Max Prop for Cal 33-2
2 messages2018-10-29 10:36 UTCthrough 2018-10-30 00:28 UTC
dh… [at] gmail.com2018-10-29 10:36 UTC
Has anyone put a 3 blade Max Prop classic on their Cal 33-2? I am considering it and am wondering what you thought of the improvements. Also, what size Max Prop did you get and how did you set it up? My 33-2 is a stock 1987 (Yanmar 3GM30F) and currently has a Michigan Sailer 2-blade 16RH15 prop which seems to work fine but I wouldn't mind a smoother running prop with less drag. Thanks. -Doug Hoffman Port Sanilac, Michigan
Re: [Cal_Boats] Max Prop for Cal 33-2
Edward Stancil2018-10-30 00:28 UTC
Hey doug they adjustable... I'm a MAX PROP DEALER .. and can get 20%...Off If you want ...the prop shop Has a book with your boat in it They make a choice for you Based on 20,000 porps sold.. Let me know ...you pay PVI.. DIRECT..Edward ...northern light.. Cal 39 markII..how many Hp .. On Mon, Oct 29, 2018, 3:41 AM dh… [at] gmail.com [Cal_Boats] < Ca… [at] yahoogroups.com> wrote: > > > Has anyone put a 3 blade Max Prop classic on their Cal 33-2? I am > considering it and am wondering what you thought of the improvements. Also, > what size Max Prop did you get and how did you set it up? My 33-2 is a > stock 1987 (Yanmar 3GM30F) and currently has a Michigan Sailer 2-blade > 16RH15 prop which seems to work fine but I wouldn't mind a smoother running > prop with less drag. > > > Thanks. > > -Doug Hoffman > > Port Sanilac, Michigan > >
