12 messages2006-09-11 18:24 UTCthrough 2016-02-17 15:10 UTC
Boot Stripe Paint
Husar Charlie2006-09-11 18:24 UTC
Hi, All. In previous discussions, I remember that salt or brackish
water attacks some paints used on boot stripes. I was wondering what
the best stuff is to use for the purpose.
Many Thanks
Annapolis
RE: [Cal_Boats] Boot Stripe Paint
Ben Koche2006-09-11 20:14 UTC
Either Interlux Brightsides or Toplac will work well
Of Husar Charlie
Sent: Monday, September 11, 2006 2:24 PM
Subject: [Cal_Boats] Boot Stripe Paint
Many Thanks
Annapolis
Re: [Cal_Boats] Boot Stripe Paint
Terrence Spencer2006-09-12 00:52 UTC
Interlux recommends their Brightside product. I will tell you in a few
years how it held up.
Terry Spencer
Cal 2-29
Capriccio
Tacoma
Reply-To: Ca… [at] yahoogroups.com
Date: Mon, 11 Sep 2006 14:24:14 -0400
Many Thanks
Annapolis
Skipper2006-09-12 01:15 UTC
Mine has held up beautifully for 4 years so far. Maybe on a long tack
(Hawaii?) it might not like to be continually immersed. I know Awlgrip
doesn't.
David Wilkie Owen
Cal 2-29 "Mariposa"
Santa Barbara, CA
http://www.mariposasailing.com
Sent: Monday, September 11, 2006 5:52 PM
Subject: Re: [Cal_Boats] Boot Stripe Paint
> Terry Spencer
> Cal 2-29
> Capriccio
> Tacoma
> From: "Husar Charlie" <hu… [at] bah.com>
> Many Thanks
> Charlie
> Annapolis
Boot Stripe Paint
Mike's Yahoo2016-02-14 13:34 UTC
Hey All-
My Cal 2-25 has a burgundy (I think it was marketed at the time as Chinese Red) boot stripe, consisting of a an approximate 1" stripe below a stripe of varying thickness from about 4" - 7" and mirror image striping at the waterline. The red is looking its age, and I'm considering options for a new paint job or vinyl stripe.
I think vinyl for the larger stripe is not a good option because the width would make it expensive and difficult to apply. As for paint, there are several options, such as Interlux Brightside, which is also marketed in smaller quantities as boot stripe paint, there is also Pettit and Interlux 1 and 2 part polyurethane. My boat yard uses Awlgrip, which from I understand is pro-use only. This is a DYI project, possibly done at the dock on a still day. This approach is prompted in part by the 2 boat buck quote from my boat yard.
I'm thinking others have faced this issue before, so your insights are welcome. My specific questions are have any of you all re-painted or applied a vinyl stripe to update the look on your boats, if so would you recommend the product used, is primer necessary, if you think it could be done at the dock, and any tips on the application. Thanks in advance.
Best,
Mike Casillo
Invincible Summer, Cal 2-25
Annapollis
Ted Wrobel2016-02-14 14:00 UTC
About 15 years ago I faced the same problem on a Catalina 27. First painted it with Brightside (forest green). Lasted about two years! Then went with 3 inch vinyl tape. Lasted years, only problem was a few tears from contact with hard objects!
Ted
1988 Cal 33 Celebration
Sent: Sunday, February 14, 2016 8:34 AM
To: Cal List Serve <ca… [at] yahoogroups.com>
Hey All-
Best,
Mike Casillo
Annapollis
No virus found in this message.
Checked by AVG - www.avg.com <http://www.avg.com>
Version: 2015.0.6189 / Virus Database: 4522/11602 - Release Date: 02/11/16
Terry Spencer2016-02-14 19:17 UTC
The Brightside, Forest Green, still looks pretty good on my boat after 8 years except for a few minor scratches.
Terry
Cal 2-29
Capriccio
Tacoma
> On Feb 14, 2016, at 6:00 AM, 'Ted Wrobel' tw… [at] tacticaltech.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Ted
> From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>]
> To: Cal List Serve <ca… [at] yahoogroups.com <mailto:ca… [at] yahoogroups.com>>
> Hey All-
> Best,
> Mike Casillo
> Annapollis
> < span style="font-size:12.0pt;">
> Checked by AVG - www.avg.com <http://www.avg.com/>
Re: Boot Stripe Paint
ca… [at] hotmail.com2016-02-15 13:48 UTC
My Cal 28-II had the same Chinese red. Drove me crazy. I used the Brightsides paint, but here is the difference: I carefully prepped the surface. Wax and gunk gets in the pores of the gelcoat and the surface appears clean, but it isn't. Wash it down with a 3M scouring pad and TSP. Rinse and scrub again with clear water. Allow to dry. Then swab it down with Interlux solvent 333 using an old rag. You'll need several. Lot'sa stuff will appear on the rag. Also, wear gloves, that stuff will dissolve fingers, I think.... Mask it off with the green tape, or better yet, the black tape that you can get at a professional paint store. Be sure to run your finger over the tape carefully to be sure it doesn't blotch under the tape.
Re: [Cal_Boats] Re: Boot Stripe Paint
Mike's Yahoo2016-02-16 14:22 UTC
Thanks Carl! It sounds like a bigger job than I originally thought. A few follow-up questions:
-are you happy with the results?
-do you have a pic?
-knowing what it entails, would you recommend painting (instead of vinyl tape)?
Best,
Mike Casillo
> On Feb 15, 2016, at 8:48 AM, ca… [at] hotmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
RE: [Cal_Boats] Re: Boot Stripe Paint
Charlie Husar2016-02-16 19:45 UTC
Hi, All. Even if you do not wax your hull, and you have the original gelcoat, there is wax left over from the mold release still embedded in that gelcoat. As Carl indicates, prep is everything. I have used Interlux 202. Toxic aromatic stuff, needs a good mask on the user. Job also requires fine sanding. Have not tried the TSP. I go 202 – sand – 202 – acetone. It is kind of scary when acetone is the gentlest chemical one uses.
Sanding can also be touchy at the edges of the stripe and up against the rub rail. Strong tape indeed helps a lot.
Then there is tip and roll on the paint. Kind of depends on whether you want the 50 foot job or the nose against the hull job (speaking about viewing distance).
Annapolis
Sent: Monday, February 15, 2016 8:48 AM
Subject: [Cal_Boats] Re: Boot Stripe Paint
Charlie Husar2016-02-17 01:38 UTC
"The 202 is not that bad. Just do things outside, assume you will have good
gloves on, and don't sniff the stuff, it will gag you, make you dizzy, and
kill lots of brain cells."
Ahhh, such a feeling. And just think (if you still can), it is not illegal.
By the way, the 202 takes two rags. It is so volatile, that you need to put
it on and wipe off very quickly. One hand following the other.
Cheers, I guess
Sent: Tuesday, February 16, 2016 8:23 PM
To: Charlie Husar <hu… [at] gmail.com>
Subject: RE: [Cal_Boats] Re: Boot Stripe Paint
Charlie is right on. I probably should have used 240 grit wet dry sandpaper,
but the scouring pad was oh so much easier to use, and I used it with the
TSP at the same time, so basically combined two steps in one.
kill lots of brain cells. Best done on a slightly breezy day.
From: hu… [at] gmail.com <mailto:hu… [at] gmail.com>
To: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> ;
ca… [at] hotmail.com <mailto:ca… [at] hotmail.com>
Date: Tue, 16 Feb 2016 14:45:11 -0500
sanding. Have not tried the TSP. I go 202 - sand - 202 - acetone. It is
viewing distance).
Annapolis
tape.
ccampbell2016-02-17 15:10 UTC
On 2/16/2016 8:38 PM, 'Charlie Husar' hu… [at] gmail.com [Cal_Boats] wrote:
> “The 202 is not that bad. Just do things outside, assume you will have
> good gloves on, and don't sniff the stuff, it will gag you, make you
> dizzy, and kill lots of brain cells.”
> illegal.
This is an interesting subject--the question of whether and when we
should be allowed to play with dangerous things.
I've used lots of paint removers, the old methylene chloride kind, even
after knowing that the stuff can be carcinogenic. Don't you think I saw
the light while waiting for results from the prostate biopsies? But I
still use the stuff.... As a kid I'd work on the car's drum brakes.
Bang the drum off, and inside there was always accumulated dust that
contained asbestos fibers. Take a deep breath and blow hard to get rid
of the stuff. Geez. Maybe we should be protected from ourselves.
And I still use various solvents, and even wearing gloves doesn't always
prevent exposure, mostly because sometimes we just need the solvent to
do the job.
I think the key is education and information. In my old age I still
don't avoid exposure completely, but I do try to limit it it sensible
ways and to diminish contact. Why? Because I've read about the adverse
effects of exposure.
And then I think that we go sailing, and there's an inherently dangerous
undertaking for you. But I know that, and do my calculations, and I
still go sailing anyway.
