Re: [Cal_Boats] JEMA Cal 21ft 1972 Hull 222
Check out www.cal21.com for some ideas. The CAL 21 is a great little CAL,
not the most convenient boat if you plan to trailer her for a short sail,
due to the way the keel retracts, but a GREAT boat if you want a boat
that will sail like a cruiser-racer but easily fit on a trailer to store
i your backyard (or driveway)! If you are planning to sail on a body of
water with a lot of shoals, where the 4'3" draft will limit your sailing,
or as I say, if you want a boat that can be quickly launched and sailed
away, then quickly pack up and trail home....... well, the CAL 21 may not
be your best choice. We owned our 1970 CAL 21 (Hull#285) for 38 years,
enjoyed her tremendously, my Sister and I grew up sailing on this boat, I
can't tell you how many great memories our family has from those days,
but we kept her on a mooring all Summer, kept her at a boatyard o na
cradle with the keel retracted for the winter. The process of raising the
keel prior to haul out and then lowering in the Spring after launching
worked fine for us, the need to tow a dinghy if we went ashore anywhere
just added to the "big boat" feel of the boat for us. I really can't stop
praising the CAL 21, but like al l retractable keel boats, the CAL 21
keel must be locked down while sailing to get best performance and
safety. The great part about the CAL 21 keel setup is that once down and
locked, you unhook the cable, insert a plug (long plank really) in the
keel well to mostly close off the bottom of the opening and then secure a
cover over the opening in the cockpit sole, and she becomes a virtual
"fixed-keel" boat, a deep, fin-keel and this makes her a great nimble
sailer. However, despite the sales brochure claims of being able to sail
away 15 minutes after arriving at the ramp, I would estimate the
launching process will take more like an hour (once you get good at it)
from arrival to sail away. Haul out will be about the same, and
realistically..... I'd plan to allow more time just in case. Unhooking
the cable from the keel means no classic cable "hum" while sailing, no
risk of getting a lobster or crab pot line caught on the cable, less
drag..... but the water better be clear when you try to re-hook the cable
onto the keel upon your return to the ramp so you can see the tip of the
keel to hook the cable loop, and don't even ask what happens if you get
it "almost hooked" then try to raise the keel!
I don't want to discourage you, as I say, I am a BIG fan of the CAL 21,
but I just want to inject a little advice that as much as I adore the 21,
she isn't as well setup for casual trailer-sailing as her competition
(Venture 21, Kells 23, Catalina 22, Balboa 20, Ensenda 20, Clipper 21,
etc) You can't really sail her up to a beach like a centerboard boat.
I will take a look at the pictures that you posted, I REALLY like to see
other CAL 21s! But, before looking.... I'll tell you that as long as you
can get good quality exterior (or batter yet, Marine) plywood, and can
use the original parts as patterns, and if your skills with woodworking
and fiberglass are up to the task (you will learn a lot rebuilding a
boat, I know.... I've done it!) a CAL 21 project is not major
complicated. Check out that web-site that I mentioned, as well as the
threads about the CAL 21 on the Sailnet Cal Forum (I've posted a lot
there as well as at cal21.com) Don't rush, you will lend up with a nice
boat. Will you be able to sell her for more than you will spend
rebuilding? Most likely not, but you will know every detail of the
repairs, and get that satisfaction. As Reggie says, if you can do it
yourself, you should get a good boat for only a little more (and maybe,
just slightly less?) than a ready to sail boat that may not be as nice.
If you aren't sure of the project, then keep looking and find a boat that
is "ready to sail" or pretty close to it, the final costs will be worth
it, but it you really want a CAL........ and don't mind the less than
quick launch/haul process........ The CAL 21 is a great design. Of
course, I will echo what others have admitted, some of the most expensive
boats around are those given away "FREE".
I rebuilt a 14' powerboat 20 years ago, she was FREE, I ended up spending
around $3000.00 +/- including new outboard (9.9 hp) and trailer, I might
have been able to find another boat "ready to use" for less, but I
couldn't have found a NEW boat for less than $10K that would compare to
my $3K rebuilt boat! I did all the work myself, bought my plywood
(exterior grade mostly) at Home Depot, fiberglass supplies from Defender
and a local store. Would I do it again? Not sure, maybe a sailboat this
time, one enough bigger than my 17' Day Sailer to have a real cabin and
room for a galley and head (of course, being a former CAL 21 owner/crew
member.... my idea of a "real" cabin may be less than most people!). But,
I've found that several boats that I looked at (on-line) weren't as good
bargains after I added up what was needed and added the cost to the "low"
asking price........ There is presently a 19' Sailstar Voyager on my
local Craig's-List, she is listed as "FREE", could buy the sails and
spars from the seller for another $200. However, she is in the water (I
think?) and with a 3' fin-keel, will need a boat hauler to move to my
house, suddenly that Free boat becomes at least $500+ (still a good
deal......... but more than I can afford at this time).
Anyway, I'll look at your pics and see if I see anything glaringly wrong.
In the meantime, feel free to ask me any CAL 21 questions that you may
have, 38 years of experience has given me plenty of knowledge!
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II #10201
Former co-owner of "NODROG"
1970 CAL 21 #285
On Sun, 6 Nov 2016 15:05:37 +0000 "r good my… [at] hotmail.com
you can find inexpensive but appropriate ways to repair anything on the
boat id you do it yourself and are not in a hurry. And, most
importantly, you will learn SO MUCH in the process that it is definitely
worth the effort and time. And, the boat will truly be yours. If you
ever intend to do a significant amount of sailing, rebuilding this boat
yourself will be the best investment you ever make.
If you have to hire it done, forget it and save up for a new boat.
lessons learned from 6 boats. Currently own Cal 27 T/2 "Knot Ready"
sailed on Flathead Lake, MT, and Cal Cruising 36 "Submit waiting for us
on a mooring in George Town, Exumas, Bahamas
Sent from Outlook
From: Ca… [at] yahoogroups.com <Ca… [at] yahoogroups.com> on behalf of
david howe tr… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com>
Sent: Sunday, November 6, 2016 5:30 AM
To: Ca… [at] yahoogroups.com; la… [at] yahoo.com
Subject: Re: [Cal_Boats] JEMA Cal 21ft 1972 Hul 222
I've got an initially inexpensive boat that's not so inexpensive anymore!
Guy at the marina said "most expensive boat I ever owned was give to me"
But forget all that and go for it! Where's it at, I'll take it..
Sent from Yahoo Mail for iPhone
On Sunday, November 6, 2016, 5:49 AM, la… [at] yahoo.com [Cal_Boats]
<Ca… [at] yahoogroups.com> wrote:
[Attachment(s) from la… [at] yahoo.com [Cal_Boats] included below]
Was given his boat and I am wondering if it is worth my time to redo all
the wood damaged? It seems like a lot of work but am I in over my head.
Here are some pics. I do have plenty more pics. Let me know what you guys
think.
How To Fix Your Fatigue (Do This Every Day)
gundrymd.com
http://thirdpartyoffers.juno.com/TGL3141/581fd50f5b96e550f7a78st03duc
