5 messages2017-11-09 14:38 UTCthrough 2017-11-09 18:13 UTC
Tachometer in Cal 33-2
NEWMAN2017-11-09 14:38 UTC
Have a question about the tach in my Cal 33-2. Mine started jumping
somewhat. It reads low or rather, it bounces and can't stay at I guess
whatever the RPM of the engine actually is. But after a while, maybe it has
warmed up, the tach starts working.
Anyone encountered this? Could it be wiring or does this sound like the
tach is failing? Does anyone know the model tach I need to purchase for
replacement? I suspect it has an internal problem. I glanced at the wiring
and nothing looks out of sorts. Didn't really see any corrosion or anything.
Leslie Newman
Puffin 1986 Cal 33-2
RE: [Cal_Boats] Tachometer in Cal 33-2
Al Waschka2017-11-09 16:39 UTC
Mine would read at about ½ speed. When I wiggled the connector at the engine (port side low) where the harness to the instrument panel plugged in, it read correctly. I intended to clean the connections but never did it.. Now it reads low all the time. I’ll be doing an engine service soon so I will clean the contacts then.
Al
Sent from Mail for Windows 10
Sent: Thursday, November 9, 2017 9:39 AM
To: ca… [at] yahoogroups.com
Subject: [Cal_Boats] Tachometer in Cal 33-2
Have a question about the tach in my Cal 33-2. Mine started jumping somewhat. It reads low or rather, it bounces and can't stay at I guess whatever the RPM of the engine actually is. But after a while, maybe it has warmed up, the tach starts working.
Anyone encountered this? Could it be wiring or does this sound like the tach is failing? Does anyone know the model tach I need to purchase for replacement? I suspect it has an internal problem. I glanced at the wiring and nothing looks out of sorts. Didn't really see any corrosion or anything.
Leslie Newman
Re: [Cal_Boats] Tachometer in Cal 33-2
NEWMAN2017-11-09 17:49 UTC
Thanks Al. Mine is sort of jumping when I throttle up. At first it was
jumping around the RPM I was running. Say I wanted to cruise at 1700, the
needle would pulse a little above and back. But last couple times out when
I throttle up it would not go up past say 1500 and yet I know I was at 2000
by engine sound. And besides not showing true RPM, it is bouncing like it
is trying to get to the true reading. I was thinking the tachometer itself
was failing, but I have not actually put a meter on anything or checked the
wiring at the sender. So I have some homework to do this coming Saturday.
Leslie
> it. Now it reads low all the time. I’ll be doing an engine service soon
> Al
> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> Windows 10
> *From: *NEWMAN d2… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com>
> *Sent: *Thursday, November 9, 2017 9:39 AM
> *To: *ca… [at] yahoogroups.com
> *Subject: *[Cal_Boats] Tachometer in Cal 33-2
> Thanks,
> Leslie Newman
> Puffin 1986 Cal 33
> <https://maps.google.com/?q=1986+Cal+33&entry=gmail&source=g>-2
John Raxter2017-11-09 17:56 UTC
Unfortunately tinned wire was not used when these boats were built. Any exposed wiring or connectors will corrode in time. If enough wire is available, strip back to clean copper and use a sealed connector to reattach.
Ymmv
John Raxter
Cal 33
Oriental NC
On Nov 9, 2017, at 12:49 PM, NEWMAN d2… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
Thanks Al. Mine is sort of jumping when I throttle up. At first it was jumping around the RPM I was running. Say I wanted to cruise at 1700, the needle would pulse a little above and back. But last couple times out when I throttle up it would not go up past say 1500 and yet I know I was at 2000 by engine sound. And besides not showing true RPM, it is bouncing like it is trying to get to the true reading. I was thinking the tachometer itself was failing, but I have not actually put a meter on anything or checked the wiring at the sender. So I have some homework to do this coming Saturday.
Leslie
> Mine would read at about ½ speed. When I wiggled the connector at the engine (port side low) where the harness to the instrument panel plugged in, it read correctly. I intended to clean the connections but never did it. Now it reads low all the time. I’ll be doing an engine service soon so I will clean the contacts then.
> Al
> From: NEWMAN d2… [at] gmail.com [Cal_Boats]
> Thanks,
> Leslie Newman
ma… [at] yahoo.com2017-11-09 18:13 UTC
Hello Leslie, I would start by making sure contacts are clean on the engine grounds and where ever it connects to the engine. It could be the tack it's self. Matthew
On Nov 9, 2017 8:38 AM, "NEWMAN d2… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
Thanks, Leslie Newman Puffin 1986 Cal 33-2
