Main halyard
Main halyard
3 messages2017-07-07 22:01 UTCthrough 2017-07-07 22:57 UTC
Main halyard
david dobbs2017-07-07 22:01 UTC
Guys, what size diameter line should I use for a CAL29 that I don't race only cruise/daysail for the main halyard. Gotta replace the existing one.Thx,David Dobbs CAL29 411
Re: [Cal_Boats] Main halyard
Terry Spencer2017-07-07 22:16 UTC
So ideally the line diameter would be sized to the sheave at the top of your mast to reduce wear on the halyard in that spot. If you are properly sized right now than you would go with the same size. When I changed mine out, I had the mast down and bought new sheaves. There is a guy in Port Townsend that specializes in making these to order. Can’t remember his name, but I am sure you could find it. Terry Spencer Cal 2-29 Capriccio Tacoma > On Jul 7, 2017, at 3:01 PM, david dobbs tm… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > Guys, what size diameter line should I use for a CAL29 that I don't race only cruise/daysail for the main halyard. Gotta replace the existing one. > Thx, > David Dobbs CAL29 411 > > > >
Greg Beron2017-07-07 22:57 UTC
I've used this site asa resiurce for dimensions when buying new running rigging: Cal 29 | | | | | | | | | | | Cal 29 The Cal 2-29 is a Bill Lapworth design and is a cruiser/racer class sloop. Specs: LOA – 29.34 ft LWL – 24 ft Beam – 9.25 ft Draft – 4.5 ft (fin keel) Displacement – 80… | | | | Greg BeronCal 29 Happy HourMarina del Rey, CA On Friday, July 7, 2017, 3:01 PM, david dobbs tm… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Guys, what size diameter line should I use for a CAL29 that I don't race only cruise/daysail for the main halyard. Gotta replace the existing one.Thx,David Dobbs CAL29 411
