randy
> Cal 2 29
> Out Patient
> Channel Islands Ca
> on a spreader.
> grind.
> spreader function.
> spreader tips.
> materials,
> tips.
> poorly.
> three years.
> Kind regards,
> (¸.·´ (¸.·' ( ......….-*_/)*
> dEmO
> <Ca… [at] yahoogroups.com>]
> *Sent:* Thursday, November 05, 2015 11:28 AM
> David,
> Michael
> *From:* "david howe tr… [at] yahoo.com [Cal_Boats]" <
> *To:* yahoogroups <ca… [at] yahoogroups.com>
> *Sent:* Thursday, November 5, 2015 2:09 PM
> *Subject:* [Cal_Boats] Spreader tip boots
