2 messages2017-11-20 10:56 UTCthrough 2017-11-20 13:08 UTC
Cal 33-2 Tachometer problem fixed
NEWMAN2017-11-20 10:56 UTC
Thanks to those that had replied regarding my tachometer problem. The tach
was reading low and surging. It was a connection problem. The two wires
that connect to the tach sending unit on the engine were faulty. The spade
connectors needed to be replaced as the wire on one was broken at the
connector and not making good connection. Was simple fix of soldering new
connectors, cleaning the terminals on the sender and slipping the
connectors into place. Tach now reads rock solid RPM.
Leslie
Puffin Cal 33-2
RE: [Cal_Boats] Cal 33-2 Tachometer problem fixed
Charlie Husar2017-11-20 13:08 UTC
Thanks for update, Leslie. Just wanted to drop a note for Lanocote (or other anhydrous lanolin). A dab in each crimped connection (when crimping) and a dab on each spade or other electrical connection (when connecting) does wonders. Same stuff to be used on stainless screw to aluminum connections.
Annapolis
Sent: Monday, November 20, 2017 5:56 AM
To: ca… [at] yahoogroups.com
Subject: [Cal_Boats] Cal 33-2 Tachometer problem fixed
Thanks to those that had replied regarding my tachometer problem. The tach was reading low and surging. It was a connection problem. The two wires that connect to the tach sending unit on the engine were faulty. The spade connectors needed to be replaced as the wire on one was broken at the connector and not making good connection. Was simple fix of soldering new connectors, cleaning the terminals on the sender and slipping the connectors into place. Tach now reads rock solid RPM.
Leslie
Puffin Cal 33-2
