12 messages2017-07-02 15:38 UTCthrough 2017-07-06 00:15 UTC
Atomic 4 Water Pump
bl… [at] sbcglobal.net2017-07-02 15:38 UTC
I have a Cal 30 with an Atomic 4. It has an Oberdorfer 202 water pump. Anyone know if West Marine carries the impeller? Any idea what the part number is?
Re: [Cal_Boats] Atomic 4 Water Pump
Kieran Dooley2017-07-02 16:02 UTC
Have you checked with Moyer Marine?
> On Jul 2, 2017, at 11:38 AM, bl… [at] sbcglobal.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
Edward Stancil2017-07-02 16:04 UTC
Try Moyer Marine ..they are most
Helpfull.
On Jul 2, 2017 8:40 AM, "bl… [at] sbcglobal.net [Cal_Boats]" <
> number is?
Greg Beron2017-07-02 17:46 UTC
blockquote, div.yahoo_quoted { margin-left: 0 !important; border-left:1px #715FFA solid !important; padding-left:1ex !important; background-color:white !important; } I haven't had any luck at West but any Universal dealer should have that.
Sent from Yahoo Mail for iPad
On Sunday, July 2, 2017, 8:38 AM, bl… [at] sbcglobal.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
Allen Edwards2017-07-02 18:32 UTC
Look up the waterpump guys on L-36.com under Sources tab... OK, in a fit
of non-lazyness I looked it up: Depco. But check the site for a link.
They are my go-to place for reauilds.
On Sun, Jul 2, 2017 at 10:46 AM, Greg Beron gb… [at] yahoo.com [Cal_Boats] <
> Sent from Yahoo Mail for iPad <https://yho.com/footer0>
> number is?
Loose rubber
Adam2017-07-05 02:27 UTC
Gunwale rubber, that is.
Anyone have a fix for this problem?
I've had very short sections near the bow come a little bit loose before, but nothing like this! No wonder the other skippers were looking at me funny as I pulled into Angel Island; I didn't notice it until stepped onto the dock. Despite doing my best to sail around and over and not straight into the San Pablo Bay ebb chop for less than two hours, it knocked 3/4 of the gunwale off, both port and starboard. And apparently the rubber was protecting a small leak somewhere in the hull-deck joint, too, as some stuff in the cabin got significantly wet. I never got a good look at the hull-deck joint until now, and can't say I'm terribly impressed with the pop rivets and goop keeping this little ship together (including some silicone, which might be temporary fixes by previous owners?). I guess I can't complain; it's worked for 40+ years. But after this incident, I'd like to be confident it will work in worse conditions and for longer periods.
So as to the gunwale rubber: any suggestions? Would a new gunwale (e.g. from Steve Seals) be significantly tighter, enough so that it won't come off so easily? http://www.sealsspars.com/gunnelcatalog.html
-Adam
Cal 2-27 #93
From: "Allen Edwards al… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
To: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com>; Greg Beron <gb… [at] yahoo.com>
Sent: Sunday, July 2, 2017 11:32 AM
Subject: Re: [Cal_Boats] Atomic 4 Water Pump
Look up the waterpump guys on L-36.com under Sources tab... OK, in a fit of non-lazyness I looked it up: Depco. But check the site for a link. They are my go-to place for reauilds.
On Sun, Jul 2, 2017 at 10:46 AM, Greg Beron gb… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
Re: [Cal_Boats] Loose rubber [2 Attachments]
Adam2017-07-05 02:45 UTC
I just realized Steve Seals sells raw lengths of the stuff...which leads me to suggest to myself:
First try cutting an inch or two off of one end, then pull the whole thing a bit more taut around the boat, and see how that goes. Right? Maybe.
From: "Adam as… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
Sent: Tuesday, July 4, 2017 7:28 PM
Subject: [Cal_Boats] Loose rubber [2 Attachments]
[Attachment(s) from Adam included below] Gunwale rubber, that is.
-Adam
Cal 2-27 #93
Robert Thompson2017-07-05 03:51 UTC
That's what I've always done, cut off a few inches and pull it tight.
On Jul 4, 2017 21:45, "Adam as… [at] yahoo.com [Cal_Boats]" <
> *From:* "Adam as… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
> *Sent:* Tuesday, July 4, 2017 7:28 PM
> *Subject:* [Cal_Boats] Loose rubber [2 Attachments]
> [Attachment(s)
> <https://mg.mail.yahoo.com/neo/launch?.rand=8ole0tuovod62#TopText> from
> periods.
> -Adam
> Cal 2-27 #93
david dobbs2017-07-05 20:40 UTC
Adam, I changed mine out years ago, with instructions from Charlie Husar and it's been fine. I uncoiled mine and let it stay in the sun for a couple of hours, then began to snap it over the hull to deck joint. I stretched it as much as I could while installing. Start at the stern, the endcap will hold the rubrail in place. It took my brother and I all one day to do it. My thumbs were sore for a week! The yard guys said it would come off when the lifted the boat. Didn't happen. That was the beginning of their respect for me. I had to earn it. Good luck.David Dobbs CAL29 411
On Tuesday, July 4, 2017 10:51 PM, "Robert Thompson ca… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
On Jul 4, 2017 21:45, "Adam as… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
So as to the gunwale rubber: any suggestions? Would a new gunwale (e.g. from Steve Seals) be significantly tighter, enough so that it won't come off so easily? http://www.sealsspars.com/ gunnelcatalog.html
-Adam
Cal 2-27 #93
Adam2017-07-05 21:03 UTC
Thanks, David and Robert. I think I'll try trimming the existing one and see just how satisfactorily it can be tightened, and if that fails, buy the new stuff. -Adam
From: "david dobbs tm… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
To: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com>; Robert Thompson <ca… [at] gmail.com>
Sent: Wednesday, July 5, 2017 1:41 PM
Subject: Re: [Cal_Boats] Loose rubber
-Adam
Cal 2-27 #93
RE: [Cal_Boats] Loose rubber
Charlie Husar2017-07-05 23:19 UTC
Adam, the old stuff losses its elasticity over time. A restretch might be tough. I buy rub rails from D&R marine (Rudy Nickerson) in Massachusetts. I install self-tapping screws vertically though the rail using the lips of the hull and deck section. This is done during the stretching process.
I have it on good word (ex-Jensen employee) that the pop rivets do nothing structural. They were there to hold the deck and hull sections in place while the joint was glassed over from the inside.
I can send you my rub rail install instructions and D&R info if you would like them.
Take Care
Annapolis
Sent: Wednesday, July 05, 2017 5:03 PM
To: Ca… [at] yahoogroups.com; Robert Thompson <ca… [at] gmail.com>; david dobbs <tm… [at] yahoo.com>
-Adam
On Jul 4, 2017 21:45, "Adam as… [at] yahoo.com <mailto:as… [at] yahoo.com> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote:
From: "Adam as… [at] yahoo.com <mailto:as… [at] yahoo.com> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> >
To: "Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> " <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> >
[ <https://mg.mail.yahoo.com/neo/launch?.rand=8ole0tuovod62#TopText> Attachment(s) from Adam included below]
So as to the gunwale rubber: any suggestions? Would a new gunwale (e.g. from Steve Seals) be significantly tighter, enough so that it won't come off so easily? http://www.sealsspars.com/ gunnelcatalog.html <http://www.sealsspars.com/gunnelcatalog.html>
-Adam
Cal 2-27 #93
fs… [at] torchlake.com2017-07-06 00:15 UTC
Thanks Charlie,
Good to know that the rivets aren't there for structural reasons as in
holding the deck to the hull.
Adam I replaced my rubrail on my Cal 2 34 2 years ago. The trick really
is to heat it up in the sun so it will give/stretch. I put mine on a
black surface but the air temp wasn't very high so it didn't heat up as
I would have liked it to.... took all day with a shit ton of pulling by
2 of us to get it on there. Yes we started at the stern and yes we
sealed the joint before putting it on, didn't know about the tapping
screw trick.
Have fun,
Faith
Squalicum Harbor,
Bellingham WA
On 2017-07-05 16:19, 'Charlie Husar' hu… [at] gmail.com [Cal_Boats]
> Take Care
> Charlie
> Annapolis
> FROM: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]
> SENT: Wednesday, July 05, 2017 5:03 PM
> TO: Ca… [at] yahoogroups.com; Robert Thompson <ca… [at] gmail.com>; david dobbs <tm… [at] yahoo.com>
> SUBJECT: Re: [Cal_Boats] Loose rubber
> -Adam
> FROM: "david dobbs tm… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
> TO: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com>; Robert Thompson <ca… [at] gmail.com>
> SENT: Wednesday, July 5, 2017 1:41 PM
>> FROM: "Adam as… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
>> SENT: Tuesday, July 4, 2017 7:28 PM
>> SUBJECT: [Cal_Boats] Loose rubber [2 Attachments]
>> [ATTACHMENT(S) [1] FROM ADAM INCLUDED BELOW]
>> So as to the gunwale rubber: any suggestions? Would a new gunwale (e.g. from Steve Seals) be significantly tighter, enough so that it won't come off so easily? http://www.sealsspars.com/ gunnelcatalog.html [2]
>> -Adam
>> Cal 2-27 #93
Links:
[1] https://mg.mail.yahoo.com/neo/launch?.rand=8ole0tuovod62#TopText
[2] http://www.sealsspars.com/gunnelcatalog.html
[3]
https://groups.yahoo.com/neo/groups/Cal_Boats/conversations/messages/43261;_ylc=X3oDMTJya2o3bnIxBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRtc2dJZAM0MzI2MQRzZWMDZnRyBHNsawNycGx5BHN0aW1lAzE0OTkyOTY3ODI-?act=reply&messageNum=43261
[4]
https://groups.yahoo.com/neo/groups/Cal_Boats/conversations/newtopic;_ylc=X3oDMTJmZ2MwdTc5BF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNudHBjBHN0aW1lAzE0OTkyOTY3ODI-
[5]
https://groups.yahoo.com/neo/groups/Cal_Boats/conversations/topics/43249;_ylc=X3oDMTM3cXAyajU0BF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRtc2dJZAM0MzI2MQRzZWMDZnRyBHNsawN2dHBjBHN0aW1lAzE0OTkyOTY3ODIEdHBjSWQDNDMyNDk-
[6]
https://groups.yahoo.com/neo/groups/Cal_Boats/photos/photomatic/1691957130;_ylc=X3oDMTE4M3R1OW82BF9TAzk3MzU5NzE0BGNmOQNQSE9UT01BVElDBHNlYwNtZWdhcGhvbmU-
[7] https://yho.com/1wwmgg
[8]
https://groups.yahoo.com/neo/groups/Cal_Boats/info;_ylc=X3oDMTJmbmZtaGFqBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDdnRsBHNsawN2Z2hwBHN0aW1lAzE0OTkyOTY3ODI-
[9]
https://groups.yahoo.com/neo/groups/Cal_Boats/members/all;_ylc=X3oDMTJnNHZzNWtoBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDdnRsBHNsawN2bWJycwRzdGltZQMxNDk5Mjk2Nzgy
[10]
https://groups.yahoo.com/neo;_ylc=X3oDMTJlampoYXUzBF9TAzk3NDc2NTkwBGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNnZnAEc3RpbWUDMTQ5OTI5Njc4Mg--
[11] https://info.yahoo.com/privacy/us/yahoo/groups/details.html
[12] https://info.yahoo.com/legal/us/yahoo/utos/terms/
