7 messages2017-07-30 19:59 UTCthrough 2017-08-01 19:04 UTC
Kvh sailcomp
John b2017-07-30 19:59 UTC
Over the last few weeks I have noticed that my digital compass will have
flickering display while the engine is running. This does not happen all
of the time and never sofar while under sail. My other instrument a
raymarine i50 tridata works fine. Any ideas??
John B
Cal 227 #650
Re: [Cal_Boats] Kvh sailcomp
Allen Edwards2017-07-30 20:31 UTC
I had some electronics resetting caused by noise on the ignition line on my
Gray Marine gas engine. The solution was a special condenser made for
noise suppression. I can't recall the part number although it might be
RC-1 unless that is the part number for the one in the distributor. I
think I put it on the ignition coil input lead and from there to ground.
I am going to my boat tomorrow and if I remember, I can check the details.
Let me know if you are interested. If you don't have a gas engine, this
won't help.
On Sun, Jul 30, 2017 at 12:59 PM, John b je… [at] gmail.com [Cal_Boats] <
> John B
> Cal 227 #650
ccampbell2017-07-31 18:35 UTC
> have flickering display while the engine is running. This does not
> happen all of the time and never sofar while under sail. My other
> instrument a raymarine i50 tridata works fine. Any ideas??
Sail more and power less.
Helen Horn2017-07-31 18:52 UTC
Check for insulation wearing off the wires, maybe slight arcing in loops? Helen
On Mon, Jul 31, 2017 at 11:35 AM, ccampbell cc… [at] lsnm.org [Cal_Boats]<Ca… [at] yahoogroups.com> wrote:
Over the last few weeks I have noticed that my digital compass will have flickering display while the engine is running. This does not happen all of the time and never sofar while under sail. My other instrument a raymarine i50 tridata works fine. Any ideas??
RE: [Cal_Boats] Kvh sailcomp
Charlie Husar2017-07-31 19:12 UTC
You might be able to put a capacitor across the power line for the device (maybe a couple microfarads depending on current draw of the compass). Don’t know how hard this might be given the various connectors, but maybe at the power panel. . Another possibility is fatter wiring on that line, and maybe shielded or twisted pair wire. This is the sort of thing that can require some experimentation. I enjoy screwing around with electronics.
Best of Luck
Annapolis
Sent: Monday, July 31, 2017 2:53 PM
Subject: Re: [Cal_Boats] Kvh sailcomp
Sent from Yahoo Mail on Android <https://overview.mail.yahoo.com/mobile/?.src=Android>
On 7/30/2017 3:59 PM, John b je… [at] gmail.com <mailto:je… [at] gmail.com> [Cal_Boats] wrote:
Allen Edwards2017-07-31 20:07 UTC
Gas or Diesel?
On Mon, Jul 31, 2017 at 12:12 PM, 'Charlie Husar' hu… [at] gmail.com
> Best of Luck
> Charlie
> Annapolis
> *Sent:* Monday, July 31, 2017 2:53 PM
> *Subject:* Re: [Cal_Boats] Kvh sailcomp
> Helen
> Chris Campbell
Edward Stancil2017-08-01 19:04 UTC
Clean all grounds ...take digital temp
In fra red. Look at alt. Lead..trace
Wire harness to compass though
The switch check all butt splices
The temp should "bounce "
As you cross a compromised
Conection ..the engine vibration
And corrosion will make compass
Light flicker as over charging..
But start with basics..
Water in Battery..and grounds
Edward
On Jul 30, 2017 12:59 PM, "John b je… [at] gmail.com [Cal_Boats]" <
John B
Cal 227 #650
