Volvo Penta MS Transmission Problem
John and Julie Stacklyn2017-06-17 14:34 UTC
Hello All,
After a sail last weekend, motoring in my home channel and all of a sudden the engine just stops. Not a slow, sputtering kind but a quick dramatic one. Assume the transmission, as the shifter slides back and forth but does nothing and moving it manually at the gear does nothing either. Oil in the drain pan and a large, rubber seal around the shaft, completely undamaged, but the only way it could get there was from the back of the transmission. Pulled the dipstick and it is bone dry. It's an Volvo MS or MSB (can't remember which) that was a rebuild from Joe DeMers about 9 years ago. Any ideas, especially from Joe would be greatly appreciated.
Thanks in advance,
John Stacklyn
Sol Survivor
Cal 31 #33
Re: [Cal_Boats] Volvo Penta MS Transmission Problem
Joe DeMers2017-06-18 14:03 UTC
Hi John - Is the transmission the problem, or the engine?
The old Volvo MS & MSB gears are now very old, obsolete, and getting
much harder to find. We can rebuild yours, if it is not extensively
damaged. Of course, running it out of oil is a disaster for any
transmission.
The permanent solution is to install a modern engine with a modern
transmission. Joe DeMers
On 6/17/17 10:34 AM, John and Julie Stacklyn st… [at] outlook.com
[Cal_Boats] wrote:
> Hello All,
> dry. It’s an Volvo MS or MSB (can’t remember which) that was a rebuild
> Thanks in advance,
> John Stacklyn
> Sol Survivor
> Cal 31 #33
*Joe DeMers - owner*
Sound Marine Diesel LLC
(860) 666-2184*
