Oil for A30M Farymann diesel
5 messages2018-08-25 15:26 UTCthrough 2018-08-26 14:04 UTC
je… [at] mindspring.com2018-08-25 15:26 UTC
Putting 50 weight oil in a Farymann A30M is a BIG mistake. This engine has a roller bearing rod & crank, and is dip/splash lubricated. It is NOT a pressurized oil system. You should be using 20 weight DIESEL GRADE oil, or 10W 30 weight, as per the manual. Joe DeMers From: "Donald Thomas dn… [at] gmail.com [Cal_Boats]" Sent: Aug 25, 2018 11:05 AM To: Ca… [at] yahoogroups.com, "he… [at] sbcglobal.net" Subject: Re: [Cal_Boats] Cal 2-27 transom with oily smudges Thanks for that. Will give them a try. Oil just changed before I cranked it first time. Heavier grade, then injector. Thx On Sat, Aug 25, 2018 at 12:43 AM, Helen Horn he… [at] sbcglobal.net [Cal_Boats] < Ca… [at] yahoogroups.com > wrote: May be blowby, try oil change and 50 weight, also maybe tune the injector. I saw this on the transom of another farymann powered cal, the owner ultimately replaced with a different diesel. Helen Sent from Yahoo Mail on Android On Fri, Aug 24, 2018 at 8:25 PM, Donald Thomas dn… [at] gmail.com [Cal_Boats] < Ca… [at] yahoogroups.com > wrote: Checking in with you on this. I have only owned this boat with a Farymann A 30 for a season.. Water pump has a new impeller and plenty of water is flowing through it.. However I am finding an ever growing dark patch of discoloration on the transom,...making me wonder about what's passing through the motor and of the exhaust. When the engine is running there is no unusual smoke, nothing to tell me oily stuff will be accumulating outside the boat. Any of you folks have an opinion on what's happening here? -- Donald J Thomas Broker Associate LIV Sotheby's International Realty 101 S. Main St. Breckenridge, Colorado 970 -409-9133 www.teamthomasmountainhomes. com -- Donald J Thomas Broker Associate LIV Sotheby's International Realty 101 S. Main St. Breckenridge, Colorado 970-409-9133 www.teamthomasmountainhomes.com
Re: [Cal_Boats] Oil for A30M Farymann diesel
r good2018-08-25 19:20 UTC
does the A30M have an intake air filter? Reggie Sent from Outlook<http://aka.ms/weboutlook> From: Ca… [at] yahoogroups.com <Ca… [at] yahoogroups.com> on behalf of je… [at] mindspring.com [Cal_Boats] <Ca… [at] yahoogroups.com> Sent: Saturday, August 25, 2018 9:26 AM To: Ca… [at] yahoogroups.com; Donald Thomas; Ca… [at] yahoogroups.com; he… [at] sbcglobal.net Subject: [Cal_Boats] Oil for A30M Farymann diesel Putting 50 weight oil in a Farymann A30M is a BIG mistake. This engine has a roller bearing rod & crank, and is dip/splash lubricated. It is NOT a pressurized oil system. You should be using 20 weight DIESEL GRADE oil, or 10W 30 weight, as per the manual. Joe DeMers From: "Donald Thomas dn… [at] gmail.com [Cal_Boats]" Sent: Aug 25, 2018 11:05 AM To: Ca… [at] yahoogroups.com, "he… [at] sbcglobal.net" Subject: Re: [Cal_Boats] Cal 2-27 transom with oily smudges Thanks for that. Will give them a try. Oil just changed before I cranked it first time. Heavier grade, then injector. Thx On Sat, Aug 25, 2018 at 12:43 AM, Helen Horn he… [at] sbcglobal.net<mailto:he… [at] sbcglobal.net> [Cal_Boats] <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>> wrote: May be blowby, try oil change and 50 weight, also maybe tune the injector. I saw this on the transom of another farymann powered cal, the owner ultimately replaced with a different diesel. Helen Sent from Yahoo Mail on Android<https://go.onelink.me/107872968?pid=InProduct&c=Global_Internal_YGrowth_AndroidEmailSig__AndroidUsers&af_wl=ym&af_sub1=Internal&af_sub2=Global_YGrowth&af_sub3=EmailSignature> On Fri, Aug 24, 2018 at 8:25 PM, Donald Thomas dn… [at] gmail.com<mailto:dn… [at] gmail.com> [Cal_Boats] <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>> wrote: Checking in with you on this. I have only owned this boat with a Farymann A 30 for a season.. Water pump has a new impeller and plenty of water is flowing through it.. However I am finding an ever growing dark patch of discoloration on the transom,...making me wonder about what's passing through the motor and of the exhaust. When the engine is running there is no unusual smoke, nothing to tell me oily stuff will be accumulating outside the boat. Any of you folks have an opinion on what's happening here? -- Donald J Thomas Broker Associate LIV Sotheby's International Realty 101 S. Main St.<https://maps.google.com/?q=101+S.+Main+St.+Breckenridge,+Colorado+970&entry=gmail&source=g> Breckenridge, Colorado<https://maps..google.com/?q=101+S.+Main+St.+Breckenridge,+Colorado+970&entry=gmail&source=g> 970<https://maps.google.com/?q=101+S.+Main+St.+Breckenridge,+Colorado+970&entry=gmail&source=g>-409-9133 www.teamthomasmountainhomes.com<http://www.teamthomasmountainhomes.com> -- Donald J Thomas Broker Associate LIV Sotheby's International Realty 101 S. Main St. Breckenridge, Colorado 970-409-9133 www.teamthomasmountainhomes.com<http://www.teamthomasmountainhomes.com>
DT Gmail2018-08-26 04:31 UTC
I will check that. We operste at 9,000 feet....and that has me wondering about how a tune up might be done. Will look for air filter. Thx > On Aug 25, 2018, at 1:20 PM, r good my… [at] hotmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > does the A30M have an intake air filter? > Reggie > > Sent from Outlook > > > From: Ca… [at] yahoogroups.com <Ca… [at] yahoogroups.com> on behalf of je… [at] mindspring.com [Cal_Boats] <Ca… [at] yahoogroups.com> > Sent: Saturday, August 25, 2018 9:26 AM > To: Ca… [at] yahoogroups.com; Donald Thomas; Ca… [at] yahoogroups.com; he… [at] sbcglobal.net > Subject: [Cal_Boats] Oil for A30M Farymann diesel > > > Putting 50 weight oil in a Farymann A30M is a BIG mistake. This engine has a roller bearing rod & crank, and is dip/splash lubricated. It is NOT a pressurized oil system. > > You should be using 20 weight DIESEL GRADE oil, or 10W 30 weight, as per the manual. Joe DeMers > > -----Original Message----- > From: "Donald Thomas dn… [at] gmail.com [Cal_Boats]" > Sent: Aug 25, 2018 11:05 AM > To: Ca… [at] yahoogroups.com, "he… [at] sbcglobal.net" > Subject: Re: [Cal_Boats] Cal 2-27 transom with oily smudges > > > > Thanks for that. Will give them a try. Oil just changed before I cranked it first time. Heavier grade, then injector. Thx > > On Sat, Aug 25, 2018 at 12:43 AM, Helen Horn he… [at] sbcglobal.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > May be blowby, try oil change and 50 weight, also maybe tune the injector. I saw this on the transom of another farymann powered cal, the owner ultimately replaced with a different diesel. Helen > > Sent from Yahoo Mail on Android > > On Fri, Aug 24, 2018 at 8:25 PM, Donald Thomas dn… [at] gmail.com [Cal_Boats] > <Ca… [at] yahoogroups.com> wrote: > > > Checking in with you on this. I have only owned this boat with a Farymann A 30 for a season.. Water pump has a new impeller and plenty of water is flowing through it.. However I am finding an ever growing dark patch of discoloration on the transom,...making me wonder about what's passing through the motor and of the exhaust. When the engine is running there is no unusual smoke, nothing to tell me oily stuff will be accumulating outside the boat. Any of you folks have an opinion on what's happening here? > -- > Donald J Thomas > Broker Associate > LIV Sotheby's International Realty > 101 S. Main St. > Breckenridge, Colorado > 970-409-9133 > www.teamthomasmountainhomes.com > > > > -- > Donald J Thomas > Broker Associate > LIV Sotheby's International Realty > 101 S. Main St. > Breckenridge, Colorado > 970-409-9133 > www.teamthomasmountainhomes.com > > >
Helen Horn2018-08-26 07:25 UTC
Donald, very sorry, Joe is correct, don't use 50 weight in diesel, Helen...Thanks Joe for catching that. Sent from Yahoo Mail on Android On Sat, Aug 25, 2018 at 9:31 PM, DT Gmail dn… [at] gmail.com [Cal_Boats]<Ca… [at] yahoogroups.com> wrote: I will check that. We operste at 9,000 feet....and that has me wondering about how a tune up might be done. Will look for air filter. Thx On Aug 25, 2018, at 1:20 PM, r good my… [at] hotmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: does the A30M have an intake air filter? Reggie Sent from Outlook From: Ca… [at] yahoogroups.com <Ca… [at] yahoogroups.com> on behalf of je… [at] mindspring.com [Cal_Boats] <Ca… [at] yahoogroups.com> Sent: Saturday, August 25, 2018 9:26 AM To: Ca… [at] yahoogroups.com; Donald Thomas; Ca… [at] yahoogroups.com; he… [at] sbcglobal.net Subject: [Cal_Boats] Oil for A30M Farymann diesel Putting 50 weight oil in a Farymann A30M is a BIG mistake. This engine has a roller bearing rod & crank, and is dip/splash lubricated. It is NOT a pressurized oil system. You should be using 20 weight DIESEL GRADE oil, or 10W 30 weight, as per the manual. Joe DeMers From: "Donald Thomas dn… [at] gmail.com [Cal_Boats]" Sent: Aug 25, 2018 11:05 AM To: Ca… [at] yahoogroups.com, "he… [at] sbcglobal.net" Subject: Re: [Cal_Boats] Cal 2-27 transom with oily smudges Thanks for that. Will give them a try. Oil just changed before I cranked it first time. Heavier grade, then injector. Thx On Sat, Aug 25, 2018 at 12:43 AM, Helen Horn he… [at] sbcglobal.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: May be blowby, try oil change and 50 weight, also maybe tune the injector. I saw this on the transom of another farymann powered cal, the owner ultimately replaced with a different diesel. Helen Sent from Yahoo Mail on Android On Fri, Aug 24, 2018 at 8:25 PM, Donald Thomas dn… [at] gmail.com [Cal_Boats]<Ca… [at] yahoogroups.com> wrote: Checking in with you on this. I have only owned this boat with a Farymann A 30 for a season.. Water pump has a new impeller and plenty of water is flowing through it.. However I am finding an ever growing dark patch of discoloration on the transom,...making me wonder about what's passing through the motor and of the exhaust. When the engine is running there is no unusual smoke, nothing to tell me oily stuff will be accumulating outside the boat. Any of you folks have an opinion on what's happening here?-- Donald J ThomasBroker AssociateLIV Sotheby's International Realty101 S. Main St.Breckenridge, Colorado970-409-9133www.teamthomasmountainhomes. com -- Donald J ThomasBroker AssociateLIV Sotheby's International Realty101 S. Main St.Breckenridge, Colorado 970-409-9133www.teamthomasmountainhomes.com
Donald Thomas2018-08-26 14:04 UTC
It's such a supportive group, one's input cannot help but be appreciated. Buying a boat this old with the quirks and challenges is so much more rewarding than marching down to the store and buying a boat by its catalog picture and the rumors about it's virtues. I have taken risks buying and committing to this boat's restoration and everyday use and the experience has been challenging but the rewards exhilarating. Thanks for helping make it possible to have this adventure, Helen. You, and everyone reading and contributing makes is much more possible. On Sun, Aug 26, 2018 at 1:25 AM, Helen Horn he… [at] sbcglobal.net [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > Donald, very sorry, Joe is correct, don't use 50 weight in diesel, > Helen...Thanks Joe for catching that. > > Sent from Yahoo Mail on Android > <https://go.onelink.me/107872968?pid=InProduct&c=Global_Internal_YGrowth_AndroidEmailSig__AndroidUsers&af_wl=ym&af_sub1=Internal&af_sub2=Global_YGrowth&af_sub3=EmailSignature> > > On Sat, Aug 25, 2018 at 9:31 PM, DT Gmail dn… [at] gmail.com [Cal_Boats] > <Ca… [at] yahoogroups.com> wrote: > > > I will check that. We operste at 9,000 feet....and that has me wondering > about how a tune up might be done. Will look for air filter. Thx > > Sent from my iPhone > > On Aug 25, 2018, at 1:20 PM, r good my… [at] hotmail.com [Cal_Boats] < > Ca… [at] yahoogroups.com> wrote: > > > > does the A30M have an intake air filter? > > Reggie > > > Sent from Outlook <http://aka.ms/weboutlook> > > > ------------------------------ > *From:* Ca… [at] yahoogroups.com <Ca… [at] yahoogroups.com> on behalf > of je… [at] mindspring.com [Cal_Boats] <Ca… [at] yahoogroups.com> > *Sent:* Saturday, August 25, 2018 9:26 AM > *To:* Ca… [at] yahoogroups.com; Donald Thomas; Ca… [at] yahoogroups.com; > he… [at] sbcglobal.net > *Subject:* [Cal_Boats] Oil for A30M Farymann diesel > > > > Putting 50 weight oil in a Farymann A30M is a BIG mistake. This engine has > a roller bearing rod & crank, and is dip/splash lubricated. It is NOT a > pressurized oil system. > > You should be using 20 weight DIESEL GRADE oil, or 10W 30 weight, as per > the manual. Joe DeMers > > -----Original Message----- > From: "Donald Thomas dn… [at] gmail.com [Cal_Boats]" > Sent: Aug 25, 2018 11:05 AM > To: Ca… [at] yahoogroups.com, "he… [at] sbcglobal.net" > Subject: Re: [Cal_Boats] Cal 2-27 transom with oily smudges > > > > Thanks for that. Will give them a try. Oil just changed before I cranked > it first time. Heavier grade, then injector. Thx > > On Sat, Aug 25, 2018 at 12:43 AM, Helen Horn he… [at] sbcglobal.net > [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > > May be blowby, try oil change and 50 weight, also maybe tune the injector. > I saw this on the transom of another farymann powered cal, the owner > ultimately replaced with a different diesel. Helen > > Sent from Yahoo Mail on Android > <https://go.onelink.me/107872968?pid=InProduct&c=Global_Internal_YGrowth_AndroidEmailSig__AndroidUsers&af_wl=ym&af_sub1=Internal&af_sub2=Global_YGrowth&af_sub3=EmailSignature> > > On Fri, Aug 24, 2018 at 8:25 PM, Donald Thomas dn… [at] gmail.com > [Cal_Boats] > <Ca… [at] yahoogroups.com> wrote: > > > > Checking in with you on this. I have only owned this boat with a Farymann > A 30 for a season.. Water pump has a new impeller and plenty of water is > flowing through it.. However I am finding an ever growing dark patch of > discoloration on the transom,...making me wonder about what's passing > through the motor and of the exhaust. When the engine is running there is > no unusual smoke, nothing to tell me oily stuff will be accumulating > outside the boat. Any of you folks have an opinion on what's happening > here? > -- > *Donald J Thomas* > Broker Associate > *LIV Sotheby's International Realty* > 101 S. Main St. > <https://maps.google.com/?q=101+S.+Main+St.+Breckenridge,+Colorado+970&entry=gmail&source=g> > Breckenridge, Colorado > <https://maps..google.com/?q=101+S.+Main+St.+Breckenridge,+Colorado+970&entry=gmail&source=g> > 970 > <https://maps.google.com/?q=101+S.+Main+St.+Breckenridge,+Colorado+970&entry=gmail&source=g> > -409-9133 > www.teamthomasmountainhomes. com <http://www.teamthomasmountainhomes.com> > > > > > -- > *Donald J Thomas* > Broker Associate > *LIV Sotheby's International Realty* > 101 S. Main St. > <https://maps.google.com/?q=101+S.+Main+St.+%0D%0A+Breckenridge,+Colorado+%0D%0A+%0D%0A+970&entry=gmail&source=g> > Breckenridge, Colorado > <https://maps.google.com/?q=101+S.+Main+St.+%0D%0A+Breckenridge,+Colorado+%0D%0A+%0D%0A+970&entry=gmail&source=g> > 970 > <https://maps.google.com/?q=101+S.+Main+St.+%0D%0A+Breckenridge,+Colorado+%0D%0A+%0D%0A+970&entry=gmail&source=g> > -409-9133 > www.teamthomasmountainhomes.com > > > > -- *Donald J Thomas* Broker Associate *LIV Sotheby's International Realty* 101 S. Main St. Breckenridge, Colorado 970-409-9133 www.teamthomasmountainhomes.com
