5 messages2016-07-26 01:59 UTCthrough 2016-07-26 13:07 UTC
Yanmar ysm8...
TD2016-07-26 01:59 UTC
...still at it.
Yes, my lovely 2-25, Resa, is still afloat but she's not been under sail in some time.
You know, i guess there are no good diesel mechanics in my area.
"Oh. You touched it? We dont want to work on it then"
Ok..fine.
So, to the group.
Anyone have experience with the injection pump or this engine and will talk with me on a phone call?
New valves and head work
Lash set to .008
All new gaskets
New injector
New exhaust elbow
New Racor
New engine filter
Bled fuel and it gets fuel to the injector
Makes compression. I can hardly crank it when the release is closed.
Spraying propane, wd or ether..pick your choice..into intake doesnt light it off.
Yes, Joe. I've tried all three. (Ducking as you throw a wrench at me)
What am i missing...besides a running engine?
Thanks.
I'm in Monterey, CA. I bought her last October to learn to sail. Got out a few times and now i'm learning the equally important diesel mechanics.
...tom
RE: [Cal_Boats] Yanmar ysm8...
Peter Ford2016-07-26 02:38 UTC
Have you talked with a shop that does rebuilding/refurbishment of injection pumps and injectors? Perhaps the guys that you bought the injector from?
(note: I am no diesel expert, but if I had done all you had done on that motor I would have sent the injection pump out for inspection and refurbishment. In the Bellingham WA area there is Northland Diesel Service. )
Clean airway and filter?
And for a 25, I would consider an outboard ... Let us know if you decide to sell your YSM ... :-)
cheers, peter
Date: Mon, 25 Jul 2016 18:59:13 -0700
Subject: [Cal_Boats] Yanmar ysm8...
...still at it.
Ok..fine.
So, to the group.
Lash set to .008
All new gaskets
New injector
New exhaust elbow
New Racor
New engine filter
Thanks.
...tom
Re: [Cal_Boats] Yanmar ysm8...
Bob Guarino2016-07-26 06:54 UTC
Wow you have done a lot to that engine. Just a few notes about what I experienced in case they help. Mine cranked over an would not start after replacing filters and rebuilding injectors. Remember that diesels have to warm the cylinder before it's going to fire. Charge your battery's up all the way. I thought mine were good but when I charged them I got it to fire. I also found the new Racor filter I put on was too fine a filter. It clogged. The Racor is supposed to be the first filter and a larger micron than the one on the engine. I had crap growing in my tank that kept clogging filters. I had to remove my fuel and clean my tank also. Once I'd cleaned the fuel, replaced the filters a second time, bled everything, charged my battery's I got her to fire! Best of luck
Bobby G
Cal-2 30
> On Jul 25, 2016, at 4:38 PM, Peter Ford pe… [at] hotmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> cheers, peter
> From: Ca… [at] yahoogroups.com
> ...still at it.
> Ok..fine.
> So, to the group.
> Lash set to .008
> All new gaskets
> New injector
> New exhaust elbow
> New Racor
> New engine filter
> Thanks.
> ...tom
NEWMAN2016-07-26 13:03 UTC
Diesels start from heat of compression. A nice and tight (good compression)
diesel will start very quickly on a warm day provided it has fuel injected
and air. To me is sounds like maybe your engine is not in time. Did you
remove the injector pump ever? I have never had to go into my Yanmar, but I
have done some major work on my antique Caterpillar bull dozers. They are
very old slow turn diesel engines with no glow plugs and injector pumps for
each cylinder. Very rare the injector pumps fail. My machine is over 60
years old and starts and runs fine. All I do is keep the fuel system clean.
Before doing much more brute force to your engine with ether and such.
triple check the timing for everything. Hopefully you have not dorked
around with the injector pump timing in any way, if that can be screwed up
on a Yanmar. I don't have my service manual here, it's on my boat. I know
my old Cats have to have their rack and injector pumps timed if you screw
with them.
Once I had an old Cat that I was not sure the nozzle was spraying
correctly. I actually took the nozzle out of the head and spun the injector
line around so I could connect the nozzle and have it spray off to the
side into a bucket. Then turned over the engine and verified that I was
truly getting a good spray of atomized fuel.
Your engine needs to have the valves open at the correct time. Intake
opens, air comes in. And while the piston is coming up the injector needs
to squirt and the valves are closed when piston is in the firing position.
If you have all that correct and good compression the engine should fire.
On Tue, Jul 26, 2016 at 2:54 AM, Bob Guarino hr… [at] yahoo.com
> Bobby G
> Cal-2 30
> Sent from my iPhone
> injector from?
> Service. )
> cheers, peter
> ...still at it.
> in some time.
> Ok..fine.
> So, to the group.
> Lash set to .008
> All new gaskets
> New injector
> New exhaust elbow
> New Racor
> New engine filter
> it off.
> Thanks.
> ...tom
NEWMAN2016-07-26 13:07 UTC
Also, don't have the fresh water intake open when you are cranking alot.
You could get some water into the cylinders and water will not compress.
You will bend a rod. I know of someone with an old Cat that had a head
gasket leaking water into the cylinder and he bent a rod. If it is having
trouble turning over, that does not sound right. Makes me wonder if you
have it flooded in some way or something. You force it to turn over with
liquid in the cylinder and you are going to damage your engine.
Leslie Newman
Puffin (Cal 33-2)
> compression) diesel will start very quickly on a warm day provided it has
> fuel injected and air. To me is sounds like maybe your engine is not in
> time. Did you remove the injector pump ever? I have never had to go into my
> Yanmar, but I have done some major work on my antique Caterpillar bull
> dozers. They are very old slow turn diesel engines with no glow plugs and
> injector pumps for each cylinder. Very rare the injector pumps fail. My
> machine is over 60 years old and starts and runs fine. All I do is keep the
> fuel system clean.
> with them.
>> Bobby G
>> Cal-2 30
>> Sent from my iPhone
>> injector from?
>> Service. )
>> cheers, peter
>> ...still at it.
>> in some time.
>> Ok..fine.
>> So, to the group.
>> Lash set to .008
>> All new gaskets
>> New injector
>> New exhaust elbow
>> New Racor
>> New engine filter
>> it off.
>> Thanks.
>> ...tom
