salon portlight replacement in cal 27 pop top
8 messages2016-07-06 01:28 UTCthrough 2016-07-10 17:57 UTC
mo… [at] aol.com2016-07-06 01:28 UTC
i want to give my thanks for the guidance i got on rub rail replacement. it was a bit more difficult done on the water and by myself, i think, than it would have been on the hard with some help but, it turned out to be a job well done. now, onto the portlights. all the glass needs replaced and two leak so that i had to use tyvek tape on the outside as a temporary fix. going to be really fun removing that tape. lol. anyhow, i have a few questions about that job for those with experience. 1) where can i get replacement rubber seals? 2) where should sealant be applied? 3)silicone sealant, butyl tape (which i really love for bedding of hardware), or some other type of sealant. 4) how do they come apart? is there an outside trim ring that screws to the inside halves or how does that work? 5) i need to replace some of the crews (at least) it's aluminum. normally i would think stainless but, not so much with aluminum. what material should replacement screws be made of? thanks, vince
Re: salon portlight replacement in cal 27 pop top
mo… [at] aol.com2016-07-10 16:25 UTC
on further examination, i see how they are put together. i can figure out where to put sealant based on what is there when i pull them apart. however, i still don't know where to find the gasket material, though. does anyone have experience with this? ---In Ca… [at] yahoogroups.com, <motorcyclejack2@...> wrote : i want to give my thanks for the guidance i got on rub rail replacement. it was a bit more difficult done on the water and by myself, i think, than it would have been on the hard with some help but, it turned out to be a job well done. now, onto the portlights. all the glass needs replaced and two leak so that i had to use tyvek tape on the outside as a temporary fix. going to be really fun removing that tape. lol. anyhow, i have a few questions about that job for those with experience. 1) where can i get replacement rubber seals? 2) where should sealant be applied? 3)silicone sealant, butyl tape (which i really love for bedding of hardware), or some other type of sealant. 4) how do they come apart? is there an outside trim ring that screws to the inside halves or how does that work? 5) i need to replace some of the crews (at least) it's aluminum. normally i would think stainless but, not so much with aluminum. what material should replacement screws be made of? thanks, vince
Re: [Cal_Boats] Re: salon portlight replacement in cal 27 pop top
Allan Neal2016-07-10 16:39 UTC
I’ve a Cal 2-29 but I just used some round stuff out of my ‘plastics material bin’, not only sealing the closure, but bending the old gasket back into place… it will most likely run black streaks down the boat and I’ll have to redo it, which is fine. I want to reduce weight with new ones at some point anyway. Best of luck Allan s/v Camlin 1975 Cal 2-29 > On Jul 10, 2016, at 12:25 PM, mo… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > on further examination, i see how they are put together. i can figure out where to put sealant based on what is there when i pull them apart. however, i still don't know where to find the gasket material, though. does anyone have experience with this? > > > > ---In Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>, <motorcyclejack2@...> wrote : > > i want to give my thanks for the guidance i got on rub rail replacement. it was a bit more difficult done on the water and by myself, i think, than it would have been on the hard with some help but, it turned out to be a job well done. > > > > now, onto the portlights. all the glass needs replaced and two leak so that i had to use tyvek tape on the outside as a temporary fix. going to be really fun removing that tape. lol. > > > > anyhow, i have a few questions about that job for those with experience. > > > > 1) where can i get replacement rubber seals? > > > > 2) where should sealant be applied? > > > > 3)silicone sealant, butyl tape (which i really love for bedding of hardware), or some other type of sealant. > > > > 4) how do they come apart? is there an outside trim ring that screws to the inside halves or how does that work? > > > > 5) i need to replace some of the crews (at least) it's aluminum. normally i would think stainless but, not so much with aluminum. what material should replacement screws be made of? > > > > thanks, > > vince > > >
bl… [at] sbcglobal.net2016-07-10 17:05 UTC
word to the wise. If you are going to use silicone, only use Marine silicone, the Home Depot stuff works but there are some extra oils or something that leave a mess on the hull. Make sure you clean up the film from the "over-smear" thoroughly and immediately.
Re: [Cal_Boats] Re: salon portlight replacement in cal 27 pop top (Vince)
Duane Knize Boat2016-07-10 17:30 UTC
Vince, Quite a while ago I bought sponge rubber o-ring material for my opening ports from Hoffmeyer, but they don't seem to carry it anymore. Here is a site I found that carries closed cell sponge in various sizes. http://www.standard-gasket.com/o-rings/prices/oring-cord-prices.htm I've also ordered gasket material from Bomar for both hatches and opening ports. https://www.pompanette.com/BigSummit/pomp.nsf/Subsites/bomar. Their size may be close enough. Good luck, Duane Duane Knize S/V Marlyn 1978 Cal 2-39 #18 berthed: Emeryville, CA kn… [at] san.rr.com On 7/10/2016 9:25 AM, mo… [at] aol.com [Cal_Boats] wrote: > > on further examination, i see how they are put together. i can figure > out where to put sealant based on what is there when i pull them > apart. however, i still don't know where to find the gasket material, > though. does anyone have experience with this? > > > > ---In Ca… [at] yahoogroups.com, <motorcyclejack2@...> wrote : > > i want to give my thanks for the guidance i got on rub rail > replacement. it was a bit more difficult done on the water and by > myself, i think, than it would have been on the hard with some help > but, it turned out to be a job well done. > > > now, onto the portlights. all the glass needs replaced and two leak so > that i had to use tyvek tape on the outside as a temporary fix. going > to be really fun removing that tape. lol. > > > anyhow, i have a few questions about that job for those with experience. > > > 1) where can i get replacement rubber seals? > > > 2) where should sealant be applied? > > > 3)silicone sealant, butyl tape (which i really love for bedding of > hardware), or some other type of sealant. > > > 4) how do they come apart? is there an outside trim ring that screws > to the inside halves or how does that work? > > > 5) i need to replace some of the crews (at least) it's aluminum. > normally i would think stainless but, not so much with aluminum. what > material should replacement screws be made of? > > > thanks, > > vince > >
mo… [at] aol.com2016-07-10 17:51 UTC
i want to go with the stock set up. if not that, i would cut the holes bigger and install opening ports. ---In Ca… [at] yahoogroups.com, <allan@...> wrote : I’ve a Cal 2-29 but I just used some round stuff out of my ‘plastics material bin’, not only sealing the closure, but bending the old gasket back into place… it will most likely run black streaks down the boat and I’ll have to redo it, which is fine. I want to reduce weight with new ones at some point anyway. Best of luck Allan s/v Camlin 1975 Cal 2-29 On Jul 10, 2016, at 12:25 PM, motorcyclejack2@... mailto:motorcyclejack2@... [Cal_Boats] <Ca… [at] yahoogroups.com mailto:Ca… [at] yahoogroups.com> wrote: on further examination, i see how they are put together. i can figure out where to put sealant based on what is there when i pull them apart. however, i still don't know where to find the gasket material, though. does anyone have experience with this? ---In Ca… [at] yahoogroups.com mailto:Ca… [at] yahoogroups.com, <motorcyclejack2@...> wrote : i want to give my thanks for the guidance i got on rub rail replacement. it was a bit more difficult done on the water and by myself, i think, than it would have been on the hard with some help but, it turned out to be a job well done. now, onto the portlights. all the glass needs replaced and two leak so that i had to use tyvek tape on the outside as a temporary fix. going to be really fun removing that tape. lol. anyhow, i have a few questions about that job for those with experience. 1) where can i get replacement rubber seals? 2) where should sealant be applied? 3)silicone sealant, butyl tape (which i really love for bedding of hardware), or some other type of sealant. 4) how do they come apart? is there an outside trim ring that screws to the inside halves or how does that work? 5) i need to replace some of the crews (at least) it's aluminum. normally i would think stainless but, not so much with aluminum. what material should replacement screws be made of? thanks, vince
mo… [at] aol.com2016-07-10 17:55 UTC
yeah. that i do know. marine products for boats. i am actually reluctant to use silicone unless it's what i should use. i prefer butyl tape. i was going to use tape to mask off the area around the ports and then, clean up is easy. ---In Ca… [at] yahoogroups.com, <blavis@...> wrote : word to the wise. If you are going to use silicone, only use Marine silicone, the Home Depot stuff works but there are some extra oils or something that leave a mess on the hull. Make sure you clean up the film from the "over-smear" thoroughly and immediately.
mo… [at] aol.com2016-07-10 17:57 UTC
---In Ca… [at] yahoogroups.com, <knized@...> wrote : thanks. i will check out those links. Vince, Quite a while ago I bought sponge rubber o-ring material for my opening ports from Hoffmeyer, but they don't seem to carry it anymore. Here is a site I found that carries closed cell sponge in various sizes. http://www.standard-gasket.com/o-rings/prices/oring-cord-prices.htm http://www.standard-gasket.com/o-rings/prices/oring-cord-prices.htm I've also ordered gasket material from Bomar for both hatches and opening ports. https://www.pompanette.com/BigSummit/pomp.nsf/Subsites/bomar https://www.pompanette.com/BigSummit/pomp.nsf/Subsites/bomar. Their size may be close enough. Good luck, Duane Duane Knize S/V Marlyn 1978 Cal 2-39 #18 berthed: Emeryville, CA knized@... mailto:knized@... On 7/10/2016 9:25 AM, motorcyclejack2@... mailto:motorcyclejack2@... [Cal_Boats] wrote: on further examination, i see how they are put together. i can figure out where to put sealant based on what is there when i pull them apart. however, i still don't know where to find the gasket material, though. does anyone have experience with this? ---In Ca… [at] yahoogroups.com mailto:Ca… [at] yahoogroups.com, <motorcyclejack2@...> mailto:motorcyclejack2@... wrote : i want to give my thanks for the guidance i got on rub rail replacement. it was a bit more difficult done on the water and by myself, i think, than it would have been on the hard with some help but, it turned out to be a job well done. now, onto the portlights. all the glass needs replaced and two leak so that i had to use tyvek tape on the outside as a temporary fix. going to be really fun removing that tape. lol. anyhow, i have a few questions about that job for those with experience. 1) where can i get replacement rubber seals? 2) where should sealant be applied? 3)silicone sealant, butyl tape (which i really love for bedding of hardware), or some other type of sealant. 4) how do they come apart? is there an outside trim ring that screws to the inside halves or how does that work? 5) i need to replace some of the crews (at least) it's aluminum. normally i would think stainless but, not so much with aluminum. what material should replacement screws be made of? thanks, vince
