6 messages2016-06-13 13:51 UTCthrough 2016-06-23 01:57 UTC
Re: [Cal_Boats] fixing the compression post
rj… [at] juno.com2016-06-13 13:51 UTC
The first step is to unstep the mast, you really can't adequately make
the repair with the mast in place. That will reduce the compressive load
on the repair area, then wedge or otherwise gently lift the structure
back up to it's correct height. Now cut out the rotten section of the
compression post and splice in replacement wood. Lifting/wedging against
the underside of the cabin top may bring everything up with it, but it
may also just lift the cabin top and separate it from the structure
underneath. You may need to find a way to attach a setup to your
bottle-jack that will hook under the bulkhead/cabinet structure and push
it up from the bottom, then insert a temporary compression post alongside
the permanent one to hold everything up while you make repairs, then
lower the structure back down onto the new base.
I have rebuilt structure under the compression post on a couple of boats,
but neither boat had a bulkhead there, just the compression post, so I'm
not sure about how the deck and bulkhead o the CAL 27 are connected, plus
different boats are built different, so even if lifting the underside of
the deck would lift the bulkhead with it on one boat, doesn't mean it
will work for all boats. You could try it, maybe it will work? But either
way, the mast really needs to be unstepped first to take the load off the
area.
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II #10201
Formerly co-owned "NODROG"
1970 CAL 21 #285
On 12 Jun 2016 09:37:07 -0700 "mo… [at] aol.com [Cal_Boats]"
<Ca… [at] yahoogroups.com> writes:
hi. i have a 1971 cal 27 pop top. working on refitting it. my present
project involves the compression post. the post below the galley counter
has begun to rot and squish in the 2 3/4 inches between the floor and
the bottom or the galley fiberglass. this has allowed the post to sink
5/8 on an inch. you can see it by looking at the top of the companionway
to the forward cabin.
i have some Brazilian walnut. it's supposed to last better than 50 years
even buried under the dirt. i am planning on cutting the bottom 2 3/4
inches off of the existing compression post and making a mast step out of
the Brazilian walnut. all the rest of the compression post is in fine
condition. i think this will be a good solution to the problem.
my question has to do with jacking up the roof/mast/compression post. i
have never done this before. since the cabin sole is attached to the
fiberglass of the galley, i was planning on removing the sole to allow me
access to the floor beneath. i was going to make a temporary compression
post, like you would when jacking up a house porch roof to replace the
porch beneath, and bolt a bottle jack to the top. you can't get directly
beneath the mast, so, i was going to set up my jack directly beside the
existing compression post. since the compression post, galley, and
bulkhead are all bonded together as a unit, i am hoping that jacking up
the roof at this point will raise the whole thing up the required 2 3/4
inches.
any thoughts, warnings, or advice you guys can give would be great.
thanks.
Blazeray
Deemed: One Household Item Everyone Should Have In Any Emergency
http://thirdpartyoffers.juno.com/TGL3141/575ebb05896623b0441e3st04duc
RE: [Cal_Boats] fixing the compression post
r good2016-06-13 14:04 UTC
it may be possible to do it mast up if all standing rigging is loosened as much as possible.Reggie
To: Ca… [at] yahoogroups.com; mo… [at] aol.com
Date: Mon, 13 Jun 2016 09:51:47 -0400
Subject: Re: [Cal_Boats] fixing the compression post
The first step is to unstep the mast, you really can't adequately make the
repair with the mast in place. That will reduce the compressive load on the
repair area, then wedge or otherwise gently lift the structure back up to it's
correct height. Now cut out the rotten section of the compression post and
splice in replacement wood. Lifting/wedging against the underside of the cabin
top may bring everything up with it, but it may also just lift the cabin top and
separate it from the structure underneath. You may need to find a way to attach
a setup to your bottle-jack that will hook under the bulkhead/cabinet structure
and push it up from the bottom, then insert a temporary compression post
alongside the permanent one to hold everything up while you make repairs, then
but neither boat had a bulkhead there, just the compression post, so I'm not
sure about how the deck and bulkhead o the CAL 27 are connected, plus different
boats are built different, so even if lifting the underside of the deck would
lift the bulkhead with it on one boat, doesn't mean it will work for all boats.
You could try it, maybe it will work? But either way, the mast really needs to
be unstepped first to take the load off the area.
1970 CAL 21 #285
writes:
project involves the compression post. the post below the galley counter has
begun to rot and squish in the 2 3/4 inches between the floor and the
bottom or the galley fiberglass. this has allowed the post to sink 5/8 on an
inch. you can see it by looking at the top of the companionway to the forward
cabin.
years even buried under the dirt. i am planning on cutting the bottom 2 3/4
inches off of the existing compression post and making a mast step out of the
Brazilian walnut. all the rest of the compression post is in fine condition. i
i have never done this before. since the cabin sole is attached to the
access to the floor beneath. i was going to make a temporary compression post,
like you would when jacking up a house porch roof to replace the porch
beneath, and bolt a bottle jack to the top. you can't get directly beneath the
mast, so, i was going to set up my jack directly beside the existing
compression post. since the compression post, galley, and bulkhead are all
bonded together as a unit, i am hoping that jacking up the roof at this point
will raise the whole thing up the required 2 3/4 inches.
thanks.
Blazeray
http://thirdpartyoffers.juno.com/TGL3142/575ebb05896623b0441e3st04duc
Re: fixing the compression post
mo… [at] aol.com2016-06-14 02:54 UTC
that's the way some had previously told me i should do it....and to do it on the water as the pressures on the hull are different when on the water as compared to being blocked on the hard. if waiting to do it til i haul it and unstep the mast is the way to go, then the whole thing becomes simpler. it's doing it while the stick is in place that complicates matters. so, is it best to do that when the mast is up or after it is removed?
---In Ca… [at] yahoogroups.com, <my1972ih@...> wrote :
it may be possible to do it mast up if all standing rigging is loosened as much as possible. Reggie
To: Ca… [at] yahoogroups.com; motorcyclejack2@...
The first step is to unstep the mast, you really can't adequately make the repair with the mast in place. That will reduce the compressive load on the repair area, then wedge or otherwise gently lift the structure back up to it's correct height. Now cut out the rotten section of the compression post and splice in replacement wood. Lifting/wedging against the underside of the cabin top may bring everything up with it, but it may also just lift the cabin top and separate it from the structure underneath. You may need to find a way to attach a setup to your bottle-jack that will hook under the bulkhead/cabinet structure and push it up from the bottom, then insert a temporary compression post alongside the permanent one to hold everything up while you make repairs, then lower the structure back down onto the new base.
I have rebuilt structure under the compression post on a couple of boats, but neither boat had a bulkhead there, just the compression post, so I'm not sure about how the deck and bulkhead o the CAL 27 are connected, plus different boats are built different, so even if lifting the underside of the deck would lift the bulkhead with it on one boat, doesn't mean it will work for all boats. You could try it, maybe it will work? But either way, the mast really needs to be unstepped first to take the load off the area.
1970 CAL 21 #285
On 12 Jun 2016 09:37:07 -0700 "motorcyclejack2@... mailto:motorcyclejack2@... [Cal_Boats]" <Ca… [at] yahoogroups.com mailto:Ca… [at] yahoogroups.com> writes:
hi. i have a 1971 cal 27 pop top. working on refitting it. my present project involves the compression post. the post below the galley counter has begun to rot and squish in the 2 3/4 inches between the floor and the bottom or the galley fiberglass. this has allowed the post to sink 5/8 on an inch. you can see it by looking at the top of the companionway to the forward cabin.
i have some Brazilian walnut. it's supposed to last better than 50 years even buried under the dirt. i am planning on cutting the bottom 2 3/4 inches off of the existing compression post and making a mast step out of the Brazilian walnut. all the rest of the compression post is in fine condition. i think this will be a good solution to the problem.
my question has to do with jacking up the roof/mast/compression post. i have never done this before. since the cabin sole is attached to the fiberglass of the galley, i was planning on removing the sole to allow me access to the floor beneath. i was going to make a temporary compression post, like you would when jacking up a house porch roof to replace the porch beneath, and bolt a bottle jack to the top. you can't get directly beneath the mast, so, i was going to set up my jack directly beside the existing compression post. since the compression post, galley, and bulkhead are all bonded together as a unit, i am hoping that jacking up the roof at this point will raise the whole thing up the required 2 3/4 inches.
any thoughts, warnings, or advice you guys can give would be great. thanks.
Blazeray Deemed: One Household Item Everyone Should Have In Any Emergency http://thirdpartyoffers.juno.com/TGL3142/575ebb05896623b0441e3st04duchttp://thirdpartyoffers.juno.com/TGL3142/575ebb05896623b0441e3st04duc http://thirdpartyoffers.juno.com/TGL3142/575ebb05896623b0441e3st04duc
Re: [Cal_Boats] Re: fixing the compression post
Jim Englert2016-06-14 03:12 UTC
I have only followed this thread a bit, but if I were fixing any area near the mast , I would take it down to remove the compressive loads. Just my .02 cents. It's just plain easier once that is done
East coast cal 29 sailor
> On Jun 13, 2016, at 10:54 PM, mo… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Reggie
> From: Ca… [at] yahoogroups.com
> 1970 CAL 21 #285
> On 12 Jun 2016 09:37:07 -0700 "motorcyclejack2@... [Cal_Boats]" <Ca… [at] yahoogroups.com> writes:
> ____________________________________________________________
> Blazeray
mo… [at] aol.com2016-06-22 21:44 UTC
i i was hoping to hear from someone who had done this. anyone with hands on experience?
On Jun 13, 2016, at 10:54 PM, motorcyclejack2@... mailto:motorcyclejack2@... [Cal_Boats] <Ca… [at] yahoogroups.com mailto:Ca… [at] yahoogroups.com> wrote:
---In Ca… [at] yahoogroups.com mailto:Ca… [at] yahoogroups.com, <my1972ih@...> wrote :
To: Ca… [at] yahoogroups.com mailto:Ca… [at] yahoogroups.com; motorcyclejack2@...
From: Ca… [at] yahoogroups.com mailto:Ca… [at] yahoogroups.com
1970 CAL 21 #285
GEORGE BARLOW2016-06-23 01:57 UTC
I’d go with the loosening of the stays with the mast up as a first try. When I removed my Cal 28 compression post, the rig stood up fine. The dead weight of the rig was supported fine by the deck with the bulkhead providing most of the strength. You could put a padded 2 by 4 supported by a bottle jack as a sister and it would pick up any sag.
I eventually took the rig down because I didn’t trust my rig to stand up in the spring windstorms we have in Texas and I didn’t want to harm any boats in neighboring slips in case it fell.
George Barlow
Eagle Mountain, Texas
> On Jun 22, 2016, at 4:44 PM, mo… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> i
> ---In Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>, <sailor7312@...> wrote :
> On Jun 13, 2016, at 10:54 PM, motorcyclejack2@... <mailto:motorcyclejack2@...> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>> wrote:
>> ---In Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>, <my1972ih@...> wrote :
>> Reggie
>> To: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>; motorcyclejack2@...
>> From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
>> 1970 CAL 21 #285
>> On 12 Jun 2016 09:37:07 -0700 "motorcyclejack2@... <mailto:motorcyclejack2@...> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>> writes:
>> Blazeray
>> <http://thirdpartyoffers.juno.com/TGL3142/575ebb05896623b0441e3st04duc>http://thirdpartyoffers.juno.com/TGL3142/575ebb05896623b0441e3st04duc <http://thirdpartyoffers.juno.com/TGL3142/575ebb05896623b0441e3st04duc>
