Re: Steam Vapor in Exhaust
du… [at] aim.com2017-06-27 23:45 UTC
Where did you get the "proper" routing of raw water from? Unless i mis-read it, you are now sucking the raw water through the system and push it into the injection elbow?
Re: [Cal_Boats] Re: Steam Vapor in Exhaust (Dutchess)
Michael D2017-06-28 12:10 UTC
Dutchess,
We became suspicious early on when we discovered hot water being sent through the transmission and into the v-drive. After some investigation, we found the correct routing from the installation manual.
BTW, I discovered the blockage and cleared it. No more vapor is visible in the exhaust, and we are now able to motor without overheating.
Michael
On Tuesday, June 27, 2017, 7:57:43 PM EDT, du… [at] aim.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
