Re: Cal 35 Mast Partners
The purpose of the "ears" as you describe them is to transfer the lift on the deck caused by halyard turning blocks mounted to the top of the mast collar or in its vicinity. These blocks can pull up on the deck w/ considerable force. The "ears" clamp the deck collar to the mast so the net force on the whole structure is zero.
Now, why are they misaligned?
Sometimes, when the mast is pulled for service, the heal is so corroded, that some of it has to be cut off. Unless the mast step is built up an equivalent amount, the mast would drop in relation to the deck after such a repair and result in this misalignment.
An alternate explanation is the deck has been "lifted" by the continual pull of the turning blocks. (I think less likely)
BTW parts for your rig are available from RigRite:
http://www.rigrite.com/spars/kenyon_spars/KENYON.html
Jeff Thayer
S/V Ecco
Cal 39 Mk2 #115
San Francisco, Ca
CONFIDENTIAL COMMUNICATION -- The information in this e-mail (including any attachments) is confidential and proprietary to PRYSM, INC. and intended only for the sole use of the intended recipient. If you have received this communication in error, then any review, dissemination, distribution, or copying of this message is strictly prohibited, and please permanently delete this message (including any copies of this e-mail and any attachments thereto) and notify us immediately by return e-mail.
