Fuel linkages 4108
Fuel linkages 4108
7 messages2019-06-21 03:50 UTCthrough 2019-06-21 17:00 UTC
Fuel linkages 4108
Edward Stancil2019-06-21 03:50 UTC
Hi guys have trouble with Keeping rpms up Now engine starts And when MOVE fuel control lever on binnacle Engine revs up. Then Idles but down to idles. Feel disconnected And Not Positive as I would like it .. 1979 Cal 39 4108 Perkins Diesel So once again .. Start eng.. Throttle on up position Engine increases rpms Then eng slowly drops Back to idle...eventhough Is in full position.. Thanks Edward Stancil Cal 39 Northern Light
Re: [Cal_Boats] Fuel linkages 4108
Doug Hoffman2019-06-21 10:04 UTC
Check the simple stuff first. Sounds like it could be fuel starvation, but fuel not totally blocked. Replace fuel filter(s), looking at old filters when removed checking for signs of excess contamination. If filters are gunked up and that fixes problem, consider cleaning fuel tank. Regards, -Doug > On Jun 20, 2019, at 11:50 PM, Edward Stancil e.… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > Hi guys have trouble with > Keeping rpms up > Now engine starts > And when MOVE fuel control lever on binnacle > Engine revs up. Then > Idles but down to idles. > Feel disconnected > And Not Positive as > I would like it .. > 1979 Cal 39 > 4108 Perkins Diesel > So once again .. > Start eng... > Throttle on up position > Engine increases rpms > Then eng slowly drops > Back to idle...eventhough > Is in full position.. > > Thanks Edward Stancil > Cal 39 Northern Light > > >
Yahoo Mail2019-06-21 12:39 UTC
Having rebuilt over 200 Perkins 4.108's in the last five years, I suggest:1- Disconnect cable for throttle. Hold lever about 1/4 position while someone you trust starts the engine. When she starts return lever to idle for one minute. Then rev it to desired RPM's If all okay replace and/or adjust the cable to the binnacle. 2-If cable linkage is okay, start at the fuel tank examining fittings and hose. Replace all fuel water separators and filters, being careful to bleed properly. Run the engine to test. 3-How old is your fuel? When is the last time you had the fuel polished and the tank(s) cleaned? Have some firm pump the fuel out through a water separator/filter, clean the tanks and add cetane booster to old fuel. Try to keep you fuel tanks full to minimize the air space in the tank. Daytime heat expands the air and it escapes the tank, evening cool draws moisture laden air into the tank, it condenses and the water goes to the bottom of the tank. 4-Have your fuel injectors tested, cleaned and calibrated, Take you F.I. high pressure pump to a competent firm and have it tested and repaired as needed. We use Atmore Fuel Injection in Atmore, AL. Be sure to mark timing before removing the pump. Hope this helps, Tom Vandiver, Cal 46 SATORI, 37 years & BSH Marine LLC, Pensacola, FL On Thursday, June 20, 2019, 10:51:07 PM CDT, Edward Stancil e.… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Hi guys have trouble withKeeping rpms upNow engine starts And when MOVE fuel control lever on binnacleEngine revs up. Then Idles but down to idles.Feel disconnected And Not Positive asI would like it ..1979 Cal 39 4108 Perkins DieselSo once again ..Start eng... Throttle on up positionEngine increases rpmsThen eng slowly dropsBack to idle...eventhoughIs in full position.. Thanks Edward StancilCal 39 Northern Light
Frank Brown2019-06-21 13:00 UTC
Check your fuel filter would be where I would start......I used to have a Cal 39 with a Perkins 4-108.....Amazing Grace Frank W. Brown Managing Director BankersBanc Capital Corporation 4880 Northside Drive NW Atlanta, GA 30327 (404) 683-1027 fb… [at] yahoo.com On Friday, June 21, 2019, 8:39:32 AM EDT, Yahoo Mail bs… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Having rebuilt over 200 Perkins 4.108's in the last five years, I suggest:1- Disconnect cable for throttle. Hold lever about 1/4 position while someone you trust starts the engine. When she starts return lever to idle for one minute. Then rev it to desired RPM's If all okay replace and/or adjust the cable to the binnacle. 2-If cable linkage is okay, start at the fuel tank examining fittings and hose. Replace all fuel water separators and filters, being careful to bleed properly. Run the engine to test. 3-How old is your fuel? When is the last time you had the fuel polished and the tank(s) cleaned? Have some firm pump the fuel out through a water separator/filter, clean the tanks and add cetane booster to old fuel. Try to keep you fuel tanks full to minimize the air space in the tank. Daytime heat expands the air and it escapes the tank, evening cool draws moisture laden air into the tank, it condenses and the water goes to the bottom of the tank. 4-Have your fuel injectors tested, cleaned and calibrated, Take you F.I. high pressure pump to a competent firm and have it tested and repaired as needed. We use Atmore Fuel Injection in Atmore, AL. Be sure to mark timing before removing the pump. Hope this helps, Tom Vandiver, Cal 46 SATORI, 37 years & BSH Marine LLC, Pensacola, FL On Thursday, June 20, 2019, 10:51:07 PM CDT, Edward Stancil e.… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Hi guys have trouble withKeeping rpms upNow engine starts And when MOVE fuel control lever on binnacleEngine revs up. Then Idles but down to idles.Feel disconnected And Not Positive asI would like it ..1979 Cal 39 4108 Perkins DieselSo once again ..Start eng... Throttle on up positionEngine increases rpmsThen eng slowly dropsBack to idle...eventhoughIs in full position.. Thanks Edward StancilCal 39 Northern Light
Re: Fuel linkages 4108
Edward Stancil2019-06-21 15:41 UTC
Fuel filter and raycore. Disassembled wiped Clean filled bled system Engine stated.. (Before Engine cranked But would keep going) Injection pump is hidden And cannot get a view.. Throttle is hookup Backwards so back Is power.. Forward is off. But Tom is this a fuel Starvation problem ? It feels like linkage Is slideing between lever (on binnacle) and injection Pump .. when throttled Up then rpms increase But slowly engine goes Back to ldle .. Moving throttle back to Idle On Thu, Jun 20, 2019, 8:50 PM Edward Stancil <e.… [at] gmail.com> wrote: > Hi guys have trouble with > Keeping rpms up > Now engine starts > And when MOVE fuel control lever on binnacle > Engine revs up. Then > Idles but down to idles. > Feel disconnected > And Not Positive as > I would like it .. > 1979 Cal 39 > 4108 Perkins Diesel > So once again .. > Start eng.. > Throttle on up position > Engine increases rpms > Then eng slowly drops > Back to idle...eventhough > Is in full position.. l move > Control back to idle then Forward.. And slowly rpms increase Eachtime then decrease But lever still at full on > Thanks Edward Stancil > Cal 39 Northern Light > > On Thu, Jun 20, 2019, 8:50 PM Edward Stancil <e.… [at] gmail.com> wrote: > Hi guys have trouble with > Keeping rpms up > Now engine starts > And when MOVE fuel control lever on binnacle > Engine revs up. Then > Idles but down to idles. > Feel disconnected > And Not Positive as > I would like it .. > 1979 Cal 39 > 4108 Perkins Diesel > So once again .. > Start eng.. > Throttle on up position > Engine increases rpms > Then eng slowly drops > Back to idle...eventhough > Is in full position.. > > Thanks Edward Stancil > Cal 39 Northern Light > >
Re: [Cal_Boats] Re: Fuel linkages 4108
Doug Hoffman2019-06-21 15:47 UTC
> On Jun 21, 2019, at 11:41 AM, Edward Stancil e.… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > Fuel filter and raycore. > Disassembled wiped > Clean filled bled system > Engine stated.. > (Before Engine cranked > But would keep going) > Injection pump is hidden > And cannot get a view.. > Throttle is hookup > Backwards so back > Is power.. Forward is off. > > But Tom is this a fuel > Starvation problem ? > > It feels like linkage > Is slideing between lever > (on binnacle) and injection > Pump .. Then try like was suggested. Bypass the linkage and work the fuel lever directly by hand. Easy stuff first. -Doug > when throttled > Up then rpms increase > But slowly engine goes > Back to ldle .. > Moving throttle back to > Idle > > > > On Thu, Jun 20, 2019, 8:50 PM Edward Stancil <e.… [at] gmail.com> wrote: > Hi guys have trouble with > Keeping rpms up > Now engine starts > And when MOVE fuel control lever on binnacle > Engine revs up. Then > Idles but down to idles. > Feel disconnected > And Not Positive as > I would like it .. > 1979 Cal 39 > 4108 Perkins Diesel > So once again .. > Start eng.. > Throttle on up position > Engine increases rpms > Then eng slowly drops > Back to idle...eventhough > Is in full position.. l move > Control back to idle then > Forward.. > And slowly rpms increase > Eachtime then decrease > But lever still at full on > > > > Thanks Edward Stancil > Cal 39 Northern Light > > > On Thu, Jun 20, 2019, 8:50 PM Edward Stancil <e.… [at] gmail.com> wrote: > Hi guys have trouble with > Keeping rpms up > Now engine starts > And when MOVE fuel control lever on binnacle > Engine revs up. Then > Idles but down to idles. > Feel disconnected > And Not Positive as > I would like it .. > 1979 Cal 39 > 4108 Perkins Diesel > So once again .. > Start eng.. > Throttle on up position > Engine increases rpms > Then eng slowly drops > Back to idle...eventhough > Is in full position.. > > Thanks Edward Stancil > Cal 39 Northern Light > > >
KEVIN BAERG2019-06-21 17:00 UTC
If you keep your hand on the lever do the rpm’s stay level? On my Cal 2-46, I replaced the throttle cable. I opted not to do the screw thing that would keep tension on the cable so it would stay where the throttle lever was placed on the binnacle. I didn’t want the possible moisture/corrosion entry point. So, our throttle will only stay up to about 1250 rpm - if I push it higher, it slides back down. We use a headband from my wife to keep pressure on the lever so it stays where we want it. I believe you can also get a different lever system at the binnacle that will lock it where you want it. Cheers, Kevin Baerg former owner of “Blue” Cal 2-46 > On Jun 21, 2019, at 8:47 AM, Doug Hoffman dh… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > > > On Jun 21, 2019, at 11:41 AM, Edward Stancil e.… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > > > > Fuel filter and raycore. > > Disassembled wiped > > Clean filled bled system > > Engine stated.. > > (Before Engine cranked > > But would keep going) > > Injection pump is hidden > > And cannot get a view.. > > Throttle is hookup > > Backwards so back > > Is power.. Forward is off. > > > > But Tom is this a fuel > > Starvation problem ? > > > > It feels like linkage > > Is slideing between lever > > (on binnacle) and injection > > Pump .. > > Then try like was suggested. Bypass the linkage and work the fuel lever directly by hand. > Easy stuff first. > > -Doug > > > when throttled > > Up then rpms increase > > But slowly engine goes > > Back to ldle .. > > Moving throttle back to > > Idle > > > > > > > > On Thu, Jun 20, 2019, 8:50 PM Edward Stancil <e.… [at] gmail.com> wrote: > > Hi guys have trouble with > > Keeping rpms up > > Now engine starts > > And when MOVE fuel control lever on binnacle > > Engine revs up. Then > > Idles but down to idles. > > Feel disconnected > > And Not Positive as > > I would like it .. > > 1979 Cal 39 > > 4108 Perkins Diesel > > So once again .. > > Start eng.. > > Throttle on up position > > Engine increases rpms > > Then eng slowly drops > > Back to idle...eventhough > > Is in full position.. l move > > Control back to idle then > > Forward.. > > And slowly rpms increase > > Eachtime then decrease > > But lever still at full on > > > > > > > > Thanks Edward Stancil > > Cal 39 Northern Light > > > > > > On Thu, Jun 20, 2019, 8:50 PM Edward Stancil <e.… [at] gmail.com> wrote: > > Hi guys have trouble with > > Keeping rpms up > > Now engine starts > > And when MOVE fuel control lever on binnacle > > Engine revs up. Then > > Idles but down to idles. > > Feel disconnected > > And Not Positive as > > I would like it .. > > 1979 Cal 39 > > 4108 Perkins Diesel > > So once again .. > > Start eng.. > > Throttle on up position > > Engine increases rpms > > Then eng slowly drops > > Back to idle...eventhough > > Is in full position.. > > > > Thanks Edward Stancil > > Cal 39 Northern Light > > > > > > > > >
