2 messages2016-03-25 21:00 UTCthrough 2016-03-25 22:28 UTC
Wooden Spreaders; Tips Wanted (double Spreader mast)
Edward Stancil2016-03-25 21:00 UTC
Hi Guys Caliente is in the process of replacing original Wood spreaders
all 4 ...we are doing this in the slip ...
So far 1) made one set of temporary lower spreaders (nearly 3 inches too
short) from another cal36, which indicates lack of uniformity.
2) made 2nd set correct size
3) using originals for templates to make final set.
We have Fabricated 1. Aluminum Tip on lower port spreader (last race
season) and might make all Aluminum.replacements, but..
slip mate has E-35 with double spreader Mast...that has Stainless Steel
spreader tips; on double Spreaders the lowers have two grooves
and single groove on top spreaders...Also they have a Horseshoe piece that
locks in the top upper
shroud...of stainless steel.
Sooo.... If any one has upgraded to ALUMINUM spreaders and stlll
have Double Tips (or single) Laying Around please contact me ...
thanks or a referral to someone who has them or can fabricate
them...Thanks Cal boaters ..Edward CALIENTE 1966 Jensen 36 #60
e.… [at] gmail.com
RE: [Cal_Boats] Wooden Spreaders; Tips Wanted (double Spreader mast)
Michael Robinson2016-03-25 22:28 UTC
Hello Ed and Helen. I had Ballenger Spars fabricate aluminum spreaders for Holiday. They did beautiful work..
http://www.ballengerspars.com/.
Mike RobinsonS/V Eleanor May(916) 705-3200 our blog:http://www.sailblogs.com/member/eleanormay/
To: ca… [at] yahoogroups.com
Date: Fri, 25 Mar 2016 14:00:18 -0700
Subject: [Cal_Boats] Wooden Spreaders; Tips Wanted (double Spreader mast)
Hi Guys Caliente is in the process of replacing original Wood spreaders all 4 ...we are doing this in the slip ...
So far 1) made one set of temporary lower spreaders (nearly 3 inches too short) from another cal36, which indicates lack of uniformity.
We have Fabricated 1. Aluminum Tip on lower port spreader (last race season) and might make all Aluminum.replacements, but..
slip mate has E-35 with double spreader Mast...that has Stainless Steel spreader tips; on double Spreaders the lowers have two grooves
and single groove on top spreaders...Also they have a Horseshoe piece that locks in the top upper
Sooo.... If any one has upgraded to ALUMINUM spreaders and stlll have Double Tips (or single) Laying Around please contact me ...
thanks or a referral to someone who has them or can fabricate them...Thanks Cal boaters ..Edward CALIENTE 1966 Jensen 36 #60
e.… [at] gmail.com
