Re: 1980 Cal 39 Toe Rail replacement.
3 messages2016-12-31 17:10 UTCthrough 2016-12-31 20:41 UTC
Thomas Bridge2016-12-31 17:10 UTC
I think you could use cedar. Yes it is soft, depending on the kind of cedar. But you could could work with those issues with larger bung holes and a washer under your through bolt, as well as a epoxy saturation when done for surface hardness. Or, it just wouldn't hold up as well as harder wood. You could use clear fir as well. Lots of boats built with fir. It likes to split, so you would need to be careful. Tom
sw… [at] yahoo.com2016-12-31 17:37 UTC
TT The Port Orford cedar is what i was looking at and it has a long history in ship building. The plan was to teak oil it the varnish when finished and install. I was just reading that Doug Fir clear is also a good choice as well so i need to look into that as well. I don't claim to know all there is on this I am learning along the way and have so far received to great information on this. Thanks
Re: [Cal_Boats] Re: 1980 Cal 39 Toe Rail replacement.
Edward Stancil2016-12-31 20:41 UTC
Go with metal ..Edward in Panama Waiting for Crew and Canel. Happy new years eve On Sat, Dec 31, 2016, 12:37 PM sw… [at] yahoo.com [Cal_Boats] < Ca… [at] yahoogroups.com> wrote: > > > TT > > The Port Orford cedar is what i was looking at and it has a long history > in ship building. The plan was to teak oil it the varnish when finished and > install. I was just reading that Doug Fir clear is also a good choice as > well so i need to look into that as well. I don't claim to know all there > is on this I am learning along the way and have so far received to great > information on this. > > Thanks > >
