4 messages2016-04-05 18:17 UTCthrough 2016-04-06 17:00 UTC
Re: [Cal_Boats] Cal 29 with Outboards [1 Attachment]
saylorran2016-04-05 18:17 UTC
Jim,I have to ask about your comment about the Out Board not as effective in a heavy sea as an A4.
It is lack of power or cavatation?
Randy
Sent on a Sprint Samsung Galaxy Note® 3
From: "Jim Englert sa… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
Date: 03/31/2016 7:42 PM (GMT-08:00)
To: Ca… [at] yahoogroups.com, jo… [at] yahoo.com
Subject: Re: [Cal_Boats] Cal 29 with Outboards [1 Attachment]
[Attachment(s) from Jim Englert included below]
One other picture. Sorry I don't have more detailed. I do love the outboard. Once it is pulled up , the boat sails like a dream. No turbulence felt on the rudder from the prop and shaft that aren't there. I also found that the boat floated higher in the back end w the inboard removed and the outboard hanging off the transom. Good luck. If you are not afraid of taking a sawzaw to your transom and doing some glass work, you won't regret it. The outboard I used has the extra long shaft(25" I think). It seldom cavitates even when under sail
On Mar 31, 2016, at 10:34 PM, Joseph Schoepp jo… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
Jim,
Thanks, that helps a lot! I'm just using mine for cruising down the ICW in Florida and the keys, so it should be good. I'm a little less worried about doing it now. Thanks again for the info.
JoeCal 29
I will add that I did not want to do an external bracket, because it puts a lot of weight off the end of the transom and by having it hung off the transom itself, the Yamaha 9.9 high thrust w the tiller works very well. The throttle and shift are easy to reach a the engine tiller in the up position.
I cut my transom to the desired height. I found the plywood that was factory installed was not adequate to support the engine to my liking, so I then cut the tray out where the water drains out of the cockpit, installed a thicker piece of plywood, reglassed the tray and everything has worked well.
I had an old cal 29 brochure which showed the option in a line drawing profile and took it from there. I love my outboard, but you have to realize it will not push through a heavy sea like an atomic 4 inboard. The Yamaha high thrust gives about the same backing power as an atomic 4 w a folding prop that is clean. I do a little over 6 knots under power wide open flat water and usually do about 5.5
Hope this helps a bit
On Mar 31, 2016, at 7:44 PM, saylorran sa… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
Does anyone have an original Cal 29 that came with an outboard?
RandyCal 2 29 Out Patient Channel Islands Ca
sailor7312 .2016-04-05 19:27 UTC
the answer to that is probably yes. Lack of power and cavitation will come
in to play probably at the same time.
Even w the deep 25" shaft, in a heavy sea way, with it hanging off the
back, it can catch some air.
I have not personally experienced the limits of what the engine can push,
just sharing what I believe.
I love my outboard on my 29, but I fully believe that if shit hits the fan,
I will be sailing not powering.
A cal 29 w a double reefed main can take a hell of a lot of wind.
On Tue, Apr 5, 2016 at 2:17 PM, saylorran sa… [at] yahoo.com [Cal_Boats] <
> Jim,
> heavy sea as an A4.
> Randy
> [image: image1.JPG]
> Jim,
> Joe
> Cal 29
> <https://overview.mail.yahoo.com/mobile/?.src=Android>
> position.
> well.
> Randy
> Cal 2 29
> Out Patient
> Channel Islands Ca
Horsehideperfecto2016-04-05 20:13 UTC
I would also add that the A4 is around 30hp so even after subtracting a bit for lost hp, you have at least twice the raw power of a 9.9hp outboard.
If you decide to not cut the boat and need a heavy duty, tubular, stainless steel, adjustable outboard mount, I have one for sale for $100. It will easily handle up to a 15hp motor.
Pete
> On Apr 5, 2016, at 3:27 PM, 'sailor7312 .' sa… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> the answer to that is probably yes. Lack of power and cavitation will come in to play probably at the same time.
> Even w the deep 25" shaft, in a heavy sea way, with it hanging off the back, it can catch some air.
> I have not personally experienced the limits of what the engine can push, just sharing what I believe.
> I love my outboard on my 29, but I fully believe that if shit hits the fan, I will be sailing not powering.
> On Tue, Apr 5, 2016 at 2:17 PM, saylorran sa… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
>> Jim,
>> Randy
>> <image1.JPG>
>>> Jim,
>>> Joe
>>> Cal 29
>>>> Randy
>>>> Cal 2 29
>>>> Out Patient
>>>> Channel Islands Ca
Cal 29 in May Cruising World
Duane Knize Boat2016-04-06 17:00 UTC
Speaking about Cal 29's, check out the cover article in May Cruising World.
Duane
Duane Knize
S/V Marlyn
1978 Cal 2-39 #18
berthed: Emeryville, CA
kn… [at] san.rr.com
