4 messages2018-08-25 03:25 UTCthrough 2018-08-25 15:05 UTC
Cal 2-27 transom with oily smudges
Donald Thomas2018-08-25 03:25 UTC
Checking in with you on this. I have only owned this boat with a Farymann
A 30 for a season. Water pump has a new impeller and plenty of water is
flowing through it. However I am finding an ever growing dark patch of
discoloration on the transom,...making me wonder about what's passing
through the motor and of the exhaust. When the engine is running there is
no unusual smoke, nothing to tell me oily stuff will be accumulating
outside the boat. Any of you folks have an opinion on what's happening
here?
*Donald J Thomas*
Broker Associate
*LIV Sotheby's International Realty*
101 S. Main St.
Breckenridge, Colorado
970-409-9133
www.teamthomasmountainhomes.com
Re: [Cal_Boats] Cal 2-27 transom with oily smudges
Helen Horn2018-08-25 06:43 UTC
May be blowby, try oil change and 50 weight, also maybe tune the injector. I saw this on the transom of another farymann powered cal, the owner ultimately replaced with a different diesel. Helen
On Fri, Aug 24, 2018 at 8:25 PM, Donald Thomas dn… [at] gmail.com [Cal_Boats]<Ca… [at] yahoogroups.com> wrote:
Checking in with you on this. I have only owned this boat with a Farymann A 30 for a season. Water pump has a new impeller and plenty of water is flowing through it.. However I am finding an ever growing dark patch of discoloration on the transom,...making me wonder about what's passing through the motor and of the exhaust. When the engine is running there is no unusual smoke, nothing to tell me oily stuff will be accumulating outside the boat. Any of you folks have an opinion on what's happening here?--
Donald J ThomasBroker AssociateLIV Sotheby's International Realty101 S. Main St.Breckenridge, Colorado 970-409-9133www.teamthomasmountainhomes.com -- {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} hr {border:1px solid #d8d8d8;} {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} {margin-bottom:10px;} .yiv2325993509ad {padding:0 0;} .yiv2325993509ad p {margin:0;} .yiv2325993509ad a {color:#0000ff;text-decoration:none;} {font-family:Arial;} {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} .yiv2325993509ad {margin-bottom:10px;padding:0 0;} {font-family:Verdana;font-size:11px;padding:10px 0;} {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} span {font-weight:700;} span:first-child {text-transform:uppercase;} span a {color:#5085b6;text-decoration:none;} span span {color:#ff7900;} span .yiv2325993509underline {text-decoration:underline;} .yiv2325993509attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} .yiv2325993509attach div a {text-decoration:none;} .yiv2325993509attach img {border:none;padding-right:5px;} .yiv2325993509attach label {display:block;margin-bottom:5px;} .yiv2325993509attach label a {text-decoration:none;} blockquote {margin:0 0 0 4px;} .yiv2325993509bold {font-family:Arial;font-size:13px;font-weight:700;} .yiv2325993509bold a {text-decoration:none;} dd.yiv2325993509last p a {font-family:Verdana;font-weight:700;} dd.yiv2325993509last p span {margin-right:10px;font-family:Verdana;font-weight:700;} dd.yiv2325993509last p span.yiv2325993509yshortcuts {margin-right:0;} div.yiv2325993509attach-table div div a {text-decoration:none;} div.yiv2325993509attach-table {width:400px;} div.yiv2325993509file-title a, div.yiv2325993509file-title a:active, div.yiv2325993509file-title a:hover, div.yiv2325993509file-title a:visited {text-decoration:none;} div.yiv2325993509photo-title a, div.yiv2325993509photo-title a:active, div.yiv2325993509photo-title a:hover, div.yiv2325993509photo-title a:visited {text-decoration:none;} div p a span.yiv2325993509yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;} .yiv2325993509green {color:#628c2a;} .yiv2325993509MsoNormal {margin:0 0 0 0;} o {font-size:0;} div {float:left;width:72px;} div div {border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} {font-size:77%;} {font-size:77%;} .yiv2325993509replbq {margin:4px;} div a:first-child {margin-right:2px;padding-right:5px;} {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} table {font-size:inherit;font:100%;} select, input, textarea {font:99% Arial, Helvetica, clean, sans-serif;} pre, code {font:115% monospace;} * {line-height:1.22em;} {padding-bottom:10px;} p a {font-family:Verdana;} p span {color:#1E66AE;font-weight:700;} {color:#ff7900;font-weight:700;} {margin-bottom:20px;padding:0px;} li a {font-size:130%;text-decoration:none;} li {font-size:77%;list-style-type:square;padding:6px 0;} ul {margin:0;padding:0 0 0 8px;} {font-family:Georgia;} p {margin:0 0 1em 0;} tt {font-size:120%;} ul li:last-child {border-right:none !important;}
NEWMAN2018-08-25 08:52 UTC
My Cal 33-2 with Yanmar 3GM30F after a lot of motoring would start to get
some black on the transom. Engine didn't smoke underway that I could see. I
just made sure to run it hard and also I found that I was idling too much.
Diesels want to be run under load. After letting your engine cool down
idling after a long motor, rev the engine say about five times to blow out
the carbon before shutting down. What Yanmar recommends is just that. I
take mine from idle right up to 3k RPM, then to idle. Sort of quick. Do
that five times and then idle back down a few seconds and shut the engine
off. Hopefully blowing out the carbon. And I washed the transom :).
Also, If the engine isn't using any oil to speak of it could be overloaded
say due to prop pitch. You never know if for sure the prop is correct for
that boat. You might want to check which prop you have and then get advice
on that as well. Overloaded diesel will have black smoke.
Leslie
On Friday, August 24, 2018, Donald Thomas dn… [at] gmail.com [Cal_Boats] <
> here?
> *Donald J Thomas*
> Broker Associate
> 101 S. Main St.
> <https://maps.google.com/?q=101+S.+Main+St.+Breckenridge,+Colorado+970&entry=gmail&source=g>
> 970
> -409-9133
Donald Thomas2018-08-25 15:05 UTC
Thanks for that. Will give them a try. Oil just changed before I cranked
it first time. Heavier grade, then injector. Thx
On Sat, Aug 25, 2018 at 12:43 AM, Helen Horn he… [at] sbcglobal.net
> <https://go.onelink.me/107872968?pid=InProduct&c=Global_Internal_YGrowth_AndroidEmailSig__AndroidUsers&af_wl=ym&af_sub1=Internal&af_sub2=Global_YGrowth&af_sub3=EmailSignature>
> [Cal_Boats]
> here?
> *Donald J Thomas*
> Broker Associate
> 101 S. Main St.
> 970
> -409-9133
*Donald J Thomas*
Broker Associate
101 S. Main St.
970-409-9133
