Re: [Cal_Boats] Cal 39 Mark II anchor/steaming bulbs?
1 messages2018-09-15 01:22 UTCthrough 2018-09-15 01:22 UTC
rj… [at] juno.com2018-09-15 01:22 UTC
If the anchor light is also an AQUA SIGNAL "Series 25" light, it will be the same bulb. We had this same "masthead" (Steaming) light on NODROG's mast, and I had the 360deg light on another boat, used same 10W bulb. Rod Johnson, "SUNBIRD" 1979 O'DAY DS II previous boat, "NODROG" 1970 CAL 21 Please note: message attached From: "Sean Dimond se… [at] untamed.be [Cal_Boats]" <Ca… [at] yahoogroups.com> To: ccampbell <cc… [at] lsnm.org> Cc: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com> Subject: Re: [Cal_Boats] Cal 39 Mark II anchor/steaming bulbs? Date: Fri, 14 Sep 2018 15:56:58 +0000 Oncologists Freak Out Over True Cause of Cancer pro.healthresponses.org http://thirdpartyoffers.juno.com/TGL3141/5b9c5f0ceb4e55f0c7d91st03duc For sure... going LEDs. Just not sure if the anchor masthead bulb is the same... S On Sep 14, 2018, at 08:53, ccampbell <cc… [at] lsnm.org<mailto:cc… [at] lsnm.org>> wrote: Just looking at the photo, it appears that the filament is intact but the terminals on the bulb are corroded. You may just need to clean those up and apply some sort of anticorrosion goop to keep the contacts good. But if you're replacing the bulb, why not go with LEDs? I was surprised to see a wide assortment of drop-in LED replacements at West Marine a few weeks ago. Practical Sailor has had some recommendations for conductive anticorrosion grease, as I recall. Chris Campbell On 9/14/2018 12:33 AM, Sean Dimond se… [at] untamed.be<mailto:se… [at] untamed.be> [Cal_Boats] wrote: Curious if anyone knows the exact replacement anchor bulb for a 1978 Cal 39 Mark II? Attached is a picture of the steaming light 3/4 up the mast… its an older 12v Festoon bulb. But is the anchor light the same? Long story, but the answer will save me two trips up the mast in the bosun chair. Thanks in advance! <festoon.png> Sean S/V AIOLOS Seattle, WA
