Rub Rail Guide
Rub Rail Guide
3 messages2016-04-20 02:40 UTCthrough 2016-06-23 14:23 UTC
Rub Rail Guide
Charlie Husar2016-04-20 02:40 UTC
There has been some rub rail discussion lately, so I thought this might be useful. The method applies to many Cal models that have the one piece rubber rail. Someone asked about the rail going right around the bow. Yes, it was designed that way. Take Care Charlie Periodically, I'd buy a bunch of rub rails to get a discount, and then distribute them to our local CAL 25 fleet. Here are some instructions and notes I would send with the rail. No UL approval written or implied. CAL 25 Rub Rail Installation The rub rails have not really changed through the models of CAL 25s. One size fits all for the flat deck CAL 25 model (and fits some other CAL models as well). A 55 foot long section is suitable for the 25. The rub rail is folded over the deck-hull joint where the deck and hull of the boat are joined. The rub rail has a cross section (two internal lips - top and bottom) that allows it to be plugged onto the lip of the joint. Removal If there are no screws going vertically through the rail, simply unscrew the 2 brass caps near the stern at the ends of the rub rail (nuts are inside the hull), and peel the old one off going around the boat. If there are vertical screws going into the rail, just unscrew them first, and the whole rail should peel off (there shouldn't be any type of glue). Then proceed as below. Installation The new rub rail fits over the deck hull joint which forms a lip around the boat. Unscrew the two brass caps at the aft end of the old rail (nuts are internal to hull). Embed one end of the new rail inside the cap and use an awl to put holes in the rail through the brass cap bolt holes to reinsert the screws. Bolt the one side back into the boat. Fold the rail over the lip of the joint as you move forward, stretching the rail (a lot) as you progress. Basically, you insert the top lip of the rail or the bottom lip of the rail, and then roll up or down to get the other lip to catch. (A rubber mallet sometimes helps.) Really does take two people. At the other end, mark and cut the rail while it is stretched. Use the back of the other brass cap (where it would be if still installed) as a marking reference. Then with rub rail tension relieved, feed it into the end cap with screws as you did the first one. Then restretch to get the cap to the holes in the hull. Due to the stretching required, this operation would be difficult with the boat in the water. Ashore, don't yank the boat off its jack stands. :- ( Also a good idea to put screws up from the bottom of the rail through the hull joint lip (number 10 self tapping ~1.5 inch pan head or oval head with washers like the decorative ones) into predrilled vertical tapping size holes. Holes should not go to the top of the rail. Put these about every two feet starting at the bow back about 10 feet on each side. This keeps the rail from getting knocked off in heavy seas (bow slamming kinds of weather). Some Notes Here's the rub (sorry for pun). The rail is best installed warm (if not hot) since it is more resilient and supple that way (stretches better). Could be a problem in the winter depending on where you live. I've heard heating methods all the way from hot water buckets (even an oil drum full of water over a propane fire), to hair dryers, to letting the rail sit on a hot summer parking lot for a while. One other is to put the rail in a dark trash bag sitting out in the sun. If you see gaps in the joint between deck and hull while the rub rail is off, caulk the joint and smooth before installing rail. Don't need to glue the rail on. The joint must be well very cleaned before caulking. Scrub it out (maybe a wire brush) then wipe or brush with acetone. By the way, if you have pop rivets through the joint, they are NOT structural. They were used to hold the top and bottom of the boat together and stable while the internal fiberglass was laid across the deck hull joint. On some models, a teak strip (usually at the top of the hull carpet that was attached with the %$_&## glue) was screwed into the deck hull joint from the inside. This arrangement ultimately leaked so the caulk is a good idea. I have seen a CAL or two where someone had filed down the lip in the deck/hull joint. Looks prettier with no rub rail, but sure screws up the install. On one boat, we had to go with the screws all the way around at 18 inch intervals.
Re: [Cal_Boats] Rub Rail Guide
ccampbell2016-04-20 18:14 UTC
On 4/19/2016 10:40 PM, 'Charlie Husar' hu… [at] gmail.com [Cal_Boats] wrote: > There has been some rub rail discussion lately, so I thought this might be > useful. Charlie: I assume this is the same rubrail as used on my Cal 20 (and, for that matter, at least very nearly the same one as used on my 1962 Glaspar I/O runabout). On the Cal 20, water running off the deck carries dust and debris into the gap between the deck structure and the top of the rubrail, and the crud accumulates there. Has anybody filled the joint between the top of the rubrail and the boat with sealer to keep this from happening? I've never removed my rubrail. When it got annoyingly chalky, I scrubbed it down with an abrasive pad and solvent and painted it with a vinyl buoy paint. The result was pretty good. That was maybe 6-8 years ago and it's about time for a repaint. Chris Campbell >
Re: Rub Rail Guide
mo… [at] aol.com2016-06-23 14:23 UTC
wow. thanks. that was quick. i really appreciate it. couldn't find anything on-line.
