2 messages2016-04-05 19:35 UTCthrough 2016-04-05 19:50 UTC
Re: [Cal_Boats] Cal outboard speed
saylorran2016-04-05 19:35 UTC
I think my only concern will be in our area of the Santa Barbara Channel, we get many days or afternoons with 15 to 20 knot winds that create 4 to 6ft swell, breaking surf, wind against current with steep faces.
I just wonder if the engine and cockpit will get swamped.
RandyCal 2 29 Out Patient Channel Islands Ca
Sent on a Sprint Samsung Galaxy Note® 3
From: "Joseph Schoepp jo… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
Date: 04/05/2016 12:10 PM (GMT-08:00)
Subject: Re: [Cal_Boats] Cal outboard speed
I am considering cutting the transom and using a 15hp. I am planning on a 2 stroke, but was wondering if you guys think a 4 stroke would be ok, found a good deal on one from a friend. Thanks for the info and thoughts.
JoeCal 29
I think the only time the outboard does not preform well is in a heavy seaway.
If you are out and the wind pipes up 25-50, plan on sailing.
you may be able to power up to 30, but the sea state will be the deciding factor.
I knew you were going to ask about the height I cut mine. I dont know off hand, but I will check when I get a chance.
It may be a week or so.
On Tue, Apr 5, 2016 at 12:22 PM, Joseph Schoepp jo… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
Do those of you with an outboard on the cal 29 feel its good enough to use to motor down the icw in south florida and around the Florida keys?
Thanks,JoeCal 29
sailor7312 .2016-04-05 19:50 UTC
....@ Randy.....valid concerns. I would tend to stay w the inboard where
you are.
...@ Joe.....I have not tried other outboards so I dont know how they would
perform. I use the 9.9 High thrust (4 stoke) which has a more power gear
ratio for heavier loads and a prop that seems to work better w heavy loads
and gives better reverse power.
It weight around 110 lbs
On Tue, Apr 5, 2016 at 3:35 PM, saylorran sa… [at] yahoo.com [Cal_Boats] <
> Randy
> Cal 2 29
> Out Patient
> Channel Islands Ca
> Joe
> Cal 29
> <https://overview.mail.yahoo.com/mobile/?.src=Android>
> seaway.
> factor.
>> Thanks,
>> Joe
>> Cal 29
