7 messages2016-10-25 18:15 UTCthrough 2016-10-25 21:11 UTC
Chris - Boat work - was Took Puffin out in 20 knot winds
pw… [at] aol.com2016-10-25 18:15 UTC
Chris -
I always thought working on diesel engines in sailboats was a royal pain in the arse but then I was talking to my car mechanic, who is also a sailor, and he told me about changing a starter in a V-8 Lexus and how it is underneath the friggin intake manifold and to get the bolts out he had to use 8 feet of extensions and go in from above the rear axle !!!!!. Coincidentally this meme showed up in my Facebook feed 2 days later and there it is. I showed this to my mechanic and he said this one is different than the Lexus he worked on so it's possible more than one car has this same design!! Ugh . . .
Paul West
Adventure Kwest
Cal 39
From: ccampbell cc… [at] lsnm.org [Cal_Boats] <Ca… [at] yahoogroups.com>
To: Cal_Boats <Ca… [at] yahoogroups.com>; NEWMAN <d2… [at] gmail.com>
Sent: Mon, Oct 24, 2016 5:00 pm
Subject: Re: [Cal_Boats] Took Puffin out in 20 knot winds
On 10/24/2016 4:43 PM, NEWMAN d2… [at] gmail.com [Cal_Boats] wrote:
Season is still going strong in Va. Wife and I took Puffin out yesterday in a nice blow. Some friends in a Pearson 31 following.
https://www.youtube.com/watch?v=0NAOkrOtAY8
Well aren't you lucky! I was changing the oil on my Ranger pickup. The oil filter dribbles all over your arm when you remove it. The oil pan drain pees sideways. What genius invented that design? Then I changed the coolant in the old Mustang GT. The V-8 has two block drains, located in almost inaccessible places. You can reach them if you're lying under them. @#%$&**!!!! What fun. My theory is that engineers who design automotive stuff should be sentenced to service the things they designed, maybe as a condition for an application to enter heaven.
I would rather be sailing. But at least I got the chores done.
Cal 20 Martha C
Re: [Cal_Boats] Chris - Boat work - was Took Puffin out in 20 knot winds
Jraxter2016-10-25 20:22 UTC
Yes, engineers need real world experience before they finalize designs.
I had a S10 pick-up 4wd, skid pads below and exhaust and brake line blocked access from above. You could see the oil filter, but couldn't touch it from either direction. Finally discovered if you lifted the front end to where the tires were off the ground, there was a flap inside the wheel well to put a wrench on the end. I thought it right clever. Until I removed the filter and it drained about a quart onto the lower skid pan, and the drain plug on the pan, drained fine thru the access hole, except the last quart which combined with the oil filter spill. Grrrrrr, £\€|*{!¥ engineers!
My Miata oil filter, Pita would drain oil when loosened onto the front cross support, loosen and lay on the cross member from below. The reach in from above and wiggle out between the engine and wheel well. Grrrrr, f+=*?! Japanese engineers.
Now the yanmar on the cal 33, no drain plug in the pan. Ok, a pump thru the dipstick tube works. Then the filter, horizontal mount, is behind the engine mount. Leaked oil drips down the block onto the engine mount. Yanmar recommends replacing the mounts every 5 years due to oil weakening the rubber mount. Grrrrrrr, engineers!
Cars dripping oil is not a big problem. Trying to keep the boat engine compartment oil free is a chore.
Ymmv
John Raxter
> On Oct 25, 2016, at 2:15 PM, pw… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Chris -
> Paul West
> Adventure Kwest
> Cal 39
> <why-mechanics-hate-engineers-damn-thats-a-tight-spot-lol-3967616.png>
> -----Original Message-----
> Chris Campbell
> Cal 20 Martha C
Marine engine oil pans [ was Re: [Cal_Boats] Chris - Boat work - was Took Puffin out in 20 knot winds
Joe DeMers2016-10-25 20:37 UTC
Marines engines lost their oil pan drains due to some owners draining
oil into the bilge, then pumping it overboard. They also lost the
decompression devise due to liability.
*Joe DeMers - owner*
Sound Marine Diesel LLC
(860) 666-2184
> Ymmv
> John Raxter
> On Oct 25, 2016, at 2:15 PM, pw… [at] aol.com <mailto:pw… [at] aol.com>
> <mailto:Ca… [at] yahoogroups.com>> wrote:
>> Chris -
>> Paul West
>> Adventure Kwest
>> Cal 39
>> From: ccampbell cc… [at] lsnm.org <mailto:cc… [at] lsnm.org>
>> <mailto:Ca… [at] yahoogroups.com>>; NEWMAN <d2… [at] gmail.com
>> <mailto:d2… [at] gmail.com>>
>> <https://www.youtube.com/watch?v=0NAOkrOtAY8>
>> enter heaven.
>> Chris Campbell
>> Cal 20 /Martha C/
(860) 666-2184*
ccampbell2016-10-25 20:50 UTC
It's not a problem unless you're lying on your back underneath, as I am
when doing the oil or coolant change. At least in the boats, you're
looking DOWN on it. Gravity is your friend.
I had a college roommate once whose idea of fun was shopping for
clothes. His dad owned an old gas station with a hydraulic lift. The
roommate couldn't care less about that hoist. I was so jealous; I
figured that having your own was as close to heaven as one could get.
We had different values. Eventually I learned that old gas station =
leaking underground tanks = liability, so I've never acquired my own,
but I still have fantasies about my very own hydraulic lift. The
fantasies attack with special strength whenever I'm lying on the ground
under the truck, or worse, under the Mustang, trying the get the @#&*!!
hex key on the block drains or the @#&$*!! oil filter off with oil
running down my arm and all over the suspension.
Long ago I had a '62 Corvair, bought very used and driven very hard by
me, a faithful and fun old heap. It didn't just drip oil. It left a
signature puddle from that rear main bearing seal. Not a "big problem"
unless I was in somebody's clean driveway!
Of course, boat ownership has its own special thrills, like sanding and
painting the bottom.
Re: Marine engine oil pans [ was Re: [Cal_Boats] Chris - Boat work - was Took Puffin out in 20 knot winds
ccampbell2016-10-25 20:51 UTC
But if the alternative is using a dipstick pump, then pumping overboard
becomes a one-step process, not two....
NEWMAN2016-10-25 20:56 UTC
I have a small plastic catch jar I use to capture the oil from the oil
filter on the Yanmar in my Cal 33. Still a pita that I must do that, but
keeps the oil from running down on stuff.
I've been trying to remember the worst design. Changed the spark plugs for
a friend on their Chevy Impala. I think a late 90's model. You have to
remove a motor mount so you can then take a ratchet strap and pull the
engine forward so you can then lay on top the motor and get at the three
plugs on the firewall side.
My 04 Nissan Xterra I had...spark plugs are way down under the intake.
Can't hardly see the back one. Just feel with fingers. Several extensions
and a universal, all duck taped together so they don't come apart just to
change the plugs.
Easiest machines I have to work on....my 1973 Ford Bronco, my 1977 Toyota
FJ40. My 1949 D2 Caterpillar.
On Tue, Oct 25, 2016 at 4:22 PM, Jraxter jr… [at] triad.rr.com [Cal_Boats] <
> Ymmv
> John Raxter
> Chris -
> Paul West
> Adventure Kwest
> Cal 39
> Chris Campbell
> Cal 20 *Martha C*
NEWMAN2016-10-25 21:11 UTC
Chris,
I too had the dream of having a lift, which only took 56 years to come
true. And it is as much a joy as is imagined. I installed a lift in my shop
in 2015 and love it. Bought a Worth brand from Worth in Texas. Great lift,
just horrible customer service after the purchase. Luckily the thing is
built like a tank. Just was missing some knobs that Worth took about two
months to get to me.
http://i1363.photobucket.com/albums/r716/gary__seven/Bronco%20Throw%20out%20bearing/Bearing2_zps8qzazmsn.jpg
On Tue, Oct 25, 2016 at 4:50 PM, ccampbell cc… [at] lsnm.org [Cal_Boats] <
> I had a college roommate once whose idea of fun was shopping for clothes.
> His dad owned an old gas station with a hydraulic lift. The roommate
> couldn't care less about that hoist. I was so jealous; I figured that
> having your own was as close to heaven as one could get. We had different
> values. Eventually I learned that old gas station = leaking underground
> tanks = liability, so I've never acquired my own, but I still have
> fantasies about my very own hydraulic lift. The fantasies attack with
> special strength whenever I'm lying on the ground under the truck, or
> worse, under the Mustang, trying the get the @#&*!! hex key on the block
> drains or the @#&$*!! oil filter off with oil running down my arm and all
> Long ago I had a '62 Corvair, bought very used and driven very hard by me,
> a faithful and fun old heap. It didn't just drip oil. It left a signature
> puddle from that rear main bearing seal. Not a "big problem" unless I was
> Chris Campbell
