Cal 33.2 sail size
Cal 33.2 sail size
24 messages2017-10-17 17:51 UTCthrough 2017-10-24 20:43 UTC
Cal 33.2 sail size
matthew2017-10-17 17:51 UTC
Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle.Matthew
Re: [Cal_Boats] Cal 33.2 sail size
Donald C Dutton2017-10-17 18:07 UTC
Matthew, Cal 33-2 Rig Dimensions: I 46’ 0” J 13’ 3” P 40’ 6” E 12’ 3” Mainsail Area: 248.1 sq. ft. 100% Foretriangle: 304.8 sq. ft. Mast Height above DWL: 50’ 3” Hope that helps! Don Dutton 1986 Cal 33-2, “Quantum Evolution” > On Oct 17, 2017, at 10:51 AM, matthew ma… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle. > Matthew > >
NEWMAN2017-10-17 18:11 UTC
Hard to see the sail measurements... http://sailboatdata.com/viewrecord.asp?class_id=1960 On Tue, Oct 17, 2017 at 1:51 PM, matthew ma… [at] yahoo.com [Cal_Boats] < Ca… [at] yahoogroups.com> wrote: > > > Does anyone know the main and jib actual sail size on the Cal 33.2? Im not > near my boat to measure. I have a guy that has hundreds of used sails. Im > also considering getting a sewing machine and making them from a pre cut > kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from > Doyle. > Matthew > > >
NEWMAN2017-10-17 18:16 UTC
Oh, that link I sent, if you click on the 'KEY' you get how the dimensions are derived and you can then transfer the numbers from the table. http://sailboatdata.com/rig_diagram.htm http://sailboatdata.com/viewrecord.asp?class_id=1960 Leslie Puffin Cal 33-2 On Tue, Oct 17, 2017 at 2:07 PM, Donald C Dutton dn… [at] comcast.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > Matthew, > > Cal 33-2 Rig Dimensions: > I 46’ 0” > J 13’ 3” > P 40’ 6” > E 12’ 3” > > Mainsail Area: 248.1 sq. ft. > 100% Foretriangle: 304.8 sq. ft. > > Mast Height above DWL: 50’ 3” > > Hope that helps! > > Don Dutton > 1986 Cal 33-2, “Quantum Evolution” > > > On Oct 17, 2017, at 10:51 AM, matthew ma… [at] yahoo.com [Cal_Boats] < > Ca… [at] yahoogroups.com> wrote: > > > Does anyone know the main and jib actual sail size on the Cal 33.2? Im not > near my boat to measure. I have a guy that has hundreds of used sails. Im > also considering getting a sewing machine and making them from a pre cut > kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from > Doyle. > Matthew > > > >
John Raxter2017-10-17 18:23 UTC
Our cal 33 came with a main from a Catalina 34 tall rig. About 6" short on the boom and pendants added to reef points. Otherwise it works great! John Raxter 336-210-8073 (m) On Oct 17, 2017, at 1:51 PM, matthew ma… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle. Matthew
NEWMAN2017-10-17 19:14 UTC
We had a nice new full batten main made for Puffin by Ullman Sails in Deltaville VA two winters ago. They came to the boat, measured and had it ready in the Spring. I highly recommend them. They have a special discount if you order a sail during the winter. I would have emailed the group and given my old sail away for shipping cost, but it was so worn out it would tear if you looked at it sideways. I removed all the cars and threw the sail away. Leslie ​ On Tue, Oct 17, 2017 at 1:51 PM, matthew ma… [at] yahoo.com [Cal_Boats] < Ca… [at] yahoogroups.com> wrote: > > > Does anyone know the main and jib actual sail size on the Cal 33.2? Im not > near my boat to measure. I have a guy that has hundreds of used sails. Im > also considering getting a sewing machine and making them from a pre cut > kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from > Doyle. > Matthew > > >
matthew2017-10-17 20:10 UTC
Oh thats good to know, Thanks Leslie and everyone for your input! I didnt know how to translate those #s to actual sail size. From: "NEWMAN d2… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> To: Ca… [at] yahoogroups.com; Donald C Dutton <dn… [at] comcast.net> Cc: matthew <ma… [at] yahoo.com> Sent: Tuesday, October 17, 2017 1:17 PM Subject: Re: [Cal_Boats] Cal 33.2 sail size Oh, that link I sent, if you click on the 'KEY' you get how the dimensions are derived and you can then transfer the numbers from the table. http://sailboatdata.com/rig_diagram.htm http://sailboatdata.com/viewrecord.asp?class_id=1960 LesliePuffin Cal 33-2 On Tue, Oct 17, 2017 at 2:07 PM, Donald C Dutton dn… [at] comcast.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Matthew, Cal 33-2 Rig Dimensions:I 46’ 0”J 13’ 3”P 40’ 6”E 12’ 3” Mainsail Area: 248.1 sq. ft.100% Foretriangle: 304.8 sq. ft. Mast Height above DWL: 50’ 3” Hope that helps! Don Dutton1986 Cal 33-2, “Quantum Evolution” On Oct 17, 2017, at 10:51 AM, matthew ma… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle.Matthew
matthew2017-10-17 20:24 UTC
Is your toe rail actually in the water there? :) From: "NEWMAN d2… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> To: Ca… [at] yahoogroups.com; matthew <ma… [at] yahoo.com> Sent: Tuesday, October 17, 2017 2:15 PM Subject: Re: [Cal_Boats] Cal 33.2 sail size We had a nice new full batten main made for Puffin by Ullman Sails in Deltaville VA two winters ago. They came to the boat, measured and had it ready in the Spring. I highly recommend them. They have a special discount if you order a sail during the winter. I would have emailed the group and given my old sail away for shipping cost, but it was so worn out it would tear if you looked at it sideways. I removed all the cars and threw the sail away.Leslie ​ On Tue, Oct 17, 2017 at 1:51 PM, matthew ma… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle.Matthew
Re: [Cal_Boats] Cal 33.2 sail size [1 Attachment]
NEWMAN2017-10-17 20:40 UTC
No, an optical illusion. There were some rolling waves and I happen to be down in one when my friend on neighbor boat PEQUOD snapped the pic. DeAnne was using her zoom lens and it was very high resolution. I cropped the picture to focus on Puffin. There is a second shot showing us coming up from behind the wave. We were sailing together on a 9 day vacation this past June. Puffin and Pequod sailing the Southern Bay. On Tue, Oct 17, 2017 at 4:24 PM, matthew ma… [at] yahoo.com [Cal_Boats] < Ca… [at] yahoogroups.com> wrote: > > [Attachment(s) <#m_-1245475935451964763_TopText> from matthew included > below] > > Is your toe rail actually in the water there? :) > > >
RE: [Cal_Boats] Cal 33.2 sail size
Charlie Husar2017-10-17 21:25 UTC
Not to mention our recent discussion involving hull speed. The boat is at or near hull speed and is sinking down into the trough of its bow wave. That’s my story and I’m sticking to it! Cheers Charlie Annapolis From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] Sent: Tuesday, October 17, 2017 4:40 PM To: Ca… [at] yahoogroups.com; matthew <ma… [at] yahoo.com> Subject: Re: [Cal_Boats] Cal 33.2 sail size No, an optical illusion. There were some rolling waves and I happen to be down in one when my friend on neighbor boat PEQUOD snapped the pic. DeAnne was using her zoom lens and it was very high resolution. I cropped the picture to focus on Puffin. There is a second shot showing us coming up from behind the wave. We were sailing together on a 9 day vacation this past June. Puffin and Pequod sailing the Southern Bay. On Tue, Oct 17, 2017 at 4:24 PM, matthew ma… [at] yahoo.com <mailto:ma… [at] yahoo.com> [Cal_Boats] <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > wrote: [Attachment(s) from matthew included below] Is your toe rail actually in the water there? :)
NEWMAN2017-10-18 00:07 UTC
I enjoyed reading all the messages on the hull speed discussion. Leslie On Tuesday, October 17, 2017, Charlie Husar <hu… [at] gmail.com> wrote: > Not to mention our recent discussion involving hull speed. The boat is at > or near hull speed and is sinking down into the trough of its bow wave. > > > > That’s my story and I’m sticking to it! > > > > Cheers > > Charlie > > Annapolis > > > > *From:* Ca… [at] yahoogroups.com > <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');> [mailto: > Ca… [at] yahoogroups.com > <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');>] > *Sent:* Tuesday, October 17, 2017 4:40 PM > *To:* Ca… [at] yahoogroups.com > <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');>; matthew < > ma… [at] yahoo.com > <javascript:_e(%7B%7D,'cvml','ma… [at] yahoo.com');>> > *Subject:* Re: [Cal_Boats] Cal 33.2 sail size > > > > No, an optical illusion. There were some rolling waves and I happen to be > down in one when my friend on neighbor boat PEQUOD snapped the pic. DeAnne > was using her zoom lens and it was very high resolution. I cropped the > picture to focus on Puffin. There is a second shot showing us coming up > from behind the wave. We were sailing together on a 9 day vacation this > past June. Puffin and Pequod sailing the Southern Bay. > > > > On Tue, Oct 17, 2017 at 4:24 PM, matthew ma… [at] yahoo.com > <javascript:_e(%7B%7D,'cvml','ma… [at] yahoo.com');> [Cal_Boats] < > Ca… [at] yahoogroups.com > <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');>> wrote: > > > > *[Attachment(s) <#m_6933396427445857609_m_-1245475935451964763_TopText> > from matthew included below]* > > Is your toe rail actually in the water there? :) > > > > > > > > > >
Urbanski, Steven J.2017-10-19 10:03 UTC
Matthew, If you are shopping sewing machines, consider the LSZ-1 along with the Monster II Balance Wheel and Ultrafeed Industrial Sewing Table & Workhorse Servo Motor. Great control and amazing power (this thing would sew through steel plates!). I replaced the sacrificial sun cover on our 35 MKII this spring. It powered through half a dozen layers of Dacron, two layers of Sunbrella and webbing like a hot knife through butter. Also make a sail pack. I’m certain those two projects alone justified the cost (at least that is what I’m telling myself). Regards, Steve From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] Sent: Tuesday, October 17, 2017 12:51 PM To: Yahoogroups Subject: [Cal_Boats] Cal 33.2 sail size Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle. Matthew This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments.
matthew2017-10-19 15:55 UTC
Thanks for you input Steve, I am shopping around for a sewing machine, this is one I was considering. It has the walking foot AND zig zag pattern. Reliable Portable Walking Foot Zig-Zag Sewing Machine | | | | $ 499.99 | | | | | | | Reliable Portable Walking Foot Zig-Zag Sewing Machine No sewing job is too big for the compact and versatile Reliable Portable Walking Foot Zig-Zag Sewing Machine. Th... | | | | From: "'Urbanski, Steven J.' st… [at] ul.com [Cal_Boats]" <Ca… [at] yahoogroups.com> To: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com> Sent: Thursday, October 19, 2017 5:03 AM Subject: RE: [Cal_Boats] Cal 33.2 sail size Matthew, If you are shopping sewing machines, consider the LSZ-1 along with the Monster II Balance Wheel and Ultrafeed Industrial Sewing Table & Workhorse Servo Motor. Great control and amazing power (this thing would sew through steel plates!). I replaced the sacrificial sun cover on our 35 MKII this spring. It powered through half a dozen layers of Dacron, two layers of Sunbrella and webbing like a hot knife through butter. Also make a sail pack. I’m certain those two projects alone justified the cost (at least that is what I’m telling myself). Regards, Steve From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] Sent: Tuesday, October 17, 2017 12:51 PM To: Yahoogroups Subject: [Cal_Boats] Cal 33.2 sail size Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle. Matthew This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments. -- {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} hr {border:1px solid #d8d8d8;} {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} {margin-bottom:10px;} .yiv6688710080ad {padding:0 0;} .yiv6688710080ad p {margin:0;} .yiv6688710080ad a {color:#0000ff;text-decoration:none;} {font-family:Arial;} {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} .yiv6688710080ad {margin-bottom:10px;padding:0 0;} {font-family:Verdana;font-size:11px;padding:10px 0;} {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} span {font-weight:700;} span:first-child {text-transform:uppercase;} span a {color:#5085b6;text-decoration:none;} span span {color:#ff7900;} span .yiv6688710080underline {text-decoration:underline;} .yiv6688710080attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} .yiv6688710080attach div a {text-decoration:none;} .yiv6688710080attach img {border:none;padding-right:5px;} .yiv6688710080attach label {display:block;margin-bottom:5px;} .yiv6688710080attach label a {text-decoration:none;} blockquote {margin:0 0 0 4px;} .yiv6688710080bold {font-family:Arial;font-size:13px;font-weight:700;} .yiv6688710080bold a {text-decoration:none;} dd.yiv6688710080last p a {font-family:Verdana;font-weight:700;} dd.yiv6688710080last p span {margin-right:10px;font-family:Verdana;font-weight:700;} dd.yiv6688710080last p span.yiv6688710080yshortcuts {margin-right:0;} div.yiv6688710080attach-table div div a {text-decoration:none;} div.yiv6688710080attach-table {width:400px;} div.yiv6688710080file-title a, div.yiv6688710080file-title a:active, div.yiv6688710080file-title a:hover, div.yiv6688710080file-title a:visited {text-decoration:none;} div.yiv6688710080photo-title a, div.yiv6688710080photo-title a:active, div.yiv6688710080photo-title a:hover, div.yiv6688710080photo-title a:visited {text-decoration:none;} div p a span.yiv6688710080yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;} .yiv6688710080green {color:#628c2a;} .yiv6688710080MsoNormal {margin:0 0 0 0;} o {font-size:0;} div {float:left;width:72px;} div div {border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} {font-size:77%;} {font-size:77%;} .yiv6688710080replbq {margin:4px;} div a:first-child {margin-right:2px;padding-right:5px;} {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} table {font-size:inherit;font:100%;} select, input, textarea {font:99% Arial, Helvetica, clean, sans-serif;} pre, code {font:115% monospace;} * {line-height:1.22em;} {padding-bottom:10px;} p a {font-family:Verdana;} p span {color:#1E66AE;font-weight:700;} {color:#ff7900;font-weight:700;} {margin-bottom:20px;padding:0px;} li a {font-size:130%;text-decoration:none;} li {font-size:77%;list-style-type:square;padding:6px 0;} ul {margin:0;padding:0 0 0 8px;} {font-family:Georgia;} p {margin:0 0 1em 0;} tt {font-size:120%;} ul li:last-child {border-right:none !important;}
Terry Spencer2017-10-19 16:15 UTC
Matthew, That machine is identical to my Sailrite machine that I bought about 12 years ago and the one that Steve recommended. Great machines. Note that you can get many accessories from Sailrite as well as support. I too paid for the machine with all the DIY projects I did in the first couple of years I owned the machine. I never made a sail and think that it would be more difficult, but not impossible, without a machine with a longer arm. Good luck. Terry Capriccio Cal 2-29 Tacpma > On Oct 19, 2017, at 8:55 AM, matthew ma… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > Reliable Portable Walking Foot Zig-Zag Sewing Machine <https://www.bedbathandbeyond.com/store/product/reliable-portable-walking-foot-zig-zag-sewing-machine/3287018?skuId=46158512>
Urbanski, Steven J.2017-10-19 16:17 UTC
Hi Matthew, The LSZ-1 has zig-zag. What I don’t see on the Reliable machine is stitch length adjustment. The Sailrite machine has mechanical stops on the direction lever to allow stitch length adjustment. [cid:image001.jpg@01D348CB.E2EB2AA0] From: matthew [mailto:ma… [at] yahoo.com] Sent: Thursday, October 19, 2017 10:55 AM To: Ca… [at] yahoogroups.com; Urbanski, Steven J. Subject: Re: [Cal_Boats] Cal 33.2 sail size Thanks for you input Steve, I am shopping around for a sewing machine, this is one I was considering. It has the walking foot AND zig zag pattern. Reliable Portable Walking Foot Zig-Zag Sewing Machine<https://www.bedbathandbeyond.com/store/product/reliable-portable-walking-foot-zig-zag-sewing-machine/3287018?skuId=46158512> [cid:image002.jpg@01D348CB.E2EB2AA0] [Text Box: $ 499.99] [https://s.yimg.com/nq/storm/assets/enhancrV2/23/logos/bedbathandbeyond.png] Reliable Portable Walking Foot Zig-Zag Sewing Machine No sewing job is too big for the compact and versatile Reliable Portable Walking Foot Zig-Zag Sewing Machine. Th... From: "'Urbanski, Steven J.' st… [at] ul.com<mailto:st… [at] ul.com> [Cal_Boats]" <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>> To: "Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>" <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>> Sent: Thursday, October 19, 2017 5:03 AM Subject: RE: [Cal_Boats] Cal 33.2 sail size Matthew, If you are shopping sewing machines, consider the LSZ-1 along with the Monster II Balance Wheel and Ultrafeed Industrial Sewing Table & Workhorse Servo Motor. Great control and amazing power (this thing would sew through steel plates!). I replaced the sacrificial sun cover on our 35 MKII this spring. It powered through half a dozen layers of Dacron, two layers of Sunbrella and webbing like a hot knife through butter. Also make a sail pack. I’m certain those two projects alone justified the cost (at least that is what I’m telling myself). Regards, Steve From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com] Sent: Tuesday, October 17, 2017 12:51 PM To: Yahoogroups Subject: [Cal_Boats] Cal 33.2 sail size Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle. Matthew This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments. This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments.
Terry Spencer2017-10-19 16:41 UTC
Steve, That is a nice feature. Looks like it is a salivate add-on that screws in where the other plate was on my older model. I have feature envy and am going to check Sailrite to see if my older model could be modified. Terry > On Oct 19, 2017, at 9:17 AM, 'Urbanski, Steven J.' st… [at] ul.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > Hi Matthew, > > > > The LSZ-1 has zig-zag. What I don’t see on the Reliable machine is stitch length adjustment. The Sailrite machine has mechanical stops on the direction lever to allow stitch length adjustment. > > > > <image001.jpg> > > <> > From: matthew [mailto:ma… [at] yahoo.com <mailto:ma… [at] yahoo.com>] > Sent: Thursday, October 19, 2017 10:55 AM > To: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>; Urbanski, Steven J. > Subject: Re: [Cal_Boats] Cal 33.2 sail size > > > > Thanks for you input Steve, I am shopping around for a sewing machine, this is one I was considering. It has the walking foot AND zig zag pattern. Reliable Portable Walking Foot Zig-Zag Sewing Machine <https://www.bedbathandbeyond.com/store/product/reliable-portable-walking-foot-zig-zag-sewing-machine/3287018?skuId=46158512> > > > <image002.jpg> > > > <image007.png> > > > > Reliable Portable Walking Foot Zig-Zag Sewing Machine > No sewing job is too big for the compact and versatile Reliable Portable Walking Foot Zig-Zag Sewing Machine. Th... > > > > > > From: "'Urbanski, Steven J.' st… [at] ul.com <mailto:st… [at] ul.com> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>> > To: "Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>> > Sent: Thursday, October 19, 2017 5:03 AM > Subject: RE: [Cal_Boats] Cal 33.2 sail size > > > > > > Matthew, > > > > If you are shopping sewing machines, consider the LSZ-1 along with the Monster II Balance Wheel and Ultrafeed Industrial Sewing Table & Workhorse Servo Motor. Great control and amazing power (this thing would sew through steel plates!). > > > > I replaced the sacrificial sun cover on our 35 MKII this spring. It powered through half a dozen layers of Dacron, two layers of Sunbrella and webbing like a hot knife through butter. Also make a sail pack. I’m certain those two projects alone justified the cost (at least that is what I’m telling myself). > > > > Regards, > > > > Steve > > > > > > > > > > From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>] > Sent: Tuesday, October 17, 2017 12:51 PM > To: Yahoogroups > Subject: [Cal_Boats] Cal 33.2 sail size > > > > > > Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle. > > Matthew > > > This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments. > > > > > > This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments. > > >
Charlie Husar2017-10-19 17:58 UTC
Geez, Steve. Looks like it would not take too much extra effort to turn that baby into an autohelm. Cheers Charlie Annapolis From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] Sent: Thursday, October 19, 2017 12:18 PM To: Ca… [at] yahoogroups.com; matthew <ma… [at] yahoo.com> Subject: RE: [Cal_Boats] Cal 33.2 sail size Hi Matthew, The LSZ-1 has zig-zag. What I don’t see on the Reliable machine is stitch length adjustment. The Sailrite machine has mechanical stops on the direction lever to allow stitch length adjustment. From: matthew [mailto:ma… [at] yahoo.com] Sent: Thursday, October 19, 2017 10:55 AM To: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> ; Urbanski, Steven J. Subject: Re: [Cal_Boats] Cal 33.2 sail size Thanks for you input Steve, I am shopping around for a sewing machine, this is one I was considering. It has the walking foot AND zig zag pattern. Reliable Portable Walking Foot Zig-Zag Sewing Machine <https://www.bedbathandbeyond.com/store/product/reliable-portable-walking-foot-zig-zag-sewing-machine/3287018?skuId=46158512> <https://s.yimg.com/nq/storm/assets/enhancrV2/23/logos/bedbathandbeyond.png> Reliable Portable Walking Foot Zig-Zag Sewing Machine No sewing job is too big for the compact and versatile Reliable Portable Walking Foot Zig-Zag Sewing Machine. Th... _____ From: "'Urbanski, Steven J.' st… [at] ul.com <mailto:st… [at] ul.com> [Cal_Boats]" <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > To: "Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> " <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > Sent: Thursday, October 19, 2017 5:03 AM Subject: RE: [Cal_Boats] Cal 33.2 sail size Matthew, If you are shopping sewing machines, consider the LSZ-1 along with the Monster II Balance Wheel and Ultrafeed Industrial Sewing Table & Workhorse Servo Motor. Great control and amazing power (this thing would sew through steel plates!). I replaced the sacrificial sun cover on our 35 MKII this spring. It powered through half a dozen layers of Dacron, two layers of Sunbrella and webbing like a hot knife through butter. Also make a sail pack. I’m certain those two projects alone justified the cost (at least that is what I’m telling myself). Regards, Steve From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com] Sent: Tuesday, October 17, 2017 12:51 PM To: Yahoogroups Subject: [Cal_Boats] Cal 33.2 sail size Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle. Matthew This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments. This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments.
Urbanski, Steven J.2017-10-19 18:21 UTC
Hi Charlie, The table has a ¾ horsepower motor with about 4:1 reduction. I’d be afraid it would pull the steering pedestal from the cockpit floor. BTW-enjoyed the frostbiting photos. I’m jealous of anyone who can sail year-round…even if you have to shovel off the decks. Regards, Steve From: Charlie Husar [mailto:hu… [at] gmail.com] Sent: Thursday, October 19, 2017 12:59 PM To: Ca… [at] yahoogroups.com; Urbanski, Steven J. Subject: RE: [Cal_Boats] Cal 33.2 sail size Geez, Steve. Looks like it would not take too much extra effort to turn that baby into an autohelm. Cheers Charlie Annapolis From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com] Sent: Thursday, October 19, 2017 12:18 PM To: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>; matthew <ma… [at] yahoo.com<mailto:ma… [at] yahoo.com>> Subject: RE: [Cal_Boats] Cal 33.2 sail size Hi Matthew, The LSZ-1 has zig-zag. What I don’t see on the Reliable machine is stitch length adjustment. The Sailrite machine has mechanical stops on the direction lever to allow stitch length adjustment. [cid:image001.jpg@01D348DB.91914210] From: matthew [mailto:ma… [at] yahoo.com] Sent: Thursday, October 19, 2017 10:55 AM To: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>; Urbanski, Steven J. Subject: Re: [Cal_Boats] Cal 33.2 sail size Thanks for you input Steve, I am shopping around for a sewing machine, this is one I was considering. It has the walking foot AND zig zag pattern. Reliable Portable Walking Foot Zig-Zag Sewing Machine<https://www.bedbathandbeyond.com/store/product/reliable-portable-walking-foot-zig-zag-sewing-machine/3287018?skuId=46158512> [cid:image002.jpg@01D348DB.91914210] [Text Box: $ 499.99] [https://s.yimg.com/nq/storm/assets/enhancrV2/23/logos/bedbathandbeyond.png] Reliable Portable Walking Foot Zig-Zag Sewing Machine No sewing job is too big for the compact and versatile Reliable Portable Walking Foot Zig-Zag Sewing Machine. Th... From: "'Urbanski, Steven J.' st… [at] ul.com<mailto:st… [at] ul.com> [Cal_Boats]" <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>> To: "Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>" <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>> Sent: Thursday, October 19, 2017 5:03 AM Subject: RE: [Cal_Boats] Cal 33.2 sail size Matthew, If you are shopping sewing machines, consider the LSZ-1 along with the Monster II Balance Wheel and Ultrafeed Industrial Sewing Table & Workhorse Servo Motor. Great control and amazing power (this thing would sew through steel plates!). I replaced the sacrificial sun cover on our 35 MKII this spring. It powered through half a dozen layers of Dacron, two layers of Sunbrella and webbing like a hot knife through butter. Also make a sail pack. I’m certain those two projects alone justified the cost (at least that is what I’m telling myself). Regards, Steve From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com] Sent: Tuesday, October 17, 2017 12:51 PM To: Yahoogroups Subject: [Cal_Boats] Cal 33.2 sail size Does anyone know the main and jib actual sail size on the Cal 33.2? Im not near my boat to measure. I have a guy that has hundreds of used sails. Im also considering getting a sewing machine and making them from a pre cut kit from sailrite. However, There're fabric is only 6.4 oz vs 8 oz from Doyle. Matthew This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments. This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments. This e-mail may contain privileged or confidential information. If you are not the intended recipient: (1) you may not disclose, use, distribute, copy or rely upon this message or attachment(s); and (2) please notify the sender by reply e-mail, and then delete this message and its attachment(s). Underwriters Laboratories Inc. and its affiliates disclaim all liability for any errors, omissions, corruption or virus in this message or any attachments.
matthew2017-10-20 05:51 UTC
Thanks for pointing out that important feature Steve. I am definitely a sewing newbie and Im glad I brought this up here. I had no idea we have a buntch of cal list sail lofts going on! :)Matthew,86 Cal 33.2 Warm Winds From: "'Urbanski, Steven J.' st… [at] ul.com [Cal_Boats]" <Ca… [at] yahoogroups.com> To: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com>; matthew <ma… [at] yahoo.com> Sent: Thursday, October 19, 2017 11:28 AM Subject: RE: [Cal_Boats] Cal 33.2 sail size Hi Matthew, The LSZ-1 has zig-zag. What I don’t see on the Reliable machine is stitch length adjustment. The Sailrite machine has mechanical stops on the direction lever to allow stitch length adjustment.
NEWMAN2017-10-20 15:33 UTC
I own a TACSEW industrial walking foot sewing machine. It only does straight stitch. I found that sail work other than sewing on the UV shield I should leave to the sail maker. I have made biminis, dodgers, sail covers and winch covers for all my boats over the years, as well as recovered car and truck seats and the like. Machine has well paid for itself. I learned the basics as a kid from my Mom, who had a re-upholstery business. There are two types of walking foot machines....needle fed and presser foot fed. I have always liked the needle fed, where the needle walks and pulls the fabric through. The presser foot feed uses the presser foot to walk and pull the fabric, and the needle does not walk. Advantages and disadvantages to both types. Needle fed guarantees a uniform stitch. Mine machine sits on a table, has the big motor, is belt driven and very heavy duty. There is a foot pedal to control the sewing speed and it is clutch driven. No worries of it getting out of control. I have looked at the machines sold by sailrite. They are the presser foot feed type, portable and also do zig-zag. Only downside is they are small and not much room in the sewing head to bunch fabric as you sew. I have used my Tacsew for over 20 years and not needed zig-zag. Leslie Puffin Cal 33-2 On Fri, Oct 20, 2017 at 1:51 AM, matthew ma… [at] yahoo.com [Cal_Boats] < Ca… [at] yahoogroups.com> wrote: > > > Thanks for pointing out that important feature Steve. I am definitely a > sewing newbie and Im glad I brought this up here. I had no idea we have a > buntch of cal list sail lofts going on! :) > Matthew, > 86 Cal 33.2 Warm Winds > > > ------------------------------ > *From:* "'Urbanski, Steven J.' st… [at] ul.com [Cal_Boats]" < > Ca… [at] yahoogroups.com> > *To:* "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com>; matthew < > ma… [at] yahoo.com> > *Sent:* Thursday, October 19, 2017 11:28 AM > *Subject:* RE: [Cal_Boats] Cal 33.2 sail size > > > Hi Matthew, > > The LSZ-1 has zig-zag. What I don’t see on the Reliable machine is stitch > length adjustment. The Sailrite machine has mechanical stops on the > direction lever to allow stitch length adjustment. > > > > >
matthew2017-10-22 02:12 UTC
Leslie, Why do you feel you should leave the sail work to the sail maker? Maybe I shouldn't take it on as my first sewing project after I get a machine. Is it due to not having a zig zag machine? I know most of my current jib is done with it. From my understanding a sail kit can be ordered from sailrite and all of the panels are pre cut and labeled. All one has to do is connect them basically, And also taking full learning advantage from all of their videos as well.Matthew From: "NEWMAN d2… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> To: Ca… [at] yahoogroups.com; matthew <ma… [at] yahoo.com> Cc: "Urbanski, Steven J." <st… [at] ul.com> Sent: Friday, October 20, 2017 10:40 AM Subject: Re: [Cal_Boats] Cal 33.2 sail size I own a TACSEW industrial walking foot sewing machine. It only does straight stitch. I found that sail work other than sewing on the UV shield I should leave to the sail maker. I have made biminis, dodgers, sail covers and winch covers for all my boats over the years, as well as recovered car and truck seats and the like. Machine has well paid for itself. I learned the basics as a kid from my Mom, who had a re-upholstery business. There are two types of walking foot machines....needle fed and presser foot fed. I have always liked the needle fed, where the needle walks and pulls the fabric through. The presser foot feed uses the presser foot to walk and pull the fabric, and the needle does not walk. Advantages and disadvantages to both types. Needle fed guarantees a uniform stitch. Mine machine sits on a table, has the big motor, is belt driven and very heavy duty. There is a foot pedal to control the sewing speed and it is clutch driven. No worries of it getting out of control. I have looked at the machines sold by sailrite. They are the presser foot feed type, portable and also do zig-zag. Only downside is they are small and not much room in the sewing head to bunch fabric as you sew. I have used my Tacsew for over 20 years and not needed zig-zag. LesliePuffin Cal 33-2 On Fri, Oct 20, 2017 at 1:51 AM, matthew ma… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Thanks for pointing out that important feature Steve. I am definitely a sewing newbie and Im glad I brought this up here. I had no idea we have a buntch of cal list sail lofts going on! :)Matthew,86 Cal 33.2 Warm Winds From: "'Urbanski, Steven J.' st… [at] ul.com [Cal_Boats]" <Ca… [at] yahoogroups.com> To: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com>; matthew <ma… [at] yahoo.com> Sent: Thursday, October 19, 2017 11:28 AM Subject: RE: [Cal_Boats] Cal 33.2 sail size Hi Matthew, The LSZ-1 has zig-zag. What I don’t see on the Reliable machine is stitch length adjustment. The Sailrite machine has mechanical stops on the direction lever to allow stitch length adjustment.
NEWMAN2017-10-22 02:29 UTC
Some things I leave to the experts. A sail is large. Lots of material to work with. Stitching needs to be very good to hold up to the stress that the sail will encounter. Sail makers are setup to sew sails. Very large sewing machines recessed in the floor so they can slide the sail through the machine easily. We had a sail made for our Cal 33-2 last winter. They went to our boat, measured, made sure it was a perfect fit. Full batten sail complete with new trucks and associated hardware. $2600. If you factor how many years the sail will last and how much enjoyment it will provide, that isn't a lot of money. All I had to do was install onto my boat, which I do every Spring anyway. I have enough years and life lessons now to know when to take on a job or to pass it on to the experts. I do enough myself that every so often it is good to let someone else do it. Leslie On Saturday, October 21, 2017, matthew <ma… [at] yahoo.com> wrote: > Leslie, Why do you feel you should leave the sail work to the sail maker? > Maybe I shouldn't take it on as my first sewing project after I get a > machine. Is it due to not having a zig zag machine? I know most of my > current jib is done with it. From my understanding a sail kit can be > ordered from sailrite and all of the panels are pre cut and labeled. All > one has to do is connect them basically, And also taking full learning > advantage from all of their videos as well. > Matthew > > > ------------------------------ > *From:* "NEWMAN d2… [at] gmail.com > <javascript:_e(%7B%7D,'cvml','d2… [at] gmail.com');> [Cal_Boats]" < > Ca… [at] yahoogroups.com > <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');>> > *To:* Ca… [at] yahoogroups.com > <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');>; matthew < > ma… [at] yahoo.com > <javascript:_e(%7B%7D,'cvml','ma… [at] yahoo.com');>> > *Cc:* "Urbanski, Steven J." <st… [at] ul.com > <javascript:_e(%7B%7D,'cvml','st… [at] ul.com');>> > *Sent:* Friday, October 20, 2017 10:40 AM > *Subject:* Re: [Cal_Boats] Cal 33.2 sail size > > > I own a TACSEW industrial walking foot sewing machine. It only does > straight stitch. I found that sail work other than sewing on the UV shield > I should leave to the sail maker. I have made biminis, dodgers, sail covers > and winch covers for all my boats over the years, as well as recovered car > and truck seats and the like. Machine has well paid for itself. I learned > the basics as a kid from my Mom, who had a re-upholstery business. > > There are two types of walking foot machines....needle fed and presser > foot fed. I have always liked the needle fed, where the needle walks and > pulls the fabric through. The presser foot feed uses the presser foot to > walk and pull the fabric, and the needle does not walk. Advantages and > disadvantages to both types. Needle fed guarantees a uniform stitch. > > Mine machine sits on a table, has the big motor, is belt driven and very > heavy duty. There is a foot pedal to control the sewing speed and it is > clutch driven. No worries of it getting out of control. I have looked at > the machines sold by sailrite. They are the presser foot feed type, > portable and also do zig-zag. Only downside is they are small and not much > room in the sewing head to bunch fabric as you sew. > > I have used my Tacsew for over 20 years and not needed zig-zag. > > Leslie > Puffin Cal 33-2 > > > On Fri, Oct 20, 2017 at 1:51 AM, matthew ma… [at] yahoo.com > <javascript:_e(%7B%7D,'cvml','ma… [at] yahoo.com');> [Cal_Boats] < > Ca… [at] yahoogroups.com > <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');>> wrote: > > > Thanks for pointing out that important feature Steve. I am definitely a > sewing newbie and Im glad I brought this up here. I had no idea we have a > buntch of cal list sail lofts going on! :) > Matthew, > 86 Cal 33.2 Warm Winds > > > ------------------------------ > *From:* "'Urbanski, Steven J.' st… [at] ul.com > <javascript:_e(%7B%7D,'cvml','st… [at] ul.com');> [Cal_Boats]" < > Ca… [at] yahoogroups.com > <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');>> > *To:* "Ca… [at] yahoogroups.com > <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');>" < > Ca… [at] yahoogroups.com > <javascript:_e(%7B%7D,'cvml','Ca… [at] yahoogroups.com');>>; matthew < > ma… [at] yahoo.com > <javascript:_e(%7B%7D,'cvml','ma… [at] yahoo.com');>> > *Sent:* Thursday, October 19, 2017 11:28 AM > *Subject:* RE: [Cal_Boats] Cal 33.2 sail size > > > Hi Matthew, > > The LSZ-1 has zig-zag. What I don’t see on the Reliable machine is stitch > length adjustment. The Sailrite machine has mechanical stops on the > direction lever to allow stitch length adjustment. > > > > > > > >
ccampbell2017-10-24 20:33 UTC
On 10/21/2017 10:29 PM, NEWMAN d2… [at] gmail.com [Cal_Boats] wrote: > > > Some things I leave to the experts. A sail is large. Lots of material > to work with. Stitching needs to be very good to hold up to the stress > that the sail will encounter. Sail makers are setup to sew sails. Very > large sewing machines recessed in the floor so they can slide the sail > through the machine easily. We had a sail made for our Cal 33-2 last > winter. They went to our boat, measured, made sure it was a perfect > fit. Full batten sail complete with new trucks and associated > hardware. $2600. If you factor how many years the sail will last and > how much enjoyment it will provide, that isn't a lot of money. I was going to say the same thing, although I acknowledge that sometimes we have a choice between doing things ourselves and not doing them at all. Better to DIY than just sit at home. On my other boat, the current mainsail was purchased around 1970. I was sailing with it 3 days ago and almost had 2nd thoughts about the new sail I have ordered--the old one looked pretty good. But 1970 is 47 years back, and that's pretty good service. A professional's competent work can last a long time. My Cal 20's main, the one one that came with it, was looking sad, so I bought a used one through somebody on this list. It had a better shape than the one I already had, but now it's getting a bit sad too. That was at least 12 years ago. Time to hunt for another one. Chris Campbell
NEWMAN2017-10-24 20:43 UTC
Chris, I am right there with you. I am a DIY guy. Replaced the whole cabin sole in Puffin. But wood working I have the tools and experience to do. Sails I can't justify the zigzag machine for the job and plus just don't want to spend my time that way. I already have my straight stitch walking foot machine so I just do the simpler jobs like biminis and wheel covers. And after getting the sail from Ulman sails, we'll it is a work of art. Leslie On Tuesday, October 24, 2017, ccampbell <cc… [at] lsnm.org> wrote: > > > On 10/21/2017 10:29 PM, NEWMAN d2… [at] gmail.com > <javascript:_e(%7B%7D,'cvml','d2… [at] gmail.com');> [Cal_Boats] wrote: > > > > Some things I leave to the experts. A sail is large. Lots of material to > work with. Stitching needs to be very good to hold up to the stress that > the sail will encounter. Sail makers are setup to sew sails. Very large > sewing machines recessed in the floor so they can slide the sail through > the machine easily. We had a sail made for our Cal 33-2 last winter. They > went to our boat, measured, made sure it was a perfect fit. Full batten > sail complete with new trucks and associated hardware. $2600. If you factor > how many years the sail will last and how much enjoyment it will provide, > that isn't a lot of money. > > > I was going to say the same thing, although I acknowledge that sometimes > we have a choice between doing things ourselves and not doing them at all. > Better to DIY than just sit at home. > > On my other boat, the current mainsail was purchased around 1970. I was > sailing with it 3 days ago and almost had 2nd thoughts about the new sail I > have ordered--the old one looked pretty good. But 1970 is 47 years back, > and that's pretty good service. A professional's competent work can last a > long time. > > My Cal 20's main, the one one that came with it, was looking sad, so I > bought a used one through somebody on this list. It had a better shape > than the one I already had, but now it's getting a bit sad too. That was > at least 12 years ago. Time to hunt for another one. > > Chris Campbell > >
