Re: Cal 2-29 [2 Attachments]
1 messages2019-04-21 05:27 UTCthrough 2019-04-21 05:27 UTC
Sean Ladwig2019-04-21 05:27 UTC
Jimmy, In case this is your first time here's a link explaining how to address the issue. https://www.boatus.com/boattech/casey/stuffing-box.asp Had the same problem and also had a hard time tracing it. It's not fun. I did it with a packing nut wrench and a pipe wrench. 2 packing nut wrenches would've been easier. Found one on the boat (after the fact) that has the handle cut down to allow for turns more than a mm at a time. Good luck, Sean 1969 CAL34 cruising edition St. Marks, FL
