8 messages2016-12-03 23:20 UTCthrough 2016-12-09 16:00 UTC
Spread boot size for Cal 27 Mark III?
David Field2016-12-03 23:20 UTC
Before climbing the mast with the wrong size speader boots for my Cal 27 Mark III, I'd like to confirm that they're the medium size. Thanks for any responses!DavidCal 27 Mark III
RE: [Cal_Boats] Spread boot size for Cal 27 Mark III?
Charlie Husar2016-12-04 22:56 UTC
David, if you have pole spreaders, the boots would be medium. When you tape them, don’t make it super tight. The shroud has to be able to slide through for rig adjustment purposes.
Best of Luck
Annapolis
Sent: Saturday, December 03, 2016 6:21 PM
Subject: [Cal_Boats] Spread boot size for Cal 27 Mark III?
David
Cal 27 Mark III
Re: [Cal_Boats] Spread boot size for Cal 27 Mark III?
David Field2016-12-04 23:56 UTC
Thanks Charlie for the taping suggestion! Medium it is. Now for another question: I checked the spread boots from West Marine... which include Sea Dog at $27.99 and Taylor Made at $38.99. And then, from Wholesale Marine a pair of
Whitecap Rubber Spreader Boot - Pair - Medium - White for $11.46. Generally I kinda feel I'm getting more for my money if I spend more. But spreader boots? What do you think?
David
On Sunday, December 4, 2016 6:03 PM, "'Charlie Husar' hu… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
David, if you have pole spreaders, the boots would be medium. When you tape them, don’t make it super tight. The shroud has to be able to slide through for rig adjustment purposes. Best of LuckCharlie Annapolis From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]
Helen Horn2016-12-05 05:18 UTC
mostly the boots are to protect your sails from injury, you want to allow moisture to pass through, not get trapped in the tips and wire shrouds. You also probably need to know how those different types of material stand up to UV light. Some riggers even use leather. Helen
On Sunday, December 4, 2016 3:59 PM, "David Field fi… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
David
Gerald Sobel2016-12-05 07:31 UTC
Charlie,Gulp! You don't say..so..the moly wire I wrapped around the shrouds to keep them in the spreader groove..I guess you're saying...that has to allow shroud movement as well? I just securely rubber-taped my falling apart boots last month. Maybe I should re-boot me boots?! Time to drop me mast again. Hopefully the step ladder doesn't get knocked over and ends up sunk in the muck below the docks this time around. Sheeessshhh!!Jerry of Ye Olde Shpritz. Cal 24 Mk-1
On Sunday, December 4, 2016 9:19 PM, "Helen Horn he… [at] sbcglobal.net [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
David
Charlie Husar2016-12-05 15:53 UTC
Hi, Jerry. As usual, you are 1.0334 (± .0002) steps ahead of me. I was going to send out a follow-on message about the moly wire.
BTW, most of what I recommend, I learned by screwing it up at least once. I should attach date stamps to my screw-ups. Two items on the moly wire:
Make sure the wire ends are pointed inward or somehow hidden. I once ripped two jibs in one race because the moly wire end poked out through the spreader boot.
Yes, do not make the wire too tight. When the shroud is wired and the boot is taped, you need to be able to pull the shroud back and forth through the boot. I once had to do the Cal 25 dock mast drop (patent pending – photos available) 3 times (yes, count ‘em 3) because first we led the backstay wrong, and the then we had taped the spreader boots too tight. Couldn’t pull the shroud through the boot when re-standing the mast.
Good word from Helen on the trapped water. With the tape a little looser, you get better drainage. Also see note below. Timmo recommends leather boots. Of course, he sails 2,558 miles at a time. My trips are slightly more humble. I find the rubber boots to be durable enough. Look for UV protection. BTW, high quality vinyl electrical tape (say 3M 33+ or Super 88 – or if you MUST have colors, 35, but not as good) makes a very suitable rigging tape.
David, watch out for the terms “small”, “medium”, “home laundry size”, and the like. Different vendors have different sizes for the “medium” spreader hole. The spreaders on my Cal 25 are 1-1/4 inches in diameter. Yours might be that or 1.5”. Look for the diameter specs on the boot. I think mine are Taylor Made medium.
Here is a note from one spreader boot vendor: NOTE: Because rigging diameter and spreader styles vary widely, a precise fit is unlikely. Riggers prefer a slight gap in boot to allow for drainage and prevent corrosion. Rubber may also be trimmed to size to prevent overlap.
Why is nothing ever simple?
Annapolis
Cal 25 and Cal 40
Sent: Monday, December 05, 2016 2:32 AM
To: Ca… [at] yahoogroups.com; Helen Horn <he… [at] sbcglobal.net>
Subject: Re: [Cal_Boats] Spread boot size for Cal 27 Mark III?
Charlie,
On Sunday, December 4, 2016 9:19 PM, "Helen Horn he… [at] sbcglobal.net <mailto:he… [at] sbcglobal.net> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
On Sunday, December 4, 2016 3:59 PM, "David Field fi… [at] yahoo.com <mailto:fi… [at] yahoo.com> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
David
On Sunday, December 4, 2016 6:03 PM, "'Charlie Husar' hu… [at] gmail.com <mailto:hu… [at] gmail.com> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
Best of Luck
Annapolis
From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com]
David
Cal 27 Mark III
Allen Edwards2016-12-05 16:54 UTC
On my old mast I used tape. They affectionately call it million dollar
tape because it is very expensive. No mast boot. The tape covered the
wire and gave a very low friction surface for the sail. My new mast has
spreaders 3 inches in from where the old ones were so will be less likely
to be hit by the jibs perhaps. The spreaders are also attached differently
so this is all new to me. (The old mast was wood, the new one aluminum).
Wondering if the tape is still the way to go or if I need to do something
else.
On Mon, Dec 5, 2016 at 7:53 AM, 'Charlie Husar' hu… [at] gmail.com
> spreader boot.
> rigging tape.
> Here is a note from one spreader boot vendor: *NOTE:* Because rigging
> Cheers
> Charlie
> Annapolis
> Cal 25 and Cal 40
> *Sent:* Monday, December 05, 2016 2:32 AM
> *To:* Ca… [at] yahoogroups.com; Helen Horn <he… [at] sbcglobal.net>
> *Subject:* Re: [Cal_Boats] Spread boot size for Cal 27 Mark III?
> Charlie,
> pair of
> spreader boots? What do you think? David
> Best of Luck
> Charlie
> Annapolis
> <Ca… [at] yahoogroups.com>]
> *Sent:* Saturday, December 03, 2016 6:21 PM
> *Subject:* [Cal_Boats] Spread boot size for Cal 27 Mark III?
> responses!
> David
> Cal 27 Mark III
ccampbell2016-12-09 16:00 UTC
On 12/5/2016 2:31 AM, Gerald Sobel so… [at] yahoo.com [Cal_Boats] wrote:
> Charlie,
My other boat has spreaders that attach to the mast via a hinged
fitting, allowing motion up and down. The ideal spreader position is
one that makes the spreader bisect the angle the shroud makes when the
spreader pokes into it. The spreaders make a slight "V" when seen from
forward or aft. I _want_ my spreader tips to be fixed on the shroud
wire. I've got stainless wire, tightly wrapped by a funny little gadget
that my brother gave me for using wrapped wire as a clamp (can't recall
the name). It's below and above the spreader, trapping it on the shroud.
My Cal 20 has hinges too, so I did the same thing on it--tightly wrapped
stainless that traps the spreader tip and holds it in position.
I've seen neglected boats that had drooping spreaders. They had relied
on shroud tension to hold spreader tips in place. The shrouds had become
loose as the turnbuckles unscrewed from wave action, and the hinged
spreaders slid right down, obeying gravity.
