4 messages2016-02-10 15:20 UTCthrough 2016-02-10 16:01 UTC
Was Waterlogged rudder, etc. - Now Ethanol Gas
Charlie Husar2016-02-10 15:20 UTC
As someone else mentioned, I always run the outboard dry when back to the dock. Seems to work well. Mine is a Tohatsu 6 LS one banger on the CAL 25.
Take Care
Annapolis
Sent: Wednesday, February 10, 2016 9:55 AM
Subject: Re: [Cal_Boats] Waterlogged rudder, etc.
On 2/9/2016 5:44 PM, 'sailor7312 .' sa… [at] gmail.com <mailto:sa… [at] gmail.com> [Cal_Boats] wrote:
BTW, nice choice on the 9.9 high trust. I did the same thing on my cal 29, took out the old engine and put a 9.9 HT on it.
Love it!! One thing I will say about the 9.9 is it is pretty sensitive to ethanol. My carb clogged after a year of intermittent use.
If you are near a place where you can buy fuel w/o ethanol, I would. If not, I would add the fuel stabilizers that are available out there.
I also find mine really likes it if after I get to the slip, I disconnect the fuel line and run the fuel out of it.
I'll second this. My marina's gas was very pricey so I kept hauling gas-station gas to the boat. And the outboards kept complaining. Then I learned that the marina's gas is recreation gas, alcohol-free gas, and I started using it for my outboards and for my lawn mowers. All the little engines are MUCH happier. On one outboard the gas pick-up tube had actually rusted through where the alcohol had absorbed moisture from the air and separated out. Ethanol is just another way to spell evil.
Re: [Cal_Boats] Was Waterlogged rudder, etc. - Now Ethanol Gas
pw… [at] aol.com2016-02-10 15:30 UTC
Charlie - Is this with ethanol and a detachable tank that you can close the vent to?
Paul
From: 'Charlie Husar' hu… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com>
Sent: Wed, Feb 10, 2016 10:21 am
Subject: [Cal_Boats] Was Waterlogged rudder, etc. - Now Ethanol Gas
Take Care
Annapolis
RE: [Cal_Boats] Was Waterlogged rudder, etc. - Now Ethanol Gas
Charlie Husar2016-02-10 15:54 UTC
Affirmative on all counts, Paul. I also detach the fuel hose at both ends.
Take Care
Annapolis
CAL 25
Sent: Wednesday, February 10, 2016 10:30 AM
To: Ca… [at] yahoogroups.com; hu… [at] gmail.com
Subject: Re: [Cal_Boats] Was Waterlogged rudder, etc. - Now Ethanol Gas
Paul
Take Care
Annapolis
From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com?> ]
TomDressler2016-02-10 16:01 UTC
Fuel-related..not sailing though.
Years ago, I had a powerboat off of Huntington Beach, CA.
I trailered it and ran back and forth to Catalina.
I would stop and fill up at local stations.
The outboard seized once and a mechanic mentioned the same thing about crap fuel at the street pumps.
It’s a recipe for failure and the money you save is spent in a rebuild.
He was right.
..tom
Sent: Wednesday, February 10, 2016 7:54 AM
To: pw… [at] aol.com; Ca… [at] yahoogroups.com
Subject: RE: [Cal_Boats] Was Waterlogged rudder, etc. - Now Ethanol Gas
Take Care
Annapolis
CAL 25
Paul
Take Care
Annapolis
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com?> ]
https://www.avast.com/antivirus
