Re: [Cal_Boats] Hood Continuous Line Furler: Need Parts For 705LD
2 messages2016-09-23 00:33 UTCthrough 2016-09-23 19:17 UTC
Sailorman2016-09-23 00:33 UTC
No, Pompannette has quite a few parts available for the older LD continuous furlers but not this Feed Extrusion. The way that those are built, this is the lowest section of the foil (where the slot begins to feed the sail into the slot) and mates to the turnbuckle tube (plain tube above drum) through the two-piece tack socket. If you think you may have one, feel free to call me and we can figure it out. It should be about 1 1/4 in diameter. Greg Murphy 616-304-2345
Jraxter2016-09-23 19:17 UTC
Ok, dug out the old part. Mine is a 800 series for our cal 33. Top tube diameter is 2" OD. John Raxter 336-210-8073 (m) > On Sep 22, 2016, at 8:33 PM, 'Sailorman' sa… [at] mascom.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > No, Pompannette has quite a few parts available for the older LD continuous furlers but not this Feed Extrusion. > > > > The way that those are built, this is the lowest section of the foil (where the slot begins to feed the sail into the slot) and mates to the turnbuckle tube (plain tube above drum) through the two-piece tack socket. > > > > If you think you may have one, feel free to call me and we can figure it out. It should be about 1 1/4 in diameter. > > > > Greg Murphy > > 616-304-2345 > > > > > >
