8 messages2015-12-29 17:46 UTCthrough 2015-12-30 04:41 UTC
saga begins...again
r good2015-12-29 17:46 UTC
Leaving Saturday, weather dependent, form snowy Montana to Port charlotte, Florida by way of El Paso, Texas. Since we are riding/driving and towing a Dana 24, we were hoping to be out of snow quickly. However, My son's yard in El Paso had snow drifts in it last Sunday, so we are not holding out much hope for warmth until Florida.
SV "Submit", Cal cruising 36, will get anew rudder and other upgrades then be launched for a cruise down the rest of the west coast of Florida, up through the keys and off to the Bahamas, buddiy boating at least part of the time with the Dana "Gust-O". Back home late April or early May?
As mentioned before, we do occasional write-ups about our "experiences" and then send out an email notice to those who want to know that a new one has been posted in our blog so they can go see it if they wish. Let us know if you want to be added to the notice list or wish to be removed.
Installations prior to being launched will/should include, in addition to the rudder, a 100w solar system, a rigid vang
and a new wheel pilot. Really looking forward to seeing the old girl again. this 47 year old boat provides us with lots of entertainment1
Reggie and Barbara
Re: [Cal_Boats] saga begins...again
Helen Horn2015-12-29 19:14 UTC
Yes, Reggie and Barbara, please keep us in the loop. New rudder was a real plus for Caliente. Electrolysis is hard on the post as there is nowhere to put a zinc except hang one overboard with a clip on the collar bolts. And if you get a foss you may have to shape the top forward edge and reseal. (The shape we got was for the 40 and there is a slope difference between post and keel.) I forgot, is this your first replacement? Helen
On Tue, Dec 29, 2015 at 9:46 AM, r good my… [at] hotmail.com [Cal_Boats]<Ca… [at] yahoogroups.com> wrote:
Reggie and Barbara
RE: [Cal_Boats] saga begins...again
Michael Robinson2015-12-29 19:27 UTC
Reggie and Barbara,
Yes please keep us in the loop.
Mike & Diane RobinsonS/V Eleanor May(916) 705-3200 our blog:http://www.sailblogs.com/member/eleanormay/
To: ca… [at] yahoogroups.com
Date: Tue, 29 Dec 2015 10:46:32 -0700
Subject: [Cal_Boats] saga begins...again
Reggie and Barbara
pw… [at] aol.com2015-12-29 20:06 UTC
Reggie - please add me to your list of stalkers ;-)
Paul West
pwestla at aol dot com
From: r good my… [at] hotmail.com [Cal_Boats] <Ca… [at] yahoogroups.com>
To: cal_boats <ca… [at] yahoogroups.com>
Sent: Tue, Dec 29, 2015 12:46 pm
< BR>Installations prior to being launched will/should include, in addition to the rudder, a 100w solar system, a rigid vang
Reggie and Barbara
Craig Johnson2015-12-29 20:34 UTC
Reggie, Please add me as well!
Craig Johnson
Date: Tue, 29 Dec 2015 15:06:53 -0500
Subject: Re: [Cal_Boats] saga begins...again
Paul West
Reggie and Barbara
Walter March2015-12-29 20:41 UTC
blockquote, div.yahoo_quoted { margin-left: 0 !important; border-left:1px #715FFA solid !important; padding-left:1ex !important; background-color:white !important; } Me too, please
Sent from Yahoo Mail for iPhone
On Tuesday, December 29, 2015, 3:34 PM, Craig Johnson cr… [at] hotmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
Craig Johnson
Paul Westpwestla at aol dot com
Reggie and Barbara
new rudder
r good2015-12-29 22:48 UTC
Yes, this is our first replacement. The current rudder had electrolysis damage where the stock meets the rudder, and it had been repaired by grinding out then welding to fill and grinding down. I was nervous about the tensile strength changes from the grinding, welding and grinding. I did not want it to snap off in a storm. Also, the rudder blade had previous salt water intrusion and I was worried about corrosion at the internal welds. there are enough things to worry about when things go bad around a sailboat without having to worry about things you can fix.
I also just ordered a new rudder for my Cal 27 T/2.
I'm really hoping the rudder I am sent is correct for my Cal Cruising 36 sailboat. I'm not set up to modify it properly.
Date: Tue, 29 Dec 2015 19:14:43 +0000
Subject: Re: [Cal_Boats] saga begins...again [1 Attachment]
[Attachment(s) from Helen Horn included below]
Leaving Saturday, weather dependent, form snowy Montana to Port charlotte, Florida by way of El Paso, Texas. Since we are riding/driving and towing a Dana 24, we were hoping to be out of snow quickly. However, My son's yard in El Paso had snow drifts in it last Sunday, so we are not holding out much hope for warmth until Florida. SV "Submit", Cal cruising 36, will get anew rudder and other upgrades then be launched for a cruise down the rest of the west coast of Florida, up through the keys and off to the Bahamas, buddiy boating at least part of the time with the Dana "Gust-O". Back home late April or early May? As mentioned before, we do occasional write-ups about our "experiences" and then send out an email notice to those who want to know that a new one has been posted in our blog so they can go see it if they wish. Let us know if you want to be added to the notice list or wish to be removed. Installations prior to being launched will/should include, in addition to the rudder, a 100w solar system, a rigid vang and a new wheel pilot. Really looking forward to seeing the old girl again. this 47 year old boat provides us with lots of entertainment1 Reggie and Barbara
Re: [Cal_Boats] new rudder
Helen Horn2015-12-30 04:41 UTC
It's not hard just annoying. We conferred with foss, as to why and how. You treat it like a surfboard; match the pitch of the hull (in our case it wouldn't go all the way in. )So, we took a straight edge , drew a line parallel to hull,it was about 1/2 in. or so down on leading edge, up to just before stock. I sawed with my Japanese fine tooth flat saw. Then I put west epoxy on, then layered two skins of cloth on, sanding between and cleaning each time, feathering into original.Then, as I usually do, I painted entire rudder with 2000E. Followed with bottom paint. It was unexpected, and took almost a week. The yard was annoyed as we had to be jacked up extra high. At least it could be warm. We also put heavy marine grease in tube when inserting, and used a bearing/bushing ring. Ours is a shoemaker design, made by so cal foss co. It's almost as deep as the keel. Elliptical. Helen
On Tue, Dec 29, 2015 at 2:48 PM, r good my… [at] hotmail.com [Cal_Boats]<Ca… [at] yahoogroups.com> wrote:
[Attachment(s) from Helen Horn included below] Yes, Reggie and Barbara, please keep us in the loop. New rudder was a real plus for Caliente. Electrolysis is hard on the post as there is nowhere to put a zinc except hang one overboard with a clip on the collar bolts. And if you get a foss you may have to shape the top forward edge and reseal. (The shape we got was for the 40 and there is a slope difference between post and keel.) I forgot, is this your first replacement? Helen
Reggie and Barbara
