Re: charging
Re: charging
1 messages2016-02-19 14:18 UTCthrough 2016-02-19 14:18 UTC
Re: charging
du… [at] aim.com2016-02-19 14:18 UTC
Be aware that the alternator won't put out "full charging" unless the battery calls for it - if you used it within 80% or so of discharge, the built-in Voltage /charge regulator will regulate the amperage to a much lower level than full, regardless of your RPM's...
