11 messages2016-01-29 04:43 UTCthrough 2016-01-29 19:37 UTC
Replacement portals for 1974 CAL 2-25
Shauna's Gmail2016-01-29 04:43 UTC
We need to replace the portals on our CAL 2-25 MystiCAL. They are attached directly to the boat with no frame.
Does anyone know of a good source for replacements?
Best Regards,
Shauna L. Welch
MystiCAL 25
Cleveland, Ohio
Re: [Cal_Boats] Replacement portals for 1974 CAL 2-25
TomDressler2016-01-29 04:58 UTC
I would like to see a pic of that.
Mine are stuck on from the outside with some screwed on decorative frame on the inside. The frame appears to be barely structural, but i guess the provide some clamping force.
..tom
Resa CAL 2-25
Monterey
> On Jan 28, 2016, at 8:43 PM, Shauna's Gmail sm… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Best Regards,
> Shauna L. Welch
> MystiCAL 25
> Cleveland, Ohio
Helen Horn2016-01-29 07:03 UTC
Mark Plastics Southern California. He will return your call and is very helpful. Helen
On Thu, Jan 28, 2016 at 8:43 PM, Shauna's Gmail sm… [at] gmail.com [Cal_Boats]<Ca… [at] yahoogroups.com> wrote:
Best Regards,
Shauna L. Welch
MystiCAL 25
Cleveland, Ohio
Shauna's Gmail2016-01-29 11:13 UTC
Unfortunately, she is shrink wrapped right now. The plexiglass is held on to the boat by a bead of caulk and a dozen or more nuts and bolts. No frames at all.
Best Regards,
Shauna L. Welch
Cell: 440.305.1340
Email: sm… [at] gmail.com
> On Jan 28, 2016, at 11:58 PM, TomDressler tb… [at] verizon.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> ..tom
> Resa CAL 2-25
> Monterey
>> Best Regards,
>> Shauna L. Welch
>> MystiCAL 25
>> Cleveland, Ohio
RE: [Cal_Boats] Replacement portals for 1974 CAL 2-25
Charlie Husar2016-01-29 13:28 UTC
Hi, Shauna. The through-bolted arrangement on your 2-25 ports does not
sound like original equipment. (I could be wrong.) A call to Mark Heacox
at number below will tell you. Go Windows made the original ports for many
Cal types back in the days when they actually called them windows.
MARK PLASTICS - GO WINDOWS
369 E. Harrison, #G, Corona, CA 92879
Tel: (951) 735-7705
Annapolis
CAL 25 (the flat-deck variety)
Sent: Thursday, January 28, 2016 11:44 PM
To: ca… [at] yahoogroups.com
Subject: [Cal_Boats] Replacement portals for 1974 CAL 2-25
Best Regards,
Shauna L. Welch
MystiCAL 25
Cleveland, Ohio
Posted by: Shauna's Gmail <sm… [at] gmail.com>
Yahoo Groups Links
TomDressler2016-01-29 17:04 UTC
Shauna,
While removing and re-sealing mine, I observed that they are simply “plastic clear things put into a hole randomly carved into the boat.”
Look at the opening. It looks like it was hand carved with a coping saw.
So, any port should fit…approximately.
Contact Jeff at this place also.. http://www.nandjmarine.com/
Tom
Resa Cal 2-25
Monterey, CA
Sent: Friday, January 29, 2016 3:14 AM
Subject: Re: [Cal_Boats] Replacement portals for 1974 CAL 2-25
Best Regards,
Shauna L. Welch
Cell: 440.305.1340
..tom
Resa CAL 2-25
Monterey
Best Regards,
Shauna L. Welch
MystiCAL 25
Cleveland, Ohio
https://www.avast.com/antivirus
Charlie Husar2016-01-29 17:21 UTC
Shauna, another thing to look at. I’m pretty sure that Cal 2-25s were not built until 1976/1977. Look on the upper part of the exterior starboard stern. That HIN code tells the date of manufacture.
Take Care
Annapolis
CAL 25
Sent: Friday, January 29, 2016 12:05 PM
Subject: RE: [Cal_Boats] Replacement portals for 1974 CAL 2-25
upper
Shauna,
Tom
Resa Cal 2-25
Monterey, CA
Best Regards,
Shauna L. Welch
Cell: 440.305.1340
Email: sm… [at] gmail.com <mailto:sm… [at] gmail.com>
On Jan 28, 2016, at 11:58 PM, TomDressler tb… [at] verizon.net <mailto:tb… [at] verizon.net> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
..tom
Resa CAL 2-25
Monterey
On Jan 28, 2016, at 8:43 PM, Shauna's Gmail sm… [at] gmail.com <mailto:sm… [at] gmail.com> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
Best Regards,
Shauna L. Welch
MystiCAL 25
Cleveland, Ohio
<https://www.avast.com/antivirus>
www.avast.com <https://www.avast.com/antivirus>
Mike's Yahoo2016-01-29 17:30 UTC
I agree with Charlie. The original fixed ports in the salon can be replaced with the same size ports through Marks Plastics. I've looked into this but haven't pulled the trigger yet.
The original (forward) opening ports were Beckson 512's, which can be replaced with the same or as I did with Tri-matrix something or other by NewFound Metals.
It is also possible to jury-rig a fixed port by using cut acrylic sheets, that are either through bolted or affixed by 2-sided tape to the outside of the boat. The second of these alternate methods is explained by Don Casey in articles in Boat US and Sail Magazine. He explains the process of cutting, painting (for the flange overlap, for appearance) the acrylite or whatever type sheet you use and the specific type of 3-M 2-sided tape as well as the process of filling the void with Dow 795. You may find this process to be better than purchasing new ones. Alternatively, you
may find the cost of materials and/or tools necessary to complete the job to be at or close to the port replacement cost.
I disagree with a prior statement that any port will do. A search on the web reveals that the fixed ports in question are not a standard size (if I recall they are approximate 42" long and are slightly curved to match the hull) and not easily replaced with an off the rack port. As such, I think you would be hard-pressed to find a production port (e.g Lewmar, Beckson) that would fit.
Please let me know if you reach out to Marks and if it would be cheaper if you and I ordered at the same time.
I hope this helps.
Best,
Mike Casillo
Annapolis
Invincible Summer, Cal 2-25
> On Jan 29, 2016, at 12:04 PM, 'TomDressler' tb… [at] verizon.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Shauna,
> Tom
> Resa Cal 2-25
> Monterey, CA
> Best Regards,
> Shauna L. Welch
> Cell: 440.305.1340
> ..tom
> Resa CAL 2-25
> Monterey
> Best Regards,
> Shauna L. Welch
> MystiCAL 25
> Cleveland, Ohio
> www.avast.com
TomDressler2016-01-29 17:45 UTC
Hi Mike,
Thanks for the added info.
I’m a NEW owner and that was my comment.
I was pointing out what I observed.
The portal cutouts were not at all ‘perfect’ and from disassembly, I simply inferred that I could fit another of similar size. Thankfully, I don’t need to…YET.
It looks like some 14 y.o. got in there with a drywall saw and started cutting.
Thank you for adding more clarification.
I am here to learn from those with more experience.
..tom
Sent: Friday, January 29, 2016 9:31 AM
I hope this helps.
Best,
Mike Casillo
Annapolis
Shauna,
Tom
Resa Cal 2-25
Monterey, CA
Best Regards,
Shauna L. Welch
Cell: 440.305.1340
..tom
Resa CAL 2-25
Monterey
Best Regards,
Shauna L. Welch
MystiCAL 25
Cleveland, Ohio
<https://www.avast.com/antivirus> Avast logo
Shauna's Gmail2016-01-29 18:34 UTC
Yes, MystiCAL is 1976. I was mistaken. Our windows do look like primitively cut holes. Lol
Best Regards,
Shauna L. Welch
Cell: 440.305.1340
> On Jan 29, 2016, at 12:45 PM, 'TomDressler' tb… [at] verizon.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Hi Mike,
> ..tom
> I hope this helps.
> Best,
> Mike Casillo
> Annapolis
> Shauna,
> Tom
> Resa Cal 2-25
> Monterey, CA
> Best Regards,
> Shauna L. Welch
> Cell: 440.305.1340
> ..tom
> Resa CAL 2-25
> Monterey
> Best Regards,
> Shauna L. Welch
> MystiCAL 25
> Cleveland, Ohio
> www.avast.com
> www.avast.com
Charlie Husar2016-01-29 19:37 UTC
As would be usual in the trade, the cut-outs were more haphazard on Mondays and Fridays than the rest of the week. That’s one reason most of the ports had external frames.
Annapolis
Sent: Friday, January 29, 2016 1:35 PM
Best Regards,
Shauna L. Welch
Cell: 440.305.1340
On Jan 29, 2016, at 12:45 PM, 'TomDressler' tb… [at] verizon.net <mailto:tb… [at] verizon.net> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
Hi Mike,
..tom
From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com]
I hope this helps.
Best,
Mike Casillo
Annapolis
On Jan 29, 2016, at 12:04 PM, 'TomDressler' tb… [at] verizon.net <mailto:tb… [at] verizon.net> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
Shauna,
Tom
Resa Cal 2-25
Monterey, CA
Best Regards,
Shauna L. Welch
Cell: 440.305.1340
..tom
Resa CAL 2-25
Monterey
Best Regards,
Shauna L. Welch
MystiCAL 25
Cleveland, Ohio
