3 messages2018-01-02 19:29 UTCthrough 2018-01-03 02:10 UTC
Perkins 4.236 Thermostat question
Keenan Smith2018-01-02 19:29 UTC
Happy New Year everyone!! I posted a while back on a head gasket job and happy to say I completed that project which also turned into rebuilding to injectors, professionally servicing the heat exchanger and oil cooler, a new water pump, and all new hoses.
I had to replace the thermostat about a year ago and I used a 180 degree thermostat. The sender is towards the aft of the engine so what I end up getting is reading that is a hotter temp, up to 200, before the thermostat opens up and then it holds an even 180. It was doing this before I changed the thermostat because I thought the original one was sticking. The alarm is closer to the thermostat. I’m wondering if I should switch out the locations for the alarm and sender for a more accurate reading. I’m also thinking of going with a 170 thermostat. I just serviced the whole cooling system (except for replacing the thermostat) so I know I have good cooling and lots of water running through the engine.
Any input is appreciated!
Keenan Smith
S/V Madison de Sante
Re: [Cal_Boats] Perkins 4.236 Thermostat question
Duane Knize Boat2018-01-02 21:58 UTC
Keenan,
If it is viable, with wire extensions, it might be good to place all the
senders and thermostat in a pan of water on the galley stove along with
a decent kitchen thermometer and check accuracy.
Also, I seem to remember a Cal 46 /Maison de Sante/ at Kona Marina, San
Diego before we sailed /Marlyn/ up to Frisco.
Same boat? Still there?
Duane
Duane Knize
S/V Marlyn
1978 Cal 2-39 #18
berthed: Emeryville, CA
kn… [at] san.rr.com
> Thanks,
> Keenan Smith
Keenan Smith2018-01-03 02:10 UTC
Hi Duane,
Thanks for your insight. I just noticed today that my cockpit gauge and interior gauge are two different temp ranges so I bought two new gauges today and a dual sender online.
This is the Maison de Sante you’re thinking of but I have been the owner only since last December. The previous owner had her 30yrs so it didn’t feel right changing the name. Plus, I need all the good luck I can get. She was in pretty good shape when I bought her but I have since done a total re-rig and engine overhaul plus a bunch of normal things like a new water heater, fridge, and batteries. I think I’m just about done going through ever inch of the boat. Today was a new sump pump and check valves for the forward head.
I should post photos :)
> On Jan 2, 2018, at 1:58 PM, Duane Knize Boat <kn… [at] san.rr.com> wrote:
> Keenan,
> If it is viable, with wire extensions, it might be good to place all the senders and thermostat in a pan of water on the galley stove along with a decent kitchen thermometer and check accuracy.
> Also, I seem to remember a Cal 46 Maison de Sante at Kona Marina, San Diego before we sailed Marlyn up to Frisco.
> Duane
> Duane Knize
> S/V Marlyn
> 1978 Cal 2-39 #18
> kn… [at] san.rr.com
>> Thanks,
>> Keenan Smith
