2 messages2016-12-30 23:18 UTCthrough 2016-12-31 01:16 UTC
Re: [Cal_Boats] Re: tankage
Charlie Husar2016-12-30 23:18 UTC
Strange, Reggie, I never got any of your drawings or photos in my E-Mails.
Curiosity on my part. Are there typically baffles installed in tanks that
long (4 feet)?
Strikes me that couple 5 gallon jerry cans would be easier than the cross
coupling system?
Take Care
HNY
Sent: Friday, December 30, 2016 12:05 PM
To: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> ; Charlie
Husar <hu… [at] gmail.com <mailto:hu… [at] gmail.com> >
Subject: Re: [Cal_Boats] Re: tankage
the tank is oriented in the boat as you see it on port side of centerline.
bottom pf picture is aft.
When the fuel tank in our CC#^ began leaking some years ago, PO removed it
and had two smaller tanks manufactured to install in place of the one large
U shaped original tank. Curiously, no fuel is drawn from this tank by the
engine. All engine fuel is drawn from the starboard tank and there is a
cross fill from the near bottom of this tank to the starboard tank, as seen
on the picture.
This tank has an external sight tube for fuel level. the starboard tank has
no fuel level indicator of any kind! So, this tank acts as a supplemental
tank. AND, the fuel fill connects only to this tank, so, to fill the
starboard tank, you must make sure to have the cross fill open while
fueling. both tanks vent through a single vent hose. It was an
interesting system to learn and we didn't get any instructions from PO.
Sent from Outlook <http://aka.ms/weboutlook>
From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
<Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > on behalf of
'Charlie Husar' hu… [at] gmail.com <mailto:hu… [at] gmail.com> [Cal_Boats]
Sent: Friday, December 30, 2016 6:45 AM
Subject: RE: [Cal_Boats] Re: tankage
Hi, All. In approximate agreement with a number of other responses, here's
what I got from plugging in the arithmetic.
5320.8 cu in
3.1 cu ft
23.0 gal (US) ignoring small thermal expansion factor
161.2 lbs (diesel - gasoline is lighter, water heavier)
My bigger questions are:
What is the orientation of the tank when installed? Any space in the tank
above the fill port cannot be used.
What is the ability of the installed tank frame to hold the weight in place?
The heel of the boat will have an effect on how much fuel can actually be
used - like in motor sailing. Don't want to run the tank to zero anyway.
Happy New Year
Annapolis
Cal 25 (no internal fuel tank)
[mailto:Ca… [at] yahoogroups.com]
Sent: Friday, December 30, 2016 7:59 AM
Subject: [Cal_Boats] Re: tankage
If I've done my math correctly, the max it could hold is 23.6 gal.
r good2016-12-31 01:16 UTC
open the two 1 1/4" valves and fuel flows.
reggie
Sent from Outlook<http://aka.ms/weboutlook>
From: Ca… [at] yahoogroups.com <Ca… [at] yahoogroups.com> on behalf of 'Charlie Husar' hu… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com>
Sent: Friday, December 30, 2016 4:18 PM
Curiosity on my part. Are there typically baffles installed in tanks that long (4 feet)?
Strikes me that couple 5 gallon jerry cans would be easier than the cross coupling system?
Take Care
HNY
To: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>; Charlie Husar <hu… [at] gmail.com<mailto:hu… [at] gmail.com>>
the tank is oriented in the boat as you see it on port side of centerline. bottom pf picture is aft.
When the fuel tank in our CC#^ began leaking some years ago, PO removed it and had two smaller tanks manufactured to install in place of the one large U shaped original tank. Curiously, no fuel is drawn from this tank by the engine. All engine fuel is drawn from the starboard tank and there is a cross fill from the near bottom of this tank to the starboard tank, as seen on the picture.
This tank has an external sight tube for fuel level. the starboard tank has no fuel level indicator of any kind! So, this tank acts as a supplemental tank. AND, the fuel fill connects only to this tank, so, to fill the starboard tank, you must make sure to have the cross fill open while fueling. both tanks vent through a single vent hose. It was an interesting system to learn and we didn't get any instructions from PO.
From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>> on behalf of 'Charlie Husar' hu… [at] gmail.com<mailto:hu… [at] gmail.com> [Cal_Boats] <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>>
Hi, All. In approximate agreement with a number of other responses, here's what I got from plugging in the arithmetic.
5320.8 cu in
3.1 cu ft
What is the orientation of the tank when installed? Any space in the tank above the fill port cannot be used.
What is the ability of the installed tank frame to hold the weight in place? The heel of the boat will have an effect on how much fuel can actually be used - like in motor sailing. Don't want to run the tank to zero anyway.
Happy New Year
Annapolis
From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com]
