4 messages2017-09-06 18:06 UTCthrough 2017-09-13 17:12 UTC
Cal 2-27 Reefing Ram Horn Hook
david howe2017-09-06 18:06 UTC
This weekend we planned on reefing the main and jib to make sure we could. Practice I guess you would say. I could not get the main tack reefing grommet to go on the rams head hook. It just would not reach it with enough slack to go around the horn. My neighbor suggested changing to a hook. Another more experienced sailor said the rams head was better and just rig up a soft shackle to leave in the sail. Wondering what everyone else uses?I do have a turning block at the clew side and a cleat near the mast.
Re: [Cal_Boats] Cal 2-27 Reefing Ram Horn Hook
NEWMAN2017-09-06 18:29 UTC
If I understand your post, mine has two reefing hooks where boom meets the
mast. And the grommet on the mainsail tack grommet has webbing through the
grommet with rings sewn to each end of the webbing. The rings on each side
of the sail slip onto the reefing hooks. I have found that the rings want
to slip off the reefing hooks, so I get the rings hooked in place, then run
a cord through the rings, so as to secure them in place.
We were reefed Saturday using the upper most reefing point in the 20 knots
winds while crossing the Bay. Was a fun ride.
This site has some pictures. The next to the last image on the page is
similar to my arrangement. He's calling them 'Floppy rings' on the sail
secured to J hooks.
http://joecoopersailing.com/sails-mainsail-measuring/
In the end you find what works best for your boat.
Leslie
Puffin Cal 33-2
On Wed, Sep 6, 2017 at 2:06 PM, david howe tr… [at] yahoo.com [Cal_Boats] <
Allen Edwards2017-09-06 18:32 UTC
There are lots of things you can do and I venture to say I have tried a
good number of them over the years. Getting a grommet to go over a hook is
not one of the ways I would recommend. The solution I like best is what my
new sail has and it is a strap with a ring on it instead of a grommet. You
can also put a soft shackle through the grommet with a ring on each end
large enough so they will not go through the grommet and then put the ring
over the hook. The other things I have tried don't work as well so I won't
confuse the discussion with them. You can have a sailmaker add a strap and
ring which will give you the best control over the positioning of the sail
or you can go with the soft shackle which might give some offset issues
that may or may not be an issue. Changing the hook seems like a poor idea.
On Wed, Sep 6, 2017 at 11:06 AM, david howe tr… [at] yahoo.com [Cal_Boats]
david howe2017-09-13 17:12 UTC
Thanks for the help. Going to check on adding rings.
Sent from Yahoo Mail for iPhone
On Wednesday, September 6, 2017, 2:32 PM, Allen Edwards al… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
There are lots of things you can do and I venture to say I have tried a good number of them over the years. Getting a grommet to go over a hook is not one of the ways I would recommend. The solution I like best is what my new sail has and it is a strap with a ring on it instead of a grommet. You can also put a soft shackle through the grommet with a ring on each end large enough so they will not go through the grommet and then put the ring over the hook. The other things I have tried don't work as well so I won't confuse the discussion with them. You can have a sailmaker add a strap and ring which will give you the best control over the positioning of the sail or you can go with the soft shackle which might give some offset issues that may or may not be an issue. Changing the hook seems like a poor idea.
On Wed, Sep 6, 2017 at 11:06 AM, david howe tr… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
