Re: [Cal_Boats] Cal 20 Hull Numbers
8 messages2016-06-22 14:31 UTCthrough 2016-06-23 17:41 UTC
RE: [Cal_Boats] Cal 20 Hull Numbers
vectormenow2016-06-22 14:31 UTC
I owned hull 61 Coyote, there was no hull number on the boat What is on your title..? I have owned 8 cal 20's and just 2 had hull # inside the transom From: "bl… [at] sbcglobal.net [Cal_Boats]" <Ca… [at] yahoogroups.com> Date: 06/22/2016 7:17 AM (GMT-08:00) To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] Cal 20 Hull Numbers Anyone know where to find the hull number on a Cal 20 hull? I have looked in the usual spot (starboard transom). The boat is a "sub 100" hull number.
rj… [at] juno.com2016-06-22 14:44 UTC
A CAL 20 with a Hull# of less than 100 would be from the early 1960's, long before the 1972 start of the USCG required 12-digit HIN. So, there will not be a Hull# on the outside of the transom unless a previous owner has properly marked the boat with a State-issued HIN issued sometime since 1989 (depending on what State the boat was registered with at that time.) However, all CAL boats had the Hull# marked on the inside of the transom, somewhere on the starboard half of the inside surface. This was done by taking what appears to be a number printed in black on a white paper label applied to the inside of the transom and covered by one thin layer of fiberglass (FG is transparent or at least translucent when wet out with resin). A previous owner may have painted over the label. Rod Johnson, "SUNBIRD" 1979 O'DAY DS II #10201 was co-owner of "NODROG" 1970 CAL 21 #285 On 22 Jun 2016 07:17:48 -0700 "bl… [at] sbcglobal.net [Cal_Boats]" <Ca… [at] yahoogroups.com> writes: Anyone know where to find the hull number on a Cal 20 hull? I have looked in the usual spot (starboard transom). The boat is a "sub 100" hull number. Yahoo Search How To Apply For Business Loans http://thirdpartyoffers.juno.com/TGL3141/576aa51078c58250f6af1st01duc
george macon2016-06-22 16:06 UTC
Sometimes you can find hull #s under drawers and woodwork. George M... From: ccampbell cc… [at] lsnm.org [Cal_Boats]<mailto:Ca… [at] yahoogroups.com> Sent: ‎6/‎22/‎2016 12:04 PM To: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>; bl… [at] sbcglobal.net<mailto:bl… [at] sbcglobal.net> Subject: Re: [Cal_Boats] Cal 20 Hull Numbers On 6/22/2016 10:17 AM, bl… [at] sbcglobal.net [Cal_Boats] wrote: > > > Anyone know where to find the hull number on a Cal 20 hull? I have > looked in the usual spot (starboard transom). The boat is a "sub 100" > hull number. > Rod's reply points out that the number is shown INSIDE the transom, not outside in what is now the "usual" (mandated) location. Back then there was no requirement of using a hull ID number in the form we expect today.. My boat (#1220) has the little unpainted oval space inside showing its number. Chris Campbell > > > > ------------------------------------------------------------------------ >
ccampbell2016-06-22 16:24 UTC
On 6/22/2016 12:06 PM, george macon ge… [at] hotmail.com [Cal_Boats] wrote: > > > Sometimes you can find hull #s under drawers and woodwork. Cal 20s ain't got no drawers! And not much woodwork, for that matter. I did some painting below in mine this spring and did not observe any numbers on the only portable woodwork, the access lids for storage spaces. Chris Campbell
george macon2016-06-22 16:51 UTC
Whoops! Sorry... My other cals were all labelled that way! George Macon To: Ca… [at] yahoogroups.com; ge… [at] hotmail.com From: Ca… [at] yahoogroups.com Date: Wed, 22 Jun 2016 12:24:44 -0400 Subject: Re: [Cal_Boats] Cal 20 Hull Numbers On 6/22/2016 12:06 PM, george macon ge… [at] hotmail.com [Cal_Boats] wrote: Sometimes you can find hull #s under drawers and woodwork. Cal 20s ain't got no drawers! And not much woodwork, for that matter. I did some painting below in mine this spring and did not observe any numbers on the only portable woodwork, the access lids for storage spaces. Chris Campbell
vectormenow2016-06-22 23:45 UTC
Not always so. Many boats have sail numbers assigned locally My best, Mike Farrell From: "Timm Lessley ti… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> Date: 06/22/2016 12:14 PM (GMT-08:00) To: Ca… [at] yahoogroups.com,bl… [at] sbcglobal.net Subject: Re: [Cal_Boats] Cal 20 Hull Numbers What is your sail number? In pdx the sail number is the hull number. On Jun 22, 2016, at 4:17 AM, bl… [at] sbcglobal.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Anyone know where to find the hull number on a Cal 20 hull? I have looked in the usual spot (starboard transom). The boat is a "sub 100" hull number.
Charlie Husar2016-06-23 04:15 UTC
Hi, All. The PHRF numbers are assigned locally and are 5 digit numbers nowadays. Some old IOR and MORC numbers were 4 or 5 digits, and were never as low as the hull number of the boat. In an area with a one design racing fleet (e.g., J/24s or Cal 25s in Annapolis) the sail number reflects the hull number. We have one exception here in the Cal 25s. That boat came to Annapolis from Detroit. For the Cal 20s, any sail number under 2000 is a hull number (unless the owner bought someone else’s sails). Take Care Charlie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] Sent: Wednesday, June 22, 2016 7:45 PM To: Ca… [at] yahoogroups.com; Timm Lessley <ti… [at] gmail.com> Subject: Re: [Cal_Boats] Cal 20 Hull Numbers Not always so. Many boats have sail numbers assigned locally My best, Mike Farrell From: "Timm Lessley ti… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> Date: 06/22/2016 12:14 PM (GMT-08:00) To: Ca… [at] yahoogroups.com,bl… [at] sbcglobal.net Subject: Re: [Cal_Boats] Cal 20 Hull Numbers What is your sail number? In pdx the sail number is the hull number. On Jun 22, 2016, at 4:17 AM, bl… [at] sbcglobal.net <mailto:bl… [at] sbcglobal.net> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote: Anyone know where to find the hull number on a Cal 20 hull? I have looked in the usual spot (starboard transom). The boat is a "sub 100" hull number.
Timm Lessley2016-06-23 17:41 UTC
Agree, yet in portland hull number is sail number except in one case, a cal 20 has sail number 000, three stooges -owned by three admittedly comic characters > On Jun 22, 2016, at 1:45 PM, vectormenow ve… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > Not always so. Many boats have sail numbers assigned locally > My best, Mike Farrell > > > > Sent from my Samsung Galaxy Reverb. > > > > -------- Original message -------- > From: "Timm Lessley ti… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> > Date: 06/22/2016 12:14 PM (GMT-08:00) > To: Ca… [at] yahoogroups.com,bl… [at] sbcglobal.net > Subject: Re: [Cal_Boats] Cal 20 Hull Numbers > > > What is your sail number? In pdx the sail number is the hull number. > > Sent from my iPhone, awed grammar and spelling courtesy of iPhone tachmology > >> On Jun 22, 2016, at 4:17 AM, bl… [at] sbcglobal.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: >> >> >> Anyone know where to find the hull number on a Cal 20 hull? I have looked in the usual spot (starboard transom). The boat is a "sub 100" hull number. >> > >
