7 messages2017-03-20 18:40 UTCthrough 2017-03-22 03:40 UTC
Re: [Cal_Boats] Re: Cal 33 - exhaust submerging
Claude Roberts2017-03-20 18:40 UTC
I thought about prop pitch as a potential cause, but it also "squats" under sail only.
On Mon, 3/20/17, js… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
Subject: [Cal_Boats] Re: Cal 33 - exhaust submerging
Date: Monday, March 20, 2017, 6:32 AM
If you have an adjustable prop take a little of the
pitch off. I have a Kiwi prop on my 1986 Cal 33-2 and I love
it. Whe I first installed it I had over pitched it a smidge
though and while acceleration under power was great it
buried the exhaust at 2200 rpm. Now perfectly pitched I am
at hull speed, with a clear exhaust and incredible
maneuvering agility. Love my Kiwi prop!
With the exhaust buried you are dragging the
transom through the water and motoring at a disadvantageous
angle...slow and inefficient!
Cheers,Jay
Christopher Thompson2017-03-21 02:22 UTC
Claude,I believe that, regardless if under sail or power, a displacement hull will "squat" as it approaches hull speed.
This is not a problem when motoring because sea water will not force its way upstream against exhaust pressure. It CAN be a problem when sailing and that is why the exhaust hose must be routed above the sailing waterline before it attaches to the engine. This issue can be compounded by a following sea.Chris 33-2 Damiana
On Monday, March 20, 2017 5:24 PM, "Claude Roberts uw… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
Cheers,Jay
Donald C Dutton2017-03-21 03:31 UTC
I have read these concerns and recently checked my boat. The exhaust hose and the bilge pump are both routed well above waterline and then down to the outlets making it impossible for water to flow from the sea to the engine or the bilge. I have been in huge seas and motored in steep chop and have never had a problem with water entering the boat.
Don Dutton
1986 Cal 33-2, “Quantum Evolution”
> On Mar 20, 2017, at 7:22 PM, Christopher Thompson ra… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Claude,
> Chris 33-2 Damiana
> On Monday, March 20, 2017 5:24 PM, "Claude Roberts uw… [at] yahoo.com <mailto:uw… [at] yahoo.com> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>> wrote:
> On Mon, 3/20/17, js… [at] gmail.com <mailto:js… [at] gmail.com> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>> wrote:
> To: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
> Cheers,Jay
> margin:10px
> 0;padding:0 10px;}
> hr {
> color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px
> 0;}
> margin-bottom:10px;}
> .yiv3882473351ad {
> .yiv3882473351ad p {
> .yiv3882473351ad a {
> color:#0000ff;text-decoration:none;}
> margin:10px
> 0px;font-weight:700;font-size:78%;line-height:122%;}
> .yiv3882473351ad {
> margin-bottom:10px;padding:0 0;}
> background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
> span {
> font-weight:700;}
> span:first-child {
> text-transform:uppercase;}
> span a {
> color:#5085b6;text-decoration:none;}
> span span {
> color:#ff7900;}
> span
> .yiv3882473351underline {
> text-decoration:underline;}
> .yiv3882473351attach {
> clear:both;display:table;font-family:Arial;font-size:12px;padding:10px
> 0;width:400px;}
> .yiv3882473351attach div a {
> .yiv3882473351attach img {
> padding-right:5px;}
> .yiv3882473351attach label {
> display:block;margin-bottom:5px;}
> .yiv3882473351attach label a {
> blockquote {
> .yiv3882473351bold {
> font-weight:700;}
> .yiv3882473351bold a {
> dd.yiv3882473351last p a {
> font-weight:700;}
> dd.yiv3882473351last p span {
> margin-right:10px;font-family:Verdana;font-weight:700;}
> span.yiv3882473351yshortcuts {
> margin-right:0;}
> div.yiv3882473351attach-table div div a {
> div.yiv3882473351attach-table {
> div.yiv3882473351file-title a,
> div.yiv3882473351file-title a:active,
> div.yiv3882473351file-title a:hover,
> div.yiv3882473351file-title a:visited {
> div.yiv3882473351photo-title a,
> div.yiv3882473351photo-title a:active,
> div.yiv3882473351photo-title a:hover,
> div.yiv3882473351photo-title a:visited {
> div
> p a span.yiv3882473351yshortcuts {
> font-weight:normal;}
> .yiv3882473351green {
> color:#628c2a;}
> .yiv3882473351MsoNormal {
> o {
> div {
> float:left;width:72px;}
> div div {
> border:1px solid
> #666666;height:62px;overflow:hidden;width:62px;}
> div label {
> color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
> .yiv3882473351replbq {
> div a:first-child {
> margin-right:2px;padding-right:5px;}
> font-family:Arial, helvetica, clean,
> sans-serif;}
> table {
> font:100%;}
> select,
> input, textarea {
> font:99% Arial, Helvetica, clean, sans-serif;}
> pre,
> code {
> font:115% monospace;}
> padding-bottom:10px;}
> p a {
> p span {
> color:#1E66AE;font-weight:700;}
> color:#ff7900;font-weight:700;}
> margin-bottom:20px;padding:0px;}
> li a {
> li {
> list-style-type:square;padding:6px 0;}
> ul {
> p {
> tt {
> ul li:last-child {
> border-right:none !important;
Allen Edwards2017-03-21 14:16 UTC
Someone makes an exhaust part that goes right at the transom that takes the
exhaust straight up from the outlet from the viewpoint of a wave. Think of
what a wave is going to see as it hits your transom. Is it going to see a
nice smooth curve and be able to flow uphill if it is strong enough? Or is
it going to see the wall of the pipe section after a right angle bend. I
think I put an elbow right there as I didn't have room for the fancy part.
My engine was getting flooded both by heeling enough to put the entire
exhaust under the water line, but also by following waves when surfing into
the GG. I also put a rubber flap on the exhaust that are normally
associated with power boats. I only had the flooding problem for a year
after Svendsen's replaced the original exhaust system.
On Mon, Mar 20, 2017 at 8:31 PM, Donald C Dutton dn… [at] comcast.net
> Don Dutton
> Claude,
> following sea.
> Chris 33-2 Damiana
> under sail only.
> Cheers,Jay
> margin:10px
> 0;padding:0 10px;}
> hr {
> 0;}
> .yiv3882473351ad {
> margin:10px
> .yiv3882473351ad {
> span {
> font-weight:700;}
> span:first-child {
> span a {
> span span {
> color:#ff7900;}
> span
> 0;width:400px;}
> padding-right:5px;}
> blockquote {
> font-weight:700;}
> font-weight:700;}
> margin-right:0;}
> div
> color:#628c2a;}
> o {
> div {
> div div {
> border:1px solid
> div label {
> div a:first-child {
> sans-serif;}
> table {
> font:100%;}
> select,
> input, textarea {
> pre,
> code {
> p a {
> p span {
> li a {
> li {
> ul {
> p {
> tt {
> ul li:last-child {
Duane Knize Boat2017-03-22 00:03 UTC
At a Caltopia several years ago, I met someone that had experienced
problems with large following seas back flooding the muffler on a Cal 2-39.
This is in spite of the high loop in the exhaust, right up to the top
inside the aft coaming.
His solution was a ping pong ball on a tether with which he plugged the
exhaust thru hull when seas were up. Starting the engine would blow the
plug out, hence the tether.
I have considered adding a Centek exhaust check valve.
https://www.centekindustries.com/
Regards,
Duane
Duane Knize
S/V Marlyn
1978 Cal 2-39 #18
berthed: Emeryville, CA
kn… [at] san.rr.com
On 3/21/2017 7:16 AM, Allen Edwards al… [at] gmail.com
> takes the exhaust straight up from the outlet from the viewpoint of a
> wave. Think of what a wave is going to see as it hits your transom.
> Is it going to see a nice smooth curve and be able to flow uphill if
> it is strong enough? Or is it going to see the wall of the pipe
> section after a right angle bend. I think I put an elbow right there
> as I didn't have room for the fancy part. My engine was getting
> flooded both by heeling enough to put the entire exhaust under the
> water line, but also by following waves when surfing into the GG. I
> also put a rubber flap on the exhaust that are normally associated
> with power boats. I only had the flooding problem for a year after
> <mailto:dn… [at] comcast.net> [Cal_Boats] <Ca… [at] yahoogroups.com
> Don Dutton
>> ra… [at] yahoo.com <mailto:ra… [at] yahoo.com>
>> Claude,
>> Chris 33-2 Damiana
>> Ro… [at] yahoo.com <mailto:uw… [at] yahoo.com>[Cal_Boats]"
>> On Mon, 3/20/17,js… [at] gmail.com
>> <mailto:js… [at] gmail.com>[Cal_Boats]
>> To:Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
>> Cheers,Jay
>> margin:10px
>> 0;padding:0 10px;}
>> hr {
>> 0;}
>> .yiv3882473351ad {
>> margin:10px
>> .yiv3882473351ad {
>> span {
>> font-weight:700;}
>> span:first-child {
>> span a {
>> span span {
>> color:#ff7900;}
>> span
>> 0;width:400px;}
>> padding-right:5px;}
>> blockquote {
>> font-weight:700;}
>> font-weight:700;}
>> margin-right:0;}
>> div
>> color:#628c2a;}
>> o {
>> div {
>> div div {
>> border:1px solid
>> div label {
>> div a:first-child {
>> sans-serif;}
>> table {
>> font:100%;}
>> select,
>> input, textarea {
>> pre,
>> code {
>> p a {
>> p span {
>> li a {
>> li {
>> ul {
>> p {
>> tt {
>> ul li:last-child {
Re: [Cal_Boats] Re: Cal 33 - exhaust submerging [1 Attachment]
Allen Edwards2017-03-22 02:07 UTC
Mine looks like this. Goes on the outside on the stern. Now, if you don't
have exhaust on the stern, won't work. A right angle elbow close to the
transom with the exhaust hose then going straight up helps with following
seas.
On Tue, Mar 21, 2017 at 5:03 PM, Duane Knize Boat kn… [at] san.rr.com
> [Attachment(s) <#m_1002175506478810246_m_7570028809319396113_TopText>
> from Duane Knize Boat included below]
> Regards,
> Duane
> Duane Knize
> S/V Marlyn
> 1978 Cal 2-39 #18
> berthed: Emeryville, CA… [at] san.rr.com
> On 3/21/2017 7:16 AM, Allen Edwards al… [at] gmail.com [Cal_Boats]
> the exhaust straight up from the outlet from the viewpoint of a wave.
> Think of what a wave is going to see as it hits your transom. Is it going
> to see a nice smooth curve and be able to flow uphill if it is strong
> enough? Or is it going to see the wall of the pipe section after a right
> angle bend. I think I put an elbow right there as I didn't have room for
> the fancy part. My engine was getting flooded both by heeling enough to
> put the entire exhaust under the water line, but also by following waves
> when surfing into the GG. I also put a rubber flap on the exhaust that are
> normally associated with power boats. I only had the flooding problem for
> a year after Svendsen's replaced the original exhaust system.
>> Don Dutton
>> Claude,
>> following sea.
>> Chris 33-2 Damiana
>> under sail only.
>> Cheers,Jay
>> margin:10px
>> 0;padding:0 10px;}
>> hr {
>> 0;}
>> .yiv3882473351ad {
>> margin:10px
>> .yiv3882473351ad {
>> span {
>> font-weight:700;}
>> span:first-child {
>> span a {
>> span span {
>> color:#ff7900;}
>> span
>> 0;width:400px;}
>> padding-right:5px;}
>> blockquote {
>> font-weight:700;}
>> font-weight:700;}
>> margin-right:0;}
>> div
>> color:#628c2a;}
>> o {
>> div {
>> div div {
>> border:1px solid
>> div label {
>> div a:first-child {
>> sans-serif;}
>> table {
>> font:100%;}
>> select,
>> input, textarea {
>> pre,
>> code {
>> p a {
>> p span {
>> li a {
>> li {
>> ul {
>> p {
>> tt {
>> ul li:last-child {
TD2017-03-22 03:40 UTC
Hmmm.
While replacing my baby Yanmar, i also had to replace the exhaust line.
Below, I see mention of a "loop" in the exhaust line.
Mine has a "drop" after the miximg elbow, before going up and exiting the transom.
Should it go up imstead of dropping after the mixing elbow?
Thinking about it...not sure what makes most sense?
What's correct?
Thanks.
...tom
> On Mar 21, 2017, at 7:07 PM, Allen Edwards al… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> Mine looks like this. Goes on the outside on the stern. Now, if you don't have exhaust on the stern, won't work. A right angle elbow close to the transom with the exhaust hose then going straight up helps with following seas.
> Allen
>> On Tue, Mar 21, 2017 at 5:03 PM, Duane Knize Boat kn… [at] san.rr.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
>> [Attachment(s) from Duane Knize Boat included below]
>> At a Caltopia several years ago, I met someone that had experienced problems with large following seas back flooding the muffler on a Cal 2-39.
>> This is in spite of the high loop in the exhaust, right up to the top inside the aft coaming.
>> His solution was a ping pong ball on a tether with which he plugged the exhaust thru hull when seas were up. Starting the engine would blow the plug out, hence the tether.
>> I have considered adding a Centek exhaust check valve. https://www.centekindustries.com/
>> <mjifeolijkcljjle.png>
>> Regards,
>> Duane
>> Duane Knize
>> S/V Marlyn
>> 1978 Cal 2-39 #18
>> kn… [at] san.rr.com
>>> On 3/21/2017 7:16 AM, Allen Edwards al… [at] gmail.com [Cal_Boats] wrote:
>>> Someone makes an exhaust part that goes right at the transom that takes the exhaust straight up from the outlet from the viewpoint of a wave. Think of what a wave is going to see as it hits your transom. Is it going to see a nice smooth curve and be able to flow uphill if it is strong enough? Or is it going to see the wall of the pipe section after a right angle bend. I think I put an elbow right there as I didn't have room for the fancy part. My engine was getting flooded both by heeling enough to put the entire exhaust under the water line, but also by following waves when surfing into the GG. I also put a rubber flap on the exhaust that are normally associated with power boats. I only had the flooding problem for a year after Svendsen's replaced the original exhaust system.
>>>> On Mon, Mar 20, 2017 at 8:31 PM, Donald C Dutton dn… [at] comcast.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
>>>> Don Dutton
>>>>> Claude,
>>>>> Chris 33-2 Damiana
>>>>> Cheers,Jay
>>>>> margin:10px
>>>>> 0;padding:0 10px;}
>>>>> hr {
>>>>> 0;}
>>>>> .yiv3882473351ad {
>>>>> margin:10px
>>>>> .yiv3882473351ad {
>>>>> span {
>>>>> font-weight:700;}
>>>>> span:first-child {
>>>>> span a {
>>>>> span span {
>>>>> color:#ff7900;}
>>>>> span
>>>>> 0;width:400px;}
>>>>> padding-right:5px;}
>>>>> blockquote {
>>>>> font-weight:700;}
>>>>> font-weight:700;}
>>>>> margin-right:0;}
>>>>> div
>>>>> color:#628c2a;}
>>>>> o {
>>>>> div {
>>>>> div div {
>>>>> border:1px solid
>>>>> div label {
>>>>> div a:first-child {
>>>>> sans-serif;}
>>>>> table {
>>>>> font:100%;}
>>>>> select,
>>>>> input, textarea {
>>>>> pre,
>>>>> code {
>>>>> p a {
>>>>> p span {
>>>>> li a {
>>>>> li {
>>>>> ul {
>>>>> p {
>>>>> tt {
>>>>> ul li:last-child {
