3 messages2016-06-12 16:37 UTCthrough 2016-06-13 02:42 UTC
fixing the compression post
mo… [at] aol.com2016-06-12 16:37 UTC
hi. i have a 1971 cal 27 pop top. working on refitting it. my present project involves the compression post. the post below the galley counter has begun to rot and squish in the 2 3/4 inches between the floor and the bottom or the galley fiberglass. this has allowed the post to sink 5/8 on an inch. you can see it by looking at the top of the companionway to the forward cabin.
i have some Brazilian walnut. it's supposed to last better than 50 years even buried under the dirt. i am planning on cutting the bottom 2 3/4 inches off of the existing compression post and making a mast step out of the Brazilian walnut. all the rest of the compression post is in fine condition. i think this will be a good solution to the problem.
my question has to do with jacking up the roof/mast/compression post. i have never done this before. since the cabin sole is attached to the fiberglass of the galley, i was planning on removing the sole to allow me access to the floor beneath. i was going to make a temporary compression post, like you would when jacking up a house porch roof to replace the porch beneath, and bolt a bottle jack to the top. you can't get directly beneath the mast, so, i was going to set up my jack directly beside the existing compression post. since the compression post, galley, and bulkhead are all bonded together as a unit, i am hoping that jacking up the roof at this point will raise the whole thing up the required 2 3/4 inches.
any thoughts, warnings, or advice you guys can give would be great. thanks.
RE: [Cal_Boats] fixing the compression post
r good2016-06-12 20:12 UTC
first question: what caused the rot and has its source been fixed?reggie
Date: Sun, 12 Jun 2016 09:37:07 -0700
Subject: [Cal_Boats] fixing the compression post
Re: fixing the compression post
mo… [at] aol.com2016-06-13 02:42 UTC
---In Ca… [at] yahoogroups.com, <my1972ih@...> wrote :
bought the boat off of the lean dock. it had no companionway hatch or hatchboards. it would rain and the bilge would fill and then the marina would pump it out. sat for at least a year like this, with the bottom of the compression post sitting in water on a regular basis. when i bought it, i built a hatch and made hatchboards.i installed a bilge pump. it neer runs because the bilge has remained dry since i closed off access to the rain. but, the damage was done. it's not rotting as in it's presently wet and rotting but, the damage done in the past needs to be dealt with. the wood at the very bottom of the post is no longer sound (from the bottom of the post and the 2 3/4 inches to the bottom of the galley cabinetry. all the rest of the post, including the nice teak slab that goes from the galley counter to the roof of the boat, is just fine.
i just need to remove the bad, raise everything the 5/8 of an inch it has sunk, and put a good piece (the mast step i will make) in place of the rotted wood.
first question: what caused the rot and has its source been fixed? reggie
