15 messages2017-01-31 16:40 UTCthrough 2017-02-03 00:26 UTC
RE: [Cal_Boats] Re: 25-2 mast base
TomDressler2017-01-31 16:40 UTC
Cal 25-2 mast base.
Sent: Saturday, January 28, 2017 10:36 AM
Subject: [Cal_Boats] Re: 2-5 mast base
Can you send me a pic of your collapsed step? My step looks kind of weird and I want to be sure that's its not the same issue.
Bill
Pass'n Gas
Cal 28
Monroe, Mi
Re: [Cal_Boats] Re: 25-2 mast base [3 Attachments]
Gerald Sobel2017-01-31 21:12 UTC
When the mast base of my Cal 24-1 looked crumbled, I wrapped it in kevlar cloth and West Systems. I think that was a dozen years ago. So far so good, but I think there was more left of my mast base than what you have there, which on one side is nothing. It may be worth a try, however. The space between my swivel mast base (tabernacle) and the cabin trunk was also turning into Milk of Magnesia too. I dug it out, and stuffed it with West Sytems and colloidal silicone filler. Again, a dozen years ago. Knock on [fiberglas covered] wood. At least I don't think I have any rot in my overhead. I think. But I do see ugly black stains thru the clear polyester. What dat?Jerry of Shpritz, ye venable Cal 24-1 kit boat.
On Tuesday, January 31, 2017 8:41 AM, "'TomDressler' tb… [at] verizon.net [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
[Attachment(s) from TomDressler included below] Cal 25-2 mast base. From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]
Subject: [Cal_Boats] Re: 2-5 mast base Can you send me a pic of your collapsed step? My step looks kind of weird and I want to be sure that's its not the same issue. Thanks,Bill Pass'n GasCal 28Monroe, Mi -- {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} hr {border:1px solid #d8d8d8;} {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} {margin-bottom:10px;} .yiv5128922670ad {padding:0 0;} .yiv5128922670ad p {margin:0;} .yiv5128922670ad a {color:#0000ff;text-decoration:none;} {font-family:Arial;} {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} .yiv5128922670ad {margin-bottom:10px;padding:0 0;} {font-family:Verdana;font-size:11px;padding:10px 0;} {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} span {font-weight:700;} span:first-child {text-transform:uppercase;} span a {color:#5085b6;text-decoration:none;} span span {color:#ff7900;} span .yiv5128922670underline {text-decoration:underline;} .yiv5128922670attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} .yiv5128922670attach div a {text-decoration:none;} .yiv5128922670attach img {border:none;padding-right:5px;} .yiv5128922670attach label {display:block;margin-bottom:5px;} .yiv5128922670attach label a {text-decoration:none;} blockquote {margin:0 0 0 4px;} .yiv5128922670bold {font-family:Arial;font-size:13px;font-weight:700;} .yiv5128922670bold a {text-decoration:none;} dd.yiv5128922670last p a {font-family:Verdana;font-weight:700;} dd.yiv5128922670last p span {margin-right:10px;font-family:Verdana;font-weight:700;} dd.yiv5128922670last p span.yiv5128922670yshortcuts {margin-right:0;} div.yiv5128922670attach-table div div a {text-decoration:none;} div.yiv5128922670attach-table {width:400px;} div.yiv5128922670file-title a, div.yiv5128922670file-title a:active, div.yiv5128922670file-title a:hover, div.yiv5128922670file-title a:visited {text-decoration:none;} div.yiv5128922670photo-title a, div.yiv5128922670photo-title a:active, div.yiv5128922670photo-title a:hover, div.yiv5128922670photo-title a:visited {text-decoration:none;} div p a span.yiv5128922670yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;} .yiv5128922670green {color:#628c2a;} .yiv5128922670MsoNormal {margin:0 0 0 0;} o {font-size:0;} div {float:left;width:72px;} div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;} div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} {font-size:77%;} {font-size:77%;} .yiv5128922670replbq {margin:4px;} div a:first-child {margin-right:2px;padding-right:5px;} {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} table {font-size:inherit;font:100%;} select, input, textarea {font:99% Arial, Helvetica, clean, sans-serif;} pre, code {font:115% monospace;} * {line-height:1.22em;} {padding-bottom:10px;} p a {font-family:Verdana;} p span {color:#1E66AE;font-weight:700;} {color:#ff7900;font-weight:700;} {margin-bottom:20px;padding:0px;} li a {font-size:130%;text-decoration:none;} li {font-size:77%;list-style-type:square;padding:6px 0;} ul {margin:0;padding:0 0 0 8px;} {font-family:Georgia;} p {margin:0 0 1em 0;} tt {font-size:120%;} ul li:last-child {border-right:none !important;}
Doug Hoffman2017-01-31 21:37 UTC
HYSOL EA-9430 GLUE is a structural 2-part epoxy that is stronger than anything I have ever used. It is used in aircraft. It mixes thick as is but a bit of colloidal silicone filler can be used to keep it from running. The Hysol will not get totally brittle, it is tough.
Aircraft Spruce is one source: http://www.aircraftspruce.com/catalog/wppages/hysol.php?clickkey=178202
-Doug
> On Jan 31, 2017, at 4:12 PM, Gerald Sobel so… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Cal 25-2 mast base.
> Thanks,
> Bill
> Pass'n Gas
> Cal 28
> Monroe, Mi
sa… [at] mascom.com2017-01-31 23:30 UTC
If it will help, I happen to have a Cal 25 (the original from 1972) mast, rigging and step available that I am sellilng. You'd have to pick up the mast in West Michigan.
Greg Murphy
TomDressler2017-02-01 00:01 UTC
Lots of questions…masts for sale, etc.
Thank you for that.
My original question was..what SHOULD a deck-stepped mast base look like?
Someone asked me for pics…so I submitted them.
Black stains are from the sealant I put around the plates…to stop leaks. When you wipe that sticky crap, it gets nasty looking, I guess. However, it’s not leaking.
But I still don’t know what it should look like.
Thanks.
I’m going out on the water.
..tom
Sent: Tuesday, January 31, 2017 1:13 PM
To: Ca… [at] yahoogroups.com; TomDressler
Subject: Re: [Cal_Boats] Re: 25-2 mast base
[ <https://mg.mail.yahoo.com/neo/launch?.rand=9pv6ekvd4ig0a#TopText> Attachment(s) from TomDressler included below]
Cal 25-2 mast base.
Bill
Pass'n Gas
Cal 28
Monroe, Mi
Mike's Yahoo2017-02-01 13:44 UTC
Tom-
I can send you a picture next time I visit my boat at the yard. I can tell you right now that mine looks entirely different, I have no thru-bolt and it is solid to the deck. It looks like the PO for your boat rigged a way to step/unstep the mast, possibly to trailer the boat. Just so you know, the mast on the 2-25 is longer than the original 25.
Best,
Mike
Cal 2-25 Annapolis
> On Jan 31, 2017, at 7:01 PM, 'TomDressler' tb… [at] verizon.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Thank you for that.
> Thanks.
> ..tom
> Cal 25-2 mast base.
> Thanks,
> Bill
> Pass'n Gas
> Cal 28
> Monroe, Mi
TD2017-02-01 14:02 UTC
Thanks Mike.
I know the PO or even prior, did a bunch to rig it for single-handing.
Roller-fuller for the jib, ran the sheets back to the cockpit, lazy-jacks on the main, added an auto-helm unit, some nice Raymarine digital units, a rader reflector and two 5 gallon portable fuel cans...he was ready to go sailing!
Why the mast base alteration? I dont know but so far, she works!
The guy i bought it from is now sailing around to Md. He's in Costa Rica at the moment.
I've asked him about the base also and am waiting for a reply...if knows anything.
Meanwhile, i'll keep internetting to see what else is out there.
...tom
> On Feb 1, 2017, at 5:44 AM, Mike's Yahoo mi… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Tom-
> Best,
> Mike
> Cal 2-25 Annapolis
>> Thank you for that.
>> Thanks.
>> ..tom
>> Cal 25-2 mast base.
>> Thanks,
>> Bill
>> Pass'n Gas
>> Cal 28
>> Monroe, Mi
Charlie Husar2017-02-01 14:24 UTC
Mike, you are absolutely right. That mast dropping bolt is not original (and I would imagine it changes the stresses on the mast material a lot). I’ve seen a couple 25 flat decks with that mod. Also correct in that the 2-25 mast is 3 feet longer and the boom is shorter that a 25-1.
I once saw a 25-1 where the dreaded PO had caulked around the outside of the mast base! When we dropped the mast, there was about 10 inches of water inside the mast column, and the mast had almost rotted through. We used a lot of glas and epoxy in an attempt to rebuild it. Seemed to have worked.
On my deck stepped Cals, I put a small mouse hole at the base of the mast to make sure it drains. Picture available. This would obviously not be a problem with the swing bolt mod, since the hole at the mast base is huge.
Sent: Wednesday, February 01, 2017 8:44 AM
To: Ca… [at] yahoogroups.com; TomDressler <tb… [at] verizon.net>
Tom-
Best,
Mike
Cal 2-25 Annapolis
On Jan 31, 2017, at 7:01 PM, 'TomDressler' tb… [at] verizon.net <mailto:tb… [at] verizon.net> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
Thank you for that.
Thanks.
..tom
From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com]
To: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> ; TomDressler
On Tuesday, January 31, 2017 8:41 AM, "'TomDressler' tb… [at] verizon.net <mailto:tb… [at] verizon.net> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
Cal 25-2 mast base.
Bill
Pass'n Gas
Cal 28
Monroe, Mi
TomDressler2017-02-01 14:50 UTC
Thanks Charlie.
Still brings me back to the original issue…what SHOULD it look like?
I’m trying to find others…to no avail, yet.
..tom
Sent: Wednesday, February 01, 2017 6:25 AM
To: Ca… [at] yahoogroups.com; 'Mike's Yahoo'
Subject: RE: [Cal_Boats] Re: 25-2 mast base
Tom-
Best,
Mike
Cal 2-25 Annapolis
Thank you for that.
Thanks.
..tom
Cal 25-2 mast base.
Bill
Pass'n Gas
Cal 28
Monroe, Mi
Re: [Cal_Boats] Re: cal 33.2 fuel tank type
matthew2017-02-01 23:01 UTC
Hello everyone,For all you mid 80's cal 33.2 folks what is your fuel tank made from? I have a booklet that says mine is supposed to be stainless but that tank is not there and the current tank is molded into the haul and is fiberglass. I cant tell if it added or original.
Matthew
Travis Porter2017-02-01 23:09 UTC
Original tank on my '86 33-2 was aluminum.
> On Feb 1, 2017, at 5:01 PM, matthew ma… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Hello everyone,
> Matthew
NEWMAN2017-02-01 23:35 UTC
My take is aluminum. Easily accessible under port cushions. Plate on the
tank shows a date of 2001, so not original.
Leslie
Puffin 1986 33-2
On Wednesday, February 1, 2017, Travis Porter tr… [at] sbcglobal.net
> Sent from my iPhone
> <javascript:_e(%7B%7D,'cvml','ma… [at] yahoo.com');> [Cal_Boats] <
> <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');>> wrote:
> Hello everyone,
> Matthew
RE: [Cal_Boats] Re: cal 33.2 fuel tank type
Ted Wrobel2017-02-02 03:11 UTC
Our 1988 Val 33-2 has a molded plastic tank. I believe it is the original tank
Ted
Celebration
Newport, RI
Sent: Wednesday, February 01, 2017 6:36 PM
To: Ca… [at] yahoogroups.com; Travis Porter
Cc: matthew
Subject: Re: [Cal_Boats] Re: cal 33.2 fuel tank type
My take is aluminum. Easily accessible under port cushions. Plate on the tank shows a date of 2001, so not original.
Leslie
Puffin 1986 33-2
On Wednesday, February 1, 2017, Travis Porter tr… [at] sbcglobal.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
Hello everyone,
Matthew
No virus found in this message.
Checked by AVG - www.avg.com <http://www.avg.com/email-signature>
Version: 2016.0.7998 / Virus Database: 4756/13876 - Release Date: 02/01/17
Christopher2017-02-02 03:22 UTC
Our '86 33-2 has an aluminum fuel tank on the port side just forward of the galley sink. Looks original but I'm not sure.
SV Damiana
> On Feb 1, 2017, at 7:11 PM, 'Ted Wrobel' tw… [at] tacticaltech.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Ted
> Celebration
> Newport, RI
> Cc: matthew
> Leslie
> Puffin 1986 33-2
> Sent from my iPhone
> Hello everyone,
> Matthew
Mike's Yahoo2017-02-03 00:26 UTC
Tom-
Pics of the base of my boat's mast.
Best,
Mike
Cal 2-25 Annapolis
> On Feb 1, 2017, at 8:44 AM, Mike's Yahoo <Mi… [at] yahoo.com> wrote:
> Tom-
> Best,
> Mike
> Cal 2-25 Annapolis
>> Thank you for that.
>> Thanks.
>> ..tom
>> Cal 25-2 mast base.
>> Thanks,
>> Bill
>> Pass'n Gas
>> Cal 28
>> Monroe, Mi
