cutlass bearing
cutlass bearing
7 messages2010-03-25 20:17 UTCthrough 2017-05-22 01:37 UTC
cutlass bearing
Robert Weiss2010-03-25 20:17 UTC
Hello: I am having trouble determining the dimenions of my cutlass bearing. It does not seem to have a metal outer sleeve. My boat is a Cal 31 (1982). I have measured the OD of the bearing as 1-1/8, but all the cutlass brgs. I have seen are listed as 1-1/4 OD. Can anyone help me with the dimensions. Thank You,
Re: [Cal_Boats] cutlass bearing
Helen Horn2010-03-26 00:32 UTC
most cutless bearing are named after 'Red Fish' 'black finn' 'Halibut' (morse) ... your old bearing is STILL in side your bronze prop shaft ...take a sawzall and carfull cut though old bearing then pull it out at on will be the name 'Salmon' stamped on out side of the bearing case ... that could be WHY yer 1/4" off.. good luck most yards charge $150-$300 berings $35-$85. From: Robert Weiss <ly… [at] yahoo.com> To: Ca… [at] yahoogroups.com Sent: Thu, March 25, 2010 1:17:33 PM Subject: [Cal_Boats] cutlass bearing Hello: I am having trouble determining the dimenions of my cutlass bearing. It does not seem to have a metal outer sleeve. My boat is a Cal 31 (1982). I have measured the OD of the bearing as 1-1/8, but all the cutlass brgs. I have seen are listed as 1-1/4 OD. Can anyone help me with the dimensions. Thank You,
Robert Weiss2010-03-26 13:47 UTC
Problem is I have to drop the rudder to remove the shaft. I have a puller to remove the brg with the shaft in place, so I cannot cut the brg. Shaft is 1" dia. So I need to know the dimensions of the brg, especially the OD. --- On Fri, 3/26/10, Helen Horn <he… [at] sbcglobal.net> wrote: From: Helen Horn <he… [at] sbcglobal.net> Subject: Re: [Cal_Boats] cutlass bearing To: Ca… [at] yahoogroups.com Date: Friday, March 26, 2010, 12:32 AM most cutless bearing are named after 'Red Fish' 'black finn' 'Halibut' (morse) ... your old bearing is STILL in side your bronze prop shaft ...take a sawzall and carfull cut though old bearing then pull it out at on will be the name 'Salmon' stamped on out side of the bearing case ... that could be WHY yer 1/4" off.. good luck most yards charge $150-$300 berings $35-$85 . From: Robert Weiss <lyzyrd83@yahoo. com> To: Cal_Boats@yahoogrou ps.com Sent: Thu, March 25, 2010 1:17:33 PM Subject: [Cal_Boats] cutlass bearing Hello: I am having trouble determining the dimenions of my cutlass bearing. It does not seem to have a metal outer sleeve. My boat is a Cal 31 (1982). I have measured the OD of the bearing as 1-1/8, but all the cutlass brgs. I have seen are listed as 1-1/4 OD. Can anyone help me with the dimensions. Thank You,
Joe DeMers2010-03-26 14:28 UTC
What you have is a "thin wall" bearing, with 1.125" OD. We have them in stock, $39. *Joe DeMers - owner* Sound Marine Diesel LLC SoundMarineDiesel.com <http://www.soundmarinediesel.com/> *phone & fax (860) 666-2184* On 3/26/2010 9:47 AM, Robert Weiss wrote: > > > Problem is I have to drop the rudder to remove the shaft. I have a > puller to remove > the brg with the shaft in place, so I cannot cut the brg. Shaft is 1" > dia. So I need to > know the dimensions of the brg, especially the OD. > > --- On *Fri, 3/26/10, Helen Horn /<he… [at] sbcglobal.net>/* wrote: > > > From: Helen Horn <he… [at] sbcglobal.net> > Subject: Re: [Cal_Boats] cutlass bearing > To: Ca… [at] yahoogroups.com > Date: Friday, March 26, 2010, 12:32 AM > > most cutless bearing are named after 'Red Fish' > 'black finn' 'Halibut' (morse) ... your old bearing is STILL in > side your bronze prop shaft ...take a sawzall and carfull cut > though old bearing then pull it out at on will be the name > 'Salmon' stamped on out side of the bearing case ... that could be > WHY yer 1/4" off.. good luck most yards charge $150-$300 > berings $35-$85 . > > *From:* Robert Weiss <lyzyrd83@yahoo. com> > *To:* Cal_Boats@yahoogrou ps.com > *Sent:* Thu, March 25, 2010 1:17:33 PM > *Subject:* [Cal_Boats] cutlass bearing > > Hello: > I am having trouble determining the dimenions of my cutlass bearing. > It does not seem to have a metal outer sleeve. My boat is a Cal > 31 (1982). > I have measured the OD of the bearing as 1-1/8, but all the > cutlass brgs. I have > seen are listed as 1-1/4 OD. > Can anyone help me with the dimensions. > Thank You, > > > > > > > > > > No virus found in this incoming message. > Checked by AVG - www.avg.com > Version: 9.0.791 / Virus Database: 271.1.1/2771 - Release Date: 03/26/10 03:33:00 > > -- *Joe DeMers - owner* Sound Marine Diesel LLC SoundMarineDiesel.com <http://www.soundmarinediesel.com/> *phone & fax (860) 666-2184*
Helen Horn2010-03-26 15:47 UTC
I have always dropped the rudder to replace cutlass...edward (you must pull the shaft or so I thought) From: Robert Weiss <ly… [at] yahoo.com> To: Ca… [at] yahoogroups.com Sent: Fri, March 26, 2010 6:47:12 AM Subject: Re: [Cal_Boats] cutlass bearing Problem is I have to drop the rudder to remove the shaft. I have a puller to remove the brg with the shaft in place, so I cannot cut the brg. Shaft is 1" dia. So I need to know the dimensions of the brg, especially the OD. --- On Fri, 3/26/10, Helen Horn <helenhorn@sbcglobal .net> wrote: >From: Helen Horn <helenhorn@sbcglobal .net> >Subject: Re: [Cal_Boats] cutlass bearing >To: Cal_Boats@yahoogrou ps.com >Date: Friday, March 26, 2010, 12:32 AM > > > >most cutless bearing are named after 'Red Fish' >'black finn' 'Halibut' (morse) ... your old bearing is STILL in side your bronze prop shaft ...take a sawzall and carfull cut though old bearing then pull it out at on will be the name 'Salmon' stamped on out side of the bearing case ... that could be WHY yer 1/4" off.. good luck most yards charge $150-$300 >berings $35-$85 . > > > > From: Robert Weiss <lyzyrd83@yahoo. com> >To: Cal_Boats@yahoogrou ps.com >Sent: Thu, March 25, 2010 1:17:33 PM >Subject: [Cal_Boats] cutlass bearing > > >Hello: >I am having trouble determining the dimenions of my cutlass bearing. >It does not seem to have a metal outer sleeve. My boat is a Cal 31 (1982). >I have measured the OD of the bearing as 1-1/8, but all the cutlass brgs. I have >seen are listed as 1-1/4 OD. > >Can anyone help me with the dimensions. > >Thank You, > > >
scott2010-03-27 01:34 UTC
Hi The yard rec a hak saw and make little cuts to collapse the bearng if it is in a strut if its in a tube which the old Ericson E-30 you press it out from the inside I have the hak saw on two boats Cal 29 and catalina 27 To ren-insatall freeze the bearing so that it will shrink tiny and hope it goes in that is into a strut just my 2 cents Scott cal 2-29 --- On Fri, 3/26/10, Helen Horn <he… [at] sbcglobal.net> wrote: From: Helen Horn <he… [at] sbcglobal.net> Subject: Re: [Cal_Boats] cutlass bearing To: Ca… [at] yahoogroups.com Date: Friday, March 26, 2010, 8:47 AM I have always dropped the rudder to replace cutlass...edward (you must pull the shaft or so I thought) From: Robert Weiss <lyzyrd83@yahoo. com> To: Cal_Boats@yahoogrou ps.com Sent: Fri, March 26, 2010 6:47:12 AM Subject: Re: [Cal_Boats] cutlass bearing Problem is I have to drop the rudder to remove the shaft. I have a puller to remove the brg with the shaft in place, so I cannot cut the brg. Shaft is 1" dia. So I need to know the dimensions of the brg, especially the OD. --- On Fri, 3/26/10, Helen Horn <helenhorn@sbcglobal .net> wrote: From: Helen Horn <helenhorn@sbcglobal .net> Subject: Re: [Cal_Boats] cutlass bearing To: Cal_Boats@yahoogrou ps.com Date: Friday, March 26, 2010, 12:32 AM most cutless bearing are named after 'Red Fish' 'black finn' 'Halibut' (morse) ... your old bearing is STILL in side your bronze prop shaft ...take a sawzall and carfull cut though old bearing then pull it out at on will be the name 'Salmon' stamped on out side of the bearing case ... that could be WHY yer 1/4" off.. good luck most yards charge $150-$300 berings $35-$85 . From: Robert Weiss <lyzyrd83@yahoo. com> To: Cal_Boats@yahoogrou ps.com Sent: Thu, March 25, 2010 1:17:33 PM Subject: [Cal_Boats] cutlass bearing Hello: I am having trouble determining the dimenions of my cutlass bearing. It does not seem to have a metal outer sleeve. My boat is a Cal 31 (1982). I have measured the OD of the bearing as 1-1/8, but all the cutlass brgs. I have seen are listed as 1-1/4 OD. Can anyone help me with the dimensions. Thank You,
Cutlass Bearing
david dobbs2017-05-22 01:37 UTC
Was down at the yard today, and at one point just grabbed the propshaft and pulled, and it moved. Don't remember that happening before, but who knows at this point, I'm old and memory isn't what it used to be. Anyway it wasn't much, maybe a sixteenth. ?, or am I just borrowing trouble? About 3 more full work days and I'm ready to splash. Won't make Memorial Day, but the week after should work.David Dobbs
