Prop replacement
Prop replacement
9 messages2017-04-02 12:59 UTCthrough 2017-04-03 17:13 UTC
Prop replacement
Kieran Dooley2017-04-02 12:59 UTC
Hi everyone, Any recommendations for a new prop on my CAL34 powered by an Atomic 4 with reversing gear transmission? I can check the reduction ratio if needed.
Re: [Cal_Boats] Prop replacement
Joe DeMers2017-04-02 13:10 UTC
On 4/2/17 8:59 AM, Kieran Dooley so… [at] yahoo.com [Cal_Boats] wrote: > Hi everyone, > Any recommendations for a new prop on my CAL34 powered by an Atomic 4 with reversing gear transmission? ********** If you have a reduction gear on an Atomic 4, the ratio is 2:1. **** What is the max diameter prop that will fit your boat? What is the prop shaft diameter? Joe DeMers > I can check the reduction ratio if needed. > > Sent from my iPhone > > > ------------------------------------ > Posted by: Kieran Dooley <so… [at] yahoo.com> > ------------------------------------ > > > ------------------------------------ > > Yahoo Groups Links > > > > > -- *Joe DeMers - owner* Sound Marine Diesel LLC SoundMarineDiesel.com <http://www.soundmarinediesel.com/>*phone & fax (860) 666-2184*
Kieran Dooley2017-04-02 13:18 UTC
I'll check when I'm at the boat today. Thanks Joe > On Apr 2, 2017, at 9:10 AM, Joe DeMers je… [at] mindspring.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > >> On 4/2/17 8:59 AM, Kieran Dooley so… [at] yahoo.com [Cal_Boats] wrote: >> Hi everyone, >> Any recommendations for a new prop on my CAL34 powered by an Atomic 4 with reversing gear transmission? > > ********** If you have a reduction gear on an Atomic 4, the ratio is 2:1. > > **** What is the max diameter prop that will fit your boat? What is the prop shaft diameter? Joe DeMers >> I can check the reduction ratio if needed. >> >> Sent from my iPhone >> >> >> ------------------------------------ >> Posted by: Kieran Dooley <so… [at] yahoo.com> >> ------------------------------------ >> >> >> ------------------------------------ >> >> Yahoo Groups Links >> >> >> >> >> > > -- > Joe DeMers - owner > > Sound Marine Diesel LLC > > SoundMarineDiesel.comphone & fax (860) 666-2184 >
Kieran Dooley2017-04-02 14:55 UTC
Joe, 1" prop shaft with 10" max prop diameter. > On Apr 2, 2017, at 9:10 AM, Joe DeMers je… [at] mindspring.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > >> On 4/2/17 8:59 AM, Kieran Dooley so… [at] yahoo.com [Cal_Boats] wrote: >> Hi everyone, >> Any recommendations for a new prop on my CAL34 powered by an Atomic 4 with reversing gear transmission? > > ********** If you have a reduction gear on an Atomic 4, the ratio is 2:1. > > **** What is the max diameter prop that will fit your boat? What is the prop shaft diameter? Joe DeMers >> I can check the reduction ratio if needed. >> >> Sent from my iPhone >> >> >> ------------------------------------ >> Posted by: Kieran Dooley <so… [at] yahoo.com> >> ------------------------------------ >> >> >> ------------------------------------ >> >> Yahoo Groups Links >> >> >> >> >> > > -- > Joe DeMers - owner > > Sound Marine Diesel LLC > > SoundMarineDiesel.comphone & fax (860) 666-2184 >
Kieran Dooley2017-04-02 19:08 UTC
I meant to say 10" radius so 20" diameter > On Apr 2, 2017, at 10:55 AM, Kieran Dooley so… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > Joe, > 1" prop shaft with 10" max prop diameter. > > Sent from my iPhone > >> On Apr 2, 2017, at 9:10 AM, Joe DeMers je… [at] mindspring.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: >> >> >> >> >>> On 4/2/17 8:59 AM, Kieran Dooley so… [at] yahoo.com [Cal_Boats] wrote: >>> Hi everyone, >>> Any recommendations for a new prop on my CAL34 powered by an Atomic 4 with reversing gear transmission? >> >> ********** If you have a reduction gear on an Atomic 4, the ratio is 2:1. >> >> **** What is the max diameter prop that will fit your boat? What is the prop shaft diameter? Joe DeMers >>> I can check the reduction ratio if needed. >>> >>> Sent from my iPhone >>> >>> >>> ------------------------------------ >>> Posted by: Kieran Dooley <so… [at] yahoo.com> >>> ------------------------------------ >>> >>> >>> ------------------------------------ >>> >>> Yahoo Groups Links >>> >>> >>> >>> >>> >> >> -- >> Joe DeMers - owner >> >> Sound Marine Diesel LLC >> >> SoundMarineDiesel.comphone & fax (860) 666-2184 > >
Christopher2017-04-03 02:10 UTC
If you go to the Moyer Marine website, they have a page on prop selection. Don Moyer is well know for his work with the A4. I used his info to rebuild an Atomic 4 that I had in a previous boat. Chris 1988 33-2 Damiana > On Apr 2, 2017, at 5:59 AM, Kieran Dooley so… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > Hi everyone, > Any recommendations for a new prop on my CAL34 powered by an Atomic 4 with reversing gear transmission? > I can check the reduction ratio if needed. > > Sent from my iPhone >
Kieran Dooley2017-04-03 06:18 UTC
Great Thanks > On Apr 2, 2017, at 10:10 PM, Christopher ra… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > If you go to the Moyer Marine website, they have a page on prop selection. Don Moyer is well know for his work with the A4. I used his info to rebuild an Atomic 4 that I had in a previous boat. > Chris 1988 33-2 Damiana > > Sent from my iPhone > >> On Apr 2, 2017, at 5:59 AM, Kieran Dooley so… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: >> >> >> Hi everyone, >> Any recommendations for a new prop on my CAL34 powered by an Atomic 4 with reversing gear transmission? >> I can check the reduction ratio if needed. >> >> Sent from my iPhone > >
Re: Prop replacement
th… [at] hotmail.com2017-04-03 16:21 UTC
Do check out Kiwi Props -- feathering props -- extremely simple and robust design. I have used on on my Cal 31 for 4 years now. Major increase in reverse thrust and reduction in prop walk compared to the fixed blade prop it replaced... Low cost for a feathering prop. I am very satisfied.
RE: [Cal_Boats] Prop replacement
Jeff Thayer2017-04-03 17:13 UTC
Check what the current prop is (diameter, pitch, left hand vs right hand, shaft diameter). All will be required to spec a replacement. I recently replaced a fixed, three blade on my Cal 39 MK2 w/ a three blade feathering MAX prop. Very happy w/ the results. Pros: Feathering is very reliable and keeps the transmission from free-wheeling while sailing Feathering added at least ½ knot to boat speed Reverse is very strong and with minimal “prop walk” Downsides are: Not as mechanically robust as fixed prop (it has moving parts after all….) Expensive Requires periodic servicing (every other year it gets stripped down, cleaned and regreased.) Jeff Thayer SV Ecco Cal 39 Mk2 #115 San Francisco, Ca From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] Sent: Sunday, April 2, 2017 6:18 AM To: Ca… [at] yahoogroups.com; Joe DeMers <je… [at] mindspring.com> Subject: Re: [Cal_Boats] Prop replacement I'll check when I'm at the boat today. Thanks Joe On Apr 2, 2017, at 9:10 AM, Joe DeMers je… [at] mindspring.com<mailto:je… [at] mindspring.com> [Cal_Boats] <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>> wrote: On 4/2/17 8:59 AM, Kieran Dooley so… [at] yahoo.com<mailto:so… [at] yahoo.com> [Cal_Boats] wrote: Hi everyone, Any recommendations for a new prop on my CAL34 powered by an Atomic 4 with reversing gear transmission? ********** If you have a reduction gear on an Atomic 4, the ratio is 2:1. **** What is the max diameter prop that will fit your boat? What is the prop shaft diameter? Joe DeMers I can check the reduction ratio if needed. ------------------------------------ Posted by: Kieran Dooley <so… [at] yahoo.com><mailto:so… [at] yahoo.com> ------------------------------------ ------------------------------------ Yahoo Groups Links http://groups.yahoo.com/group/Cal_Boats/ Individual Email | Traditional http://groups.yahoo.com/group/Cal_Boats/join (Yahoo! ID required) Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> https://info.yahoo.com/legal/us/yahoo/utos/terms/ -- Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.com<http://www.soundmarinediesel.com/>phone & fax (860) 666-2184 CONFIDENTIAL COMMUNICATION -- The information in this e-mail (including any attachments) is confidential and proprietary to PRYSM, INC. and intended only for the sole use of the intended recipient. If you have received this communication in error, then any review, dissemination, distribution, or copying of this message is strictly prohibited, and please permanently delete this message (including any copies of this e-mail and any attachments thereto) and notify us immediately by return e-mail.
