4 messages2016-03-26 18:18 UTCthrough 2016-03-28 02:18 UTC
RE: Broken booms and Ballengers
TomDressler2016-03-26 18:18 UTC
Hmm.
So here you are discussing spars, spreaders, boom and Ballengers.
Wednesday, for you Pac-Coasters (SF-MRY), if you recall, it was a bit bumpy
out there.
My friend was coming down from SF-Half Moon Bay and into Mry to pick me up
for a sail to Morro Bay.
Wednesday night was rough, it seems.
When I went to the dock to catch lines for him, I saw a pile of hardware and
software lying on the deck of his 63' ketch.
There was a pile of mainsail, aluminum, sheets and halyards all piled up.
His boom was bent/broken about 1/3 out from the mast at a 30 degree angle.
Shouldn't they be straight?
He said he saw some 20' sea and 30kt blows.
His jibe preventer stiffened, the moment arm out past that exceeded the
limit and BOOM!
So now he's working with Ballengers to get a new boom made up..and get all
of his rigging re-done.
He said.yep.sailing.you go from port to port and stop long enough to fix the
stuff that broke en route.
He's taking it quite well, actually.
I learned how to disassemble a bloom.
We'll continue to Morro Bay in May.
..tom
Sent: Friday, March 25, 2016 3:29 PM
Subject: RE: [Cal_Boats] Wooden Spreaders; Tips Wanted (double Spreader
mast)
Hello Ed and Helen. I had Ballenger Spars fabricate aluminum spreaders for
Holiday. They did beautiful work..
http://www.ballengerspars.com/.
Mike Robinson
S/V Eleanor May
(916) 705-3200
our blog:
http://www.sailblogs.com/member/eleanormay/
To: ca… [at] yahoogroups.com
Date: Fri, 25 Mar 2016 14:00:18 -0700
Subject: [Cal_Boats] Wooden Spreaders; Tips Wanted (double Spreader mast)
Hi Guys Caliente is in the process of replacing original Wood spreaders all
4 ...we are doing this in the slip ...
So far 1) made one set of temporary lower spreaders (nearly 3 inches too
short) from another cal36, which indicates lack of uniformity.
2) made 2nd set correct size
3) using originals for templates to make final set.
We have Fabricated 1. Aluminum Tip on lower port spreader (last race
season) and might make all Aluminum.replacements, but..
slip mate has E-35 with double spreader Mast...that has Stainless Steel
spreader tips; on double Spreaders the lowers have two grooves
and single groove on top spreaders...Also they have a Horseshoe piece that
locks in the top upper
shroud...of stainless steel.
Sooo.... If any one has upgraded to ALUMINUM spreaders and stlll have
Double Tips (or single) Laying Around please contact me ...
thanks or a referral to someone who has them or can fabricate them...Thanks
Cal boaters ..Edward CALIENTE 1966 Jensen 36 #60
e.… [at] gmail.com
https://www.avast.com/antivirus
Re: [Cal_Boats] RE: Broken booms and Ballengers
mike farrell2016-03-27 17:44 UTC
Buzz Ballenger is a great guy and a wealth of knowledge and experience. He supplied a mast, boom and rigging for my Santa Cruz 27 PHYLLIS SWIFT after her dismasting in the 1989 SC 27 Nationals on the Berkeley Circle when the starboard lower turnbuckle failed. Buzz also gave me great service and a good deal when I replaced the rigging and spreader bar in 2012 on YELLOW JACK USA57313. A preventer rigged forward is not really necessary on a sailboat under 30" Over 30' it's benefits are often overshadowed by conditions that can cause broken spars in the event of a broach or jibe. Steering downwind in heavy conditions require constant concentration and experience and can be a challenge particularly at night. Reduce sail to reduce pressure on the rig in heavy displacement boats that are limited to hull speed and unable to surf. An expensive lesson off the California coast, no injuries to the crew however! My Best, Mike Farrell
From: "'TomDressler' tb… [at] verizon.net [Cal_Boats]" <Ca… [at] yahoogroups.com>
To: Ca… [at] yahoogroups.com; 'Michael Robinson' <mi… [at] hotmail.com>
Sent: Saturday, March 26, 2016 11:18 AM
Subject: [Cal_Boats] RE: Broken booms and Ballengers
<!-- .yiv8260907678ygrp-photo-title{clear:both;font-size:smaller;height:15px;overflow:hidden;text-align:center;width:75px;} div.yiv8260907678ygrp-photo{background-position:center;background-repeat:no-repeat;background-color:white;border:1px solid black;height:62px;width:62px;} div.yiv8260907678photo-title a, div.yiv8260907678photo-title a:active, div.yiv8260907678photo-title a:hover, div.yiv8260907678photo-title a:visited {text-decoration:none;} div.yiv8260907678attach-table div.yiv8260907678attach-row {clear:both;} div.yiv8260907678attach-table div.yiv8260907678attach-row div {float:left;} p {clear:both;padding:15px 0 3px 0;overflow:hidden;} div.yiv8260907678ygrp-file {width:30px;} div.yiv8260907678attach-table div.yiv8260907678attach-row div div a {text-decoration:none;} div.yiv8260907678attach-table div.yiv8260907678attach-row div div span {font-weight:normal;} div.yiv8260907678ygrp-file-title {font-weight:bold;} --> <!-- _filtered {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered {font-family:Verdana;panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;} _filtered {font-family:"Lucida Handwriting";panose-1:3 1 1 1 1 1 1 1 1 1;} p.yiv8260907678MsoNormal, li.yiv8260907678MsoNormal, div.yiv8260907678MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;font-family:"Times New Roman", "serif";} a:link, span.yiv8260907678MsoHyperlink {color:blue;text-decoration:underline;} a:visited, span.yiv8260907678MsoHyperlinkFollowed {color:purple;text-decoration:underline;} p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman", "serif";} code {font-family:"Courier New";} pre {margin:0in;margin-bottom:.0001pt;font-size:10.0pt;font-family:"Courier New";} tt {font-family:"Courier New";} span.yiv8260907678cat {} span.yiv8260907678ct {} span.yiv8260907678HTMLPreformattedChar {font-family:"Consolas", "serif";} p.yiv8260907678attach, li.yiv8260907678attach, div.yiv8260907678attach {margin-right:0in;margin-left:0in;font-size:9.0pt;font-family:"Arial", "sans-serif";} p.yiv8260907678bold, li.yiv8260907678bold, div.yiv8260907678bold {margin-right:0in;margin-left:0in;font-size:10.0pt;font-family:"Arial", "sans-serif";font-weight:bold;} p.yiv8260907678green, li.yiv8260907678green, div.yiv8260907678green {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman", "serif";color:#628C2A;} p.yiv8260907678replbq, li.yiv8260907678replbq, div.yiv8260907678replbq {margin:3.0pt;font-size:12.0pt;font-family:"Times New Roman", "serif";} p.yiv8260907678ad, li.yiv8260907678ad, div.yiv8260907678ad {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman", "serif";} p.yiv8260907678underline, li.yiv8260907678underline, div.yiv8260907678underline {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman", "serif";} span.yiv8260907678yshortcuts {} p.yiv8260907678ad1, li.yiv8260907678ad1, div.yiv8260907678ad1 {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman", "serif";} p.yiv8260907678ad2, li.yiv8260907678ad2, div.yiv8260907678ad2 {margin-right:0in;margin-bottom:7.5pt;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman", "serif";} p.yiv8260907678underline1, li.yiv8260907678underline1, div.yiv8260907678underline1 {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman", "serif";text-decoration:underline;} span.yiv8260907678yshortcuts1 {font-family:"Verdana", "sans-serif";font-weight:bold;} span.yiv8260907678yshortcuts2 {font-family:"Verdana", "sans-serif";font-weight:normal;} span.yiv8260907678EmailStyle38 {font-family:"Calibri", "sans-serif";color:#1F497D;} .yiv8260907678MsoChpDefault {font-size:10.0pt;} _filtered {margin:1.0in 1.0in 1.0in 1.0in;} div.yiv8260907678WordSection1 {} _filtered {} _filtered {font-family:Symbol;} _filtered {font-family:"Courier New";} _filtered {font-family:Wingdings;} _filtered {font-family:Wingdings;} _filtered {font-family:Wingdings;} _filtered {font-family:Wingdings;} _filtered {font-family:Wingdings;} _filtered {font-family:Wingdings;} _filtered {font-family:Wingdings;} ol {margin-bottom:0in;} ul {margin-bottom:0in;}-->
Hmm.So here you are discussing spars, spreaders, boom and Ballengers.Wednesday, for you Pac-Coasters (SF-MRY), if you recall, it was a bit bumpy out there.My friend was coming down from SF-Half Moon Bay and into Mry to pick me up for a sail to Morro Bay.Wednesday night was rough, it seems.When I went to the dock to catch lines for him, I saw a pile of hardware and software lying on the deck of his 63’ ketch.There was a pile of mainsail, aluminum, sheets and halyards all piled up.His boom was bent/broken about 1/3 out from the mast at a 30 degree angle.Shouldn’t they be straight?He said he saw some 20’ sea and 30kt blows.His jibe preventer stiffened, the moment arm out past that exceeded the limit and BOOM!So now he’s working with Ballengers to get a new boom made up..and get all of his rigging re-done.He said…yep…sailing…you go from port to port and stop long enough to fix the stuff that broke en route.He’s taking it quite well, actually.I learned how to disassemble a bloom.We’ll continue to Morro Bay in May. ..tom From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]
Subject: RE: [Cal_Boats] Wooden Spreaders; Tips Wanted (double Spreader mast) Hello Ed and Helen. I had Ballenger Spars fabricate aluminum spreaders for Holiday. They did beautiful work.. http://www.ballengerspars.com/.
Mike RobinsonS/V Eleanor May(916) 705-3200 our blog:http://www.sailblogs.com/member/eleanormay/ To: ca… [at] yahoogroups.com
Hi Guys Caliente is in the process of replacing original Wood spreaders all 4 ...we are doing this in the slip ... So far 1) made one set of temporary lower spreaders (nearly 3 inches too short) from another cal36, which indicates lack of uniformity. 2) made 2nd set correct size 3) using originals for templates to make final set. We have Fabricated 1. Aluminum Tip on lower port spreader (last race season) and might make all Aluminum.replacements, but..slip mate has E-35 with double spreader Mast...that has Stainless Steel spreader tips; on double Spreaders the lowers have two groovesand single groove on top spreaders...Also they have a Horseshoe piece that locks in the top uppershroud...of stainless steel. Sooo.... If any one has upgraded to ALUMINUM spreaders and stlll have Double Tips (or single) Laying Around please contact me ...thanks or a referral to someone who has them or can fabricate them...Thanks Cal boaters ..Edward CALIENTE 1966 Jensen 36 #60 e.… [at] gmail.com
www.avast.com |
TomDressler2016-03-27 23:50 UTC
Right. No injuries to crew.
The preventer is in place. This boat is 63' loa and the boom is 16'-3"!
Oh, did i mention it's a ferrocement?
Big loads on that baby indeed!
Ballenger will build him a new boom and he will get other rigging replaced at the same time.
Thanks for the feedback.
....tom
> On Mar 27, 2016, at 10:44 AM, mike farrell ve… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Hmm.
> ..tom
> Mike Robinson
> S/V Eleanor May
> (916) 705-3200
> our blog:
> e.… [at] gmail.com
> www.avast.com
Helen Horn2016-03-28 02:18 UTC
Same length boom as a cal 36. Helen
On Sun, Mar 27, 2016 at 4:50 PM, TomDressler tb… [at] verizon.net [Cal_Boats]<Ca… [at] yahoogroups.com> wrote:
Right. No injuries to crew.The preventer is in place. This boat is 63' loa and the boom is 16'-3"!Oh, did i mention it's a ferrocement?Big loads on that baby indeed!Ballenger will build him a new boom and he will get other rigging replaced at the same time.Thanks for the feedback.
....tom
www.avast.com |
