2 messages2019-01-25 15:49 UTCthrough 2019-01-25 15:59 UTC
One way Valves in a bilge line
Bruce Boyles2019-01-25 15:49 UTC
I have what appears to be a common problem with my bilge pump. The pump runs fine but when it stops water left in the line flows back into the bilge. Currently I have an electric bilge and a manual bilge pump connected with a Y-valve a couple of feet ahead the stern exhaust port. I was thinking of replacing the Y-valve with a Y-valve with one-way exit ports. In doing some research, I have come across blogs that say this is not a good idea even to the point where it could nullify my insurance. I would welcome this group's input on the subject.
BruceOsprey1975 Cal 2-27
Re: [Cal_Boats] One way Valves in a bilge line
Allen Edwards2019-01-25 15:59 UTC
I don't understand what you are saying about your existing setup but I
might offer some suggestions. I have two pumps. One is large with a large
hoes going to a dedicated fitting on the stern. The other is small with a
small hose that goes to the same fitting with a T fitting right at the
stern. That line has a check valve that keeps water from flowing back.
Probably would be better to have an anti syphon there instead but that is
what I have. The amount of water that flows back if the large pump every
runs is a lot but it never runs and is there just in case I get a large
leak. The small one is an automatic pump and goes on every few minutes.
It lasts almost 5 years and I always buy the extended warranty so only have
to buy a new extended warranty every 5 years but the pump itself is free
(after the first time).
I also have a manual pump that is in the same line as the large manual one
but with a valve setup a bit complicated to explain. Basically, the manual
pump draws water from forward of the check valve and deposits it aft of the
check valve. That way either pump can work without manual intervention
other than working the pump.
On Fri, Jan 25, 2019 at 7:49 AM Bruce Boyles br… [at] yahoo.com
> Thanks,
> Bruce
> Osprey
> 1975 Cal 2-27
